Old 06-12-2015, 01:08 PM   #1
Mishimoto
Drives: 2013 Subaru BRZ
Mishimoto’s BRZ/FR-S Plug-N-Play Fan Shroud R&D!
Hey guys,
We have re-released this product in black! Check out our commercial ft86 Club thread for more info.
Keeping the twins cool! Mishimoto’s BRZ/FR-S Plug-N-Play Fan Shroud R&D, Part 1: Stock System and Initial Fabrication
Taking a look at our lineup of products for the BRZ/FR-S reveals a solid offering in both cooling performance and power-adding products. Our engineering team has evaluated numerous vehicle systems and provided upgrade components where solutions were needed. Our intake components provide improved induction noise and nice increases in power. Our oil cooler system provides a solution for high oil temperatures on the track. And, our aluminum performance radiator is ideal for track vehicle owners looking for some additional peace of mind during long-duration lapping. These are just a few of the components we currently offer, and we’ve managed to find yet another opportunity to provide an awesome component that will enhance your BRZ/FR-S: a direct-fit fan shroud kit.
Our shroud kits have become more complex over the years for two reasons. First, our engineering team has identified methods for improving performance, aesthetics, and ease of install. We’ve performed extensive testing to ensure that our fan location and shroud thickness are optimal in direct-fit kits. Our team has explored a few uniquely styled shrouds (see BMW E36/E46 shrouds) for improved airflow on the track. And, we’ve started to include stock-like fan plugs, so install is simple and no wiring is required.
Stock shroud design is the second reason our shroud kits have evolved. Many modern fan shrouds double or triple their functions to hold hoses in place, mount expansion tanks, or even function as coolant pathways for transmission coolers. These factors create some additional challenges for our team of engineers. But, would designing automotive components be interesting if they were all simple?
Stock Fan Setup
The stock fan system utilizes dual electric fans mounted to a plastic shroud. This shroud also provides a mounting position for the coolant overflow tank. The stock fans are set to activate at 212°F (100°C), although they will also activate when the AC system is being used. Additionally, the stock fans run on a multispeed system that will need to be incorporated into our design. Below is a look at what you will see once the hood is open on your BRZ or FR-S.
Stock fan shroud
Stock fan shroud
Mishimoto Shroud Plans
We have a few basic goals for this particular product design. First, we want to ensure that this product is easy to install. To achieve this we will be using stock plugs to create an easy, wiring-free installation. We will also be incorporating the stock overflow tank mount into our shroud. This kit will be a full bolt-on replacement unit.
Second, we are looking to achieve optimal airflow and cooling while providing a slim profile. Our electric fans produce a substantial amount of CFM and will be quite suitable for this kit and vehicle.
Shroud Fabrication
After establishing our plans and guidelines, we set out to begin fabrication of our aluminum shroud. We have a talented fabrication staff that pays attention to every detail.
This shroud started life as a flat sheet of aluminum, and our aluminum radiator was used to identify critical shroud mounting points.
Shroud fabrication
Measurements were made and we started mapping out our cuts.
Shroud fabrication
We made a few cuts, bent the edges, and welded our basic shroud shape. The goal was to fit fully with the footprint of the radiator core, which would allow the fans to pull air through the entire surface.
Shroud fabrication
Shroud fabrication
Next we needed to construct mounting tabs that would attach the shroud to the radiator itself. These were crafted from aluminum and tacked into place.
Shroud mounting tab fabrication
We fired up the welder and got to work attaching these mounting points.
Shroud mounting tab welding
The end result is quite nice!
Next we needed to cut holes for the fans and drill holes for the fan mounting hardware. The surface area of the shroud allowed us to use two of our 12” fans, which produce 1,150 CFM each. These fans will have no issues keeping the FA20 cool under any environment or driving situation.
Mounting fans to shroud
Once the locations were selected, we cut the fan holes and drilled our mounting location points.
Fan shroud fabrication
Coming Up!
This shroud prototype is not done yet! We still need to construct mounts for the coolant overflow tank. Check back next time for a look at what we did!
Thanks for reading!
