Old 10-27-2014, 07:16 PM   #1
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
DIY - Quik Latch Mini install(front bumper)
Just finished this install at 6:30am in the morning..
Prep work: Jack up car, remove wheels if necessary, remove weather stripping under the hood, remove screws/clips. Remove screws/clips under the bumper. Remove screws/clips in the wheel arch. All this should be in a previous DIY on this forum
Mask off bumper and fender. Use the small black plastic clip as your mounting point. You want to use the location where the silver phillips self tapper is mounted. Remove the screw. Use a 6.5mm drill and install the threaded part of the QLM.
Mark a line in marker directly above where the mounting point is. Also mark off on the bumper area. Drill a pilot hole to see where the little round point is on the QLM.
Try to center it, once you have found the center, trace a circle using the button part of the QLM.
Use a dremel to remove the excess plastic to fit the QLM button.
The rest of the install should be pretty easy. The tricky part for me was trying to find a decent mounting point for the bolt.
As you can see from the above pics, the front of my bumper now isn't sagging.
stevo_12v is offline   Reply With Quote
Old 10-27-2014, 07:29 PM   #2
vividracing
vividracing's Avatar
By far of the coolest DIY so far! Great addition to the forum!
vividracing is offline   Reply With Quote
Old 10-27-2014, 08:05 PM   #3
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Sweet
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Old 10-29-2014, 01:59 AM   #4
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Where did you buy the part?
Scalzo is offline   Reply With Quote
Old 10-29-2014, 04:03 AM   #5
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@stevo_12v can you give us a close up picture of the stud/stem (the part that is fastened to the black bracket below the fender) with the bumper off?
Fizz is offline   Reply With Quote
Old 10-29-2014, 04:37 AM   #6
nyfries
Drives: 14 FRS Whiteout
Sub
nyfries is offline   Reply With Quote
Old 10-29-2014, 06:23 AM   #7
Foobar
SLO NO MO
Foobar's Avatar
List of parts needed?
Old 10-30-2014, 02:23 PM   #8
stevo_12v
REAR BUMPER Install
Update: Made a start on my rear bumper quick release setup. You need 4x of these. Pics below show you the mounting locations.
Old 10-30-2014, 02:28 PM   #9
PNW FRS
PNW FRS's Avatar
Eyebrows?
What is the purpose of the black plastic "eyebrows?" Do you have a pix of your rig that shows this mod from the front?
Re: Quick Latch... very cool! Ditto on parts list, etc.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 10-30-2014, 03:09 PM   #10
SCHN3LL
Drives: '13 GBS BRZ
Moar downforce brah.
OFT + e85, Borla catback, header soon...
SCHN3LL is offline   Reply With Quote
Old 10-31-2014, 03:12 PM   #11
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
looks great and clean. i am wondering anyone can push and release bumper though. right? i hope it has like locking mechanism key
Old 11-02-2014, 06:37 AM   #12
Foobar
SLO NO MO
Foobar's Avatar
Keep some of the bolts on for security.
Old 11-02-2014, 01:13 PM   #13
D_Thissen
D_Thissen's Avatar
Sub'd. Looks awesome!
Old 11-05-2014, 11:29 AM   #14
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Nice! @mkivsoopra wanna do this?
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
DIY: TheRetrofitSource/Morimoto Retro-Quik Install in FR-S civicdrivr DIY (Do-It-Yourself) Guides 236 07-10-2017 12:04 AM
FS: WA _Black Anodized Mini Quik-Latches NEW ..Great fix for bumper fitment issues!! glamcem Exterior Parts (Aero, Lighting, Etc.) 6 11-26-2014 01:21 PM
re-install Front bumper to headlight gap fix BadBRZ Forced Induction 27 08-19-2014 08:31 PM
Rear Bumper removal / bumper latch SmartedPanda Cosmetic Modification (Interior/Exterior/Lighting) 3 05-01-2014 01:27 PM
iPad Mini Install Xonzo Electronics | Audio | NAV | Infotainment 11 01-24-2014 09:30 AM
