#29 | |
Drives: GT86
#30 |
not playing cards
Look at my picture of the custom hockey pucks. That's ok because they compress quite a bit so, even if they pop out, the worst you have is a marred finish on the car. I'm sure there are better, more expensive solutions but I'm into the guerrilla technique because it's part of the fun.
#31 | |
Drives: 2014 BRZ Limited
But this is not that difficult a problem. There are plenty of jack stands made for pinchwelds, plus dozens of pinchweld adapters on the market made from a variety of materials. A Google image search shows how other people have solved the issue. I even saw someone suggest permanently mounting a rail along the pinchweld to provide a flat jacking point. |
#32 |
If it doesn't, you need a low profile jack. I have the giant low-profile hi-rise Harbor Freight jack, and it would have to be pretty damned low for that thing not to fit under it.
#33 | |
Drives: GT86
#34 | |
Drives: GT86
#35 | |
not playing cards
Also, when seated, the puck is compressed enough it just acts like a pad. There's no separation - no place for the car to roll out/off of the spacer. The wood (or cinderblock) can fail without warning at any time. I'm not advocating it as the end-all solution. Just an idea.
#36 |
Drives: GT86
I'm still not understanding how the wood is any different. The wood is pressed in to the cup of the axle stand just like the hockey puck would be - once the weight of the car is on it there is nowhere the wood can go even if it splits.
EDIT: it might help if I show you what my axle stands look like - and the yellow outline is how the wood sits in it If that wood splits, where can it possibly go when it is pressed in to the jack stand by the weight of the car? Last edited by ChrisD; 02-11-2015 at 02:44 PM. |
#37 | |
Drives: GT86
#38 |
Drives: GT86
Also can someone explain to me why we even need to bother with putting the axle stands around the pinch welds at all? I understand that that's where the strengthened part of the car is and that it is intended to be a load bearing part, but that's the bit BEHIND the pinch weld isn't it... not the thin lip of the pinch weld itself. So why can't I just stick an axle stand directly behind the pinch weld on the thick flat part that is actually meant to be load bearing? I must be missing something, but it seems like everyone's solutions involve just making your jack or axle stand miss the pinch weld entirely and just get surface area on the part behind it and in front of it - but the bit in front of the pinch weld doesn't seem strong at all so I assume it is the part behind it that takes all of the load... so why not just stick an axle stand with a flat head on that?
#39 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"I gotta rock." -- Charley Brown |
#40 |
Drives: 2013 FRS- Hot Lava
#41 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#42 | |
| jack stands oil change. | Howardwei | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 04-02-2019 11:45 PM |
| Alignment at home using hub stands.. | diss7 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 06-25-2014 04:52 AM |
| Japanese jack stands? | Augora | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-26-2014 12:59 PM |
| Jacks/stands around central nj? | Reflex | NY / NJ / CT / PA | 9 | 09-13-2013 11:30 AM |
| ramps + jack stands | so26 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 04-23-2013 04:43 PM |