-John
Mishimoto is offline   Reply With Quote
The Following 11 Users Say Thank You to Mishimoto For This Useful Post:
BatStig (06-13-2015), cameronjones239 (06-12-2015), chaoskaze (06-12-2015), DAEMANO (06-12-2015), F1fletch (06-12-2015), FyeaFRS (10-15-2015), Lonewolf (06-12-2015), pcuerpo (06-18-2015), quicksilver30 (06-13-2015), Rybot (07-08-2015), Teclis (06-19-2015)
Old 06-12-2015, 02:37 PM   #2
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Sub'd. I loved my mishimoto radiator and fan shroud for my S13.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 06-12-2015, 03:00 PM   #3
wootwoot
Drives: FRS
Sweet.
wootwoot is offline   Reply With Quote
Old 06-12-2015, 03:22 PM   #4
celek
Resident Gear Head
celek's Avatar
Glad to see this product come to this platform
I am wondering if like your other available shrouds does it fit Factory rad as well as Mishi rads.
Also with the slim fan are you expecting to see space savings over stock
celek is offline   Reply With Quote
Old 06-12-2015, 03:24 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
ha! Love it! Look forward to seeing this in the shop
Old 06-12-2015, 05:15 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Just a thought. Maybe it's better to make shroud not flat but gradually rising from sides & corners till fan? Will make it more difficult and expensive to make though.
Old 06-12-2015, 08:25 PM   #7
Streetthrowback
Drives: 2015 brz
Subscribed
Streetthrowback is offline   Reply With Quote
Old 06-12-2015, 11:14 PM   #8
celek
Resident Gear Head
celek's Avatar
This is the way all the shrouds they make are designed. The trick to a shroud is to seal against the radiator and pull every bit of hot air from every nook and cranny in the corners.
And you are correct angles increases cost and probably not what we want to pay since this piece will be $250 price range.
Old 06-13-2015, 09:55 AM   #9
quicksilver30
quicksilver30's Avatar
Drives: '13 LR BRZ Limited| '07 Jeep GC
I am totally down for this...
'13 Lightning Red BRZ
Mods: Grimmspeed Cold Air Intake|FT86SpeedFactory Stage 2 Tune|FT86SpeedFactory Catted header|Nameless Catted and Resonated OP/DP|Perrin Resonated Cat-back|
quicksilver30 is offline   Reply With Quote
Old 06-15-2015, 05:04 PM   #10
Mishimoto
Thanks!
Originally Posted by wootwoot View Post
Sweet.
Thanks for taking a look!
Great! Correct, this shroud is being designed to function with both stock radiators as well as our aluminum radiator for the BRZ/FR-S!
Yes, we are hoping to save some space on this design. More on this later in the development process.
Thanks Shutter!
Interesting point here! Passing this idea on to our engineering team to see what they think. Based on our previous tests and products, I would have to assume our flat shroud is fairly optimal. Always nice to have new ideas to research and explore. Thanks for the comment!
Originally Posted by Streetthrowback View Post
Subscribed
Thanks for the interest guys!
-John
Old 06-16-2015, 06:48 AM   #11
Max FRS
Drives: 2015 Halo FRS Automatic
Any estimate on when this will be ready for sale? I have the Mishimoto radiator to install but now want to add your fan shroud. It will be worth the wait, looking forward to updates and the final product. Any chance for a pre-sale group buy?
Max
Max FRS is offline   Reply With Quote
Old 06-19-2015, 09:47 AM   #12
Mishimoto
Max
Thanks for the interest! We are still a bit early on in the process to provide a concrete release date. That being said, we do expect these to hit shelves towards the end of August assuming we do not have any major setbacks. We will be running a discounted pre-sale for forum members, so keep an eye out for that once the product is complete.
Thanks for picking up our radiator! Let me know what you think once it is installed!
-John
Old 06-19-2015, 02:09 PM   #13
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Hey guys what benefits would this product have for the stock rad?
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 06-20-2015, 03:06 PM   #14
Max FRS
August, faster that I thought. Whenever the pre-sale starts, sign me up! I also realize August is an estimate. I am going to wait to install my radiator until I get the new shroud.
Can I plug and play this amp? 7thgear Electronics | Audio | NAV | Infotainment 4 04-11-2015 04:26 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-20-2012 11:10 PM
