Old 06-26-2014, 02:34 AM   #29
evan
Drives: fr-s
Thanks for posting the final pics. Car looks amazing!
evan is offline   Reply With Quote
Old 06-26-2014, 02:41 AM   #30
evan
Drives: fr-s
Originally Posted by Snowblind View Post
This would have been a cool modification if I was 13 years old and had just watched the first Fast and Furious movie. You should do some cool neon underglow lights to finish the look.
Maybe you can post pics of some interesting and unique mods you have done to your car? I'd certainly like to know how an adult mods their car.
The Following 2 Users Say Thank You to evan For This Useful Post:
Ammonia (06-27-2014), HyperTech (06-29-2014)
Old 06-26-2014, 05:48 AM   #31
UF Key Master
UF Key Master's Avatar
Drives: 2013 Toyota FRS Ultramarine
Originally Posted by Candlejack View Post
...do the windows still roll up/down when you close/open the doors? O__O
Yes, the windows still drop the small amount upon opening the door. That is one of the reasons why I believe the door will raise in a more vertical travel once I modify the post on the hinge. I don't want to grind it down too much though because if the shock did fail it is this post which would keep the door from dropping straight down.
UF Key Master is offline   Reply With Quote
Old 06-26-2014, 06:58 AM   #32
s2d4
s2d4's Avatar
are there better shock options? it bounces around a fair bit at the end of each movement.
Old 06-26-2014, 07:13 AM   #33
UF Key Master
I don't think it is the shock as much as the instability involved with having only one pivot point. When it is open there is considerable movement which I don't believe can be removed. Unfortunately, this is a structural issue which must be accepted if you want to do this modification. The only time it really bothers me is when I let the door open without keeping hold of it. It will open up with enough force to shake the whole car and bounce around.
The Following User Says Thank You to UF Key Master For This Useful Post:
GT86_PRAGUE (01-07-2015)
Old 06-26-2014, 08:21 AM   #34
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by evan View Post
..and this is how the world condemns free thinkers.
So being a "free thinker" means thinking like the minority? If you find out the majority think the same way you do about something you have to change your opinion to align with the minority? That doesn't sound very free to me. That sounds hipster.
You automatically assume that if someone expresses an opinion that isn't like yours or is like the majority's that they're a lemming?
brianhj is offline   Reply With Quote
Old 06-26-2014, 09:14 AM   #35
Mikem53
Drives: FR-S 6MT
OP... Nicely done! Sharp looking machine!
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
UF Key Master (06-26-2014)
Old 06-26-2014, 09:48 AM   #36
sluflyer06
Drives: 2014 BRZ Ltd - DGM
So its not that vertical doors are flat out bad in my eyes except...
A. Having to open the door normally first makes this entire mod pretty stupid since it accomplishes almost nothing except adding more steps to getting in and out of the car.
B. there is so much play in the movement that it looks like a bad hack.
C. Its really not your vertical doors I hate, its those inner city ghetto bling blang wheels. (I do apologize for being an azz here but man those things just don't jive with the car)
If the doors actually opened vertically like you would imagine they would (like a lambo) I could for sure see the benefits of this.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
The Following User Says Thank You to sluflyer06 For This Useful Post:
meWant (06-30-2014)
Old 06-26-2014, 10:11 AM   #37
UF Key Master
I see your points. I'm working on modifying them to open in a more vertical motion but the play will probably not be able to be reduced. As for my wheels - it may be my age but I love the chrome - different strokes.
Old 06-26-2014, 10:13 AM   #38
sluflyer06
Yea its your car man, at least the stock pads don't dust. Where does the play originate from? The mounts look pretty beefy.
2014 BRZ Ltd. - DGM
E46 323ci vert
Old 06-26-2014, 10:41 AM   #39
UF Key Master
Having only one pivot point, no matter how thick the steel is it will never be firm like the 2 hinge set up of a normal door. It's one of the attributes of this mod which can't be corrected. Like I mentioned earlier, it really only bothers me if I allow the door to raise without holding on to it.
Old 06-26-2014, 11:00 AM   #40
stugray
Drives: 2013 GBS BRZ Limited
Looks great!
This might be a stupid question, but how do you have a FT86 in Fl.?
I understand the rebadging concept, but the OP actually says "FT86" in the 'drives' field in his avatar. If it IS just a rebadge job, then that is a little misleading.
I completely expected to see the location be Australia
Old 06-26-2014, 11:21 AM   #41
UF Key Master
Your right, it was purchased as a Scion. I have since rebadged and purchased everything I could to make it Toyota. I'm the original owner of an '89 MR2 and this car was its' replacement. It just bugged me looking at "Scion" so I changed it. You know - the title actually says Toyota.
Old 06-26-2014, 11:45 AM   #42
J_kennington
Drives: 2013 asphalt scion FRS
I would like them if they could go up after opening it like an inch. Obviously you will always have to swing out before up on any car. But that's waaaay out.
And OP is right btw, a scion frs is titled as
Make: Toyota
Model: scion frs
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
DIY: APR Door Mirror Install RallySport Direct DIY (Do-It-Yourself) Guides 53 04-26-2019 03:08 PM
DiodeDynamics Door LED install Khazzy DIY (Do-It-Yourself) Guides 25 05-09-2014 09:52 PM
Red inside door handle grips how to install? 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 13 03-24-2014 12:21 AM
Selling a Vertical door kit FRS-89 Exterior Parts (Aero, Lighting, Etc.) 0 02-20-2013 02:57 PM
Anyone install door stabilizer? russv Cosmetic Modification (Interior/Exterior/Lighting) 1 08-12-2012 12:08 PM
