Old 04-11-2015, 10:22 AM   #1
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Can I plug and play this amp?
This is for an FRS
Last time I touched audio was over a decade ago, so forgive me but I forgot pretty much everything.
Last week my brother sent our venerable VW Golf to the scrap yard and gave me back my amp that I put into it many moons ago. It's a nice amp and i was 100% satisfied with it given my needs.
My question, how easy will it be to plug this baby in place of my OEM one with minimal wiring. I am okay with losing rear speakers. My head unit is OEM. I can solder no problem. I don't plan on doing any other mods.
Just want to boost the power to my front.
Will I be able to use the OEM wires and just splice them? Is there a handy connector I could buy? Will I have to route the power again or can I use the OEM power cable? (I saw a post saying that if it's a BRZ then no good) is 150w too much for OEM?
Old 04-11-2015, 11:06 AM   #2
Chimera
Drives: FRS
The factory amp is rated 15A, that 2.6x is rated 20A. So you could try but you'll may blow fuses. You could plug a 20 in.. But then you risk fire. If you check out the audio directory there's a super good thread on how to use the oem harness,to plug and play. I'd try it out with the 15 fuse and try to under gain. Also maybe get some new door speakers to take advantage of the new amp.
Old 04-11-2015, 03:18 PM   #3
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Here yah go!
How to use OEM wiring:
http://www.ft86club.com/forums/showthread.php?t=42239
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 04-11-2015, 03:48 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by 86geek View Post
Here yah go!
awesome!
so basically pull the relevant pins out, put them into the new amp, and hope the amperage will suffice? (turn down the gain a bit?)
Old 04-11-2015, 04:26 PM   #5
Chimera
Drives: FRS
Even turning the gain down you may blow fuses. Might want to check that it's 2ohm safe too.. I didn't check that. Stocks are 2 ohm.
Motec M1 Plug N Play FullBlown Forced Induction 89 05-09-2014 12:45 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-20-2012 11:10 PM
