Old 11-25-2017, 07:01 PM   #29
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Originally Posted by Exrald View Post
Will the 1" size with for our bumper?
I don't see why not. Looks like you'll still need to drill a 3/4" hole in the bumper so that doesn't leave much "wiggle" room since the exposed part of the latch you want to use is only 1".....but if you do it right, you won't need any wiggle room.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Exrald (11-29-2017)
Old 03-07-2018, 12:02 AM   #30
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
With these installed what can you leave off in terms of the original fasteners?
I don't have any sag (yet) but if these make it faster/easier to get the bumper off and on I might as well do it now...going to take it off to respray my lip anyway ><
BRZyJ is offline   Reply With Quote
Old 03-07-2018, 12:38 AM   #31
Brink
Drives: 2017 BRZ
How many times removing the bumper does it generally take before it starts to sag? Only had mine off once so far and it still looks good, wondering if I should plan on getting something like this installed the next time it comes off or if I don't need to worry about it yet.
Brink is offline   Reply With Quote
Old 03-07-2018, 07:41 AM   #32
BirdTRD
Simply Forgotus
BirdTRD's Avatar
I don't think you can get away with leaving any of the stock clips or screws out without things flopping around or creating yet another gap.
The only reason I installed these was to remove the notorious gap. They do not make it faster or easier to remove the bumper in any way. If you don't have the gap, I wouldn't install them.
BRZyJ (03-07-2018)
Old 03-07-2018, 12:14 PM   #33
BRZyJ
BRZyJ's Avatar
Thanks Bird. Bummer...ah well :/
I'll probably need them eventually but I guess I'll sit on it for now.
Old 05-19-2018, 04:23 PM   #34
Leonardo
Country Boy 4 Life
Leonardo's Avatar
USE A STEP BIT!!!
For the bumber and inner plastic.
via Imgflip Meme Generator
I LIKE TIRES!
BirdTRD (05-19-2018)
Old 05-19-2018, 05:45 PM   #35
BirdTRD
Simply Forgotus
BirdTRD's Avatar
USE A STEP BIT!!!
That works too. (Just don't go 1 step too far!) Sharp bits are the real key to success, no matter which type you choose to use.
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
bjac86 (06-06-2018), Leonardo (05-19-2018)
Old 05-19-2018, 06:42 PM   #36
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thats a good point, don't use a drill without variable speed. I used my cordless drill on slow speed 1 with a new bit. It was easy to drill the hole to the correct step.
I LIKE TIRES!
Old 06-06-2018, 01:33 PM   #37
bjac86
Drives: Series. Blue
Awesome write up, worked out great! My bumper tabs were so far gone i needed two for each side
bjac86 is offline   Reply With Quote
The Following 2 Users Say Thank You to bjac86 For This Useful Post:
BirdTRD (06-06-2018), PerCompLLC (10-16-2021)
Old 10-13-2021, 06:55 PM   #38
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
This is great! This is only one quick release were all the others are showing two.
G_Rossney is offline   Reply With Quote
quik latch
DIY - Quik Latch Mini install(front bumper) stevo_12v DIY (Do-It-Yourself) Guides 31 07-20-2018 10:12 AM
DIY: TheRetrofitSource/Morimoto Retro-Quik Install in FR-S civicdrivr DIY (Do-It-Yourself) Guides 236 07-10-2017 12:04 AM
FS: Quik Latch Mini Black Ny Brz Exterior Parts (Aero, Lighting, Etc.) 1 06-22-2015 07:10 PM
FS: WA _Black Anodized Mini Quik-Latches NEW ..Great fix for bumper fitment issues!! glamcem Exterior Parts (Aero, Lighting, Etc.) 6 11-26-2014 01:21 PM
Rear Bumper removal / bumper latch SmartedPanda Cosmetic Modification (Interior/Exterior/Lighting) 3 05-01-2014 01:27 PM
