| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
I don't see why not. Looks like you'll still need to drill a 3/4" hole in the bumper so that doesn't leave much "wiggle" room since the exposed part of the latch you want to use is only 1".....but if you do it right, you won't need any wiggle room.
| The Following User Says Thank You to BirdTRD For This Useful Post: | Exrald (11-29-2017) |
#30 |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
With these installed what can you leave off in terms of the original fasteners?
I don't have any sag (yet) but if these make it faster/easier to get the bumper off and on I might as well do it now...going to take it off to respray my lip anyway >< |
#31 |
Drives: 2017 BRZ
How many times removing the bumper does it generally take before it starts to sag? Only had mine off once so far and it still looks good, wondering if I should plan on getting something like this installed the next time it comes off or if I don't need to worry about it yet.
#32 | ||
Simply Forgotus
The only reason I installed these was to remove the notorious gap. They do not make it faster or easier to remove the bumper in any way. If you don't have the gap, I wouldn't install them. |
| The Following User Says Thank You to BirdTRD For This Useful Post: | BRZyJ (03-07-2018) |
#33 |
#34 |
Country Boy 4 Life
USE A STEP BIT!!!
For the bumber and inner plastic. via Imgflip Meme Generator via Imgflip Meme Generator
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | BirdTRD (05-19-2018) |
#35 |
Simply Forgotus
#36 |
Country Boy 4 Life
Thats a good point, don't use a drill without variable speed. I used my cordless drill on slow speed 1 with a new bit. It was easy to drill the hole to the correct step.
I LIKE TIRES! |
#37 |
Drives: Series. Blue
Awesome write up, worked out great! My bumper tabs were so far gone i needed two for each side
| The Following 2 Users Say Thank You to bjac86 For This Useful Post: | BirdTRD (06-06-2018), PerCompLLC (10-16-2021) |
#38 |
This is great! This is only one quick release were all the others are showing two.
| Tags |
| quik latch |
| DIY - Quik Latch Mini install(front bumper) | stevo_12v | DIY (Do-It-Yourself) Guides | 31 | 07-20-2018 10:12 AM |
| DIY: TheRetrofitSource/Morimoto Retro-Quik Install in FR-S | civicdrivr | DIY (Do-It-Yourself) Guides | 236 | 07-10-2017 12:04 AM |
| FS: Quik Latch Mini Black | Ny Brz | Exterior Parts (Aero, Lighting, Etc.) | 1 | 06-22-2015 07:10 PM |
| FS: WA _Black Anodized Mini Quik-Latches NEW ..Great fix for bumper fitment issues!! | glamcem | Exterior Parts (Aero, Lighting, Etc.) | 6 | 11-26-2014 01:21 PM |
| Rear Bumper removal / bumper latch | SmartedPanda | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 05-01-2014 01:27 PM |
