Old 08-15-2015, 09:37 AM   #29
Streetthrowback
Drives: 2015 brz
any update on the price of this badboy?
Streetthrowback is offline   Reply With Quote
Old 08-15-2015, 08:02 PM   #30
jflogerzi
jflogerzi's Avatar
Any numbers like track data?
2013 Series 10 FRS #553
Old 08-19-2015, 02:38 PM   #31
Mishimoto
Drives: 2013 Subaru BRZ
Originally Posted by ahaghshenas View Post
Great looking stuff
Since I had started my build way before your radiator was out I have a koyo rad installed as that was all that was available at the time.
What are the chances that this shroud will work with the koyo rad??
If so interested in the pre sales info
Thanks for the kind words! Assuming the Koyo radiator fits with the factory fan shroud and uses factory-location mounting points, our fan shroud setup should bolt into place just fine.
Coming soon! We will be launching our discounted pre-sale next week!
We do not have any track data for this particular component. It should provide very similar temperatures to the stock shroud during at-speed, track driving. The fans should only activate during long duration idle conditions to regulate fluid temperatures when airflow is not produced by vehicle movement.
-John
Mishimoto is offline   Reply With Quote
Old 08-19-2015, 02:43 PM   #32
xjohnx
Grip>Slip
xjohnx's Avatar
-John
Will they move more air than the stock fans at idle? If so, approximately how much more?
Old 08-19-2015, 03:01 PM   #33
churchx
churchx's Avatar
Drives: 2014 GT86
It's harder to move same amount of air/generate same air pressure for slimmer fans. Though then again nothing is said about their relative rpm-s to stock at specific voltage, they can easily pump as much or more by something as simple as spinning at higher rpms.
But then again .. electrical fans not always work always-on, depending on regulation / coolant temps .. even weeker fan can get same cooling by simply working longer, it's electrically regulated after all, not belt-driven always-on one, where there might be more difference between one pumping more or less air compared to stock. Isn't main focus of this - to free up for FF underbonnet space while cooling 'sufficient'?
Old 08-25-2015, 11:15 AM   #34
Mishimoto
Thanks guys! Church is correct. Our shroud setup produces similar, but not greater, airflow compared to the stock setup. Our idle testing showed that our kit is more than sufficient for keeping the FA cool in long duration idle conditions. The primary goals for this project were to produce a slim fan setup that is aesthetically pleasing and is sufficient for cooling at idle and low speed driving situations. We succeeded in each!
In other news, we should be launching our discounted pre-sale later today!
Thanks
-John
Old 08-25-2015, 11:21 AM   #35
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
If you guys need a turbo car for test fit im in PA! lol.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 08-25-2015, 11:29 AM   #36
Mishimoto
Thanks for the offer! If we are in need of such a vehicle we will certainly reach out!
-John
Old 08-25-2015, 03:26 PM   #37
Mishimoto
Our pre-sale is now live! Check out the details below.
Pre-Sale Link!!
Mishimoto Subaru BRZ / Scion FR-S Performance Aluminum Fan Shroud Kit
Pre-Sale Expiration Date: 9/30/2015
Estimated Ship Date: 9/30/2015
Product Specs
  • Direct plug-n-play for the 2013+ Subaru BRZ / Scion FR-S / Toyota GT86
  • Includes two high-flow 12" fans, each providing over 1150 CFM of airflow
  • Fans are pre-wired with stock-style connectors
  • Fits with both stock and Mishimoto Subaru BRZ / Scion FR-S radiators
  • Accommodates stock coolant overflow tank
  • Slim profile with a maximum thickness of just 3.5"
  • Brushed aluminum finish
  • Includes all mounting hardware for installation
  • Mishimoto Lifetime Warranty
Images
Product R&D
http://engineering.mishimoto.com/?cat=291
Tech Specs
Pre-Sale Link!!
Feel free to follow-up with any questions regarding this kit!
Thanks
-John
The Following User Says Thank You to Mishimoto For This Useful Post:
Sportsguy83 (08-25-2015)
Old 08-25-2015, 05:00 PM   #38
Streetthrowback
Drives: 2015 brz
I clicked on the link but no where it says to add to cart...
Old 08-26-2015, 06:19 AM   #39
Max FRS
Drives: 2015 Halo FRS Automatic
I just went to the Pre-Order site and "Add to Cart" showed up. I have placed my order.
You made it by August as estimated, thanks.
Max FRS is offline   Reply With Quote
Old 08-26-2015, 11:13 AM   #40
Mishimoto
Very strange, it seems to be working fine for us. What browser are you using? Is this on a mobile device? Give the link below a try and let me know what happens.
http://www.mishimoto.com/subaru-brz-...-kit-2013.html
Thanks
Thanks for the order!
-John
Old 08-26-2015, 05:49 PM   #41
Streetthrowback
Drives: 2015 brz
I was able to view it after I posted, thanks, once I get paid this Friday 1st thing is this bad boy!
Old 08-27-2015, 11:13 AM   #42
Mishimoto
Great! Thank you very much!
-John
Can I plug and play this amp? 7thgear Electronics | Audio | NAV | Infotainment 4 04-11-2015 04:26 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-20-2012 11:10 PM
