Old 06-15-2014, 09:14 PM   #29
onzippy
Drives: 2014 FRS
You need to post a video of whatever "it" is wobbling because now I need to know.
Sent from my SGH-T999 using Tapatalk
onzippy is offline   Reply With Quote
Old 06-15-2014, 10:46 PM   #30
Astroboy
Astroboy's Avatar
Drives: None
Can you pm me an email?.
Astroboy is offline   Reply With Quote
Old 06-15-2014, 11:31 PM   #31
Astroboy
Astroboy's Avatar
Drives: None
Guys I'm almost for certain it's a di failure now because when I start her up with the steering wheel completely to the right, it pops once... On the right side... This is very strange, but when my steering wheel is straight, it doesn't pop at start up..... I noticed the car revs a little bit higher when steering completely to the right or left while in neutral. So I was assuming it was feeling heavy load during start up causing it to pop.. Idk anymore
Old 06-15-2014, 11:32 PM   #32
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Accurate Race Shop View Post
Yeah you can post a video preferably under the hood at idle. That will give me the best idea if it is a misfire.
Sent from my Q10
Can you pm me an email or phone number?
Old 06-15-2014, 11:41 PM   #33
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Pretty hard to diagnose or understand completely such a problem over the net. Why haven't you just taken to a trustworthy mechanic by now? That would yield accurate and immediate answers no??
Old 06-16-2014, 12:02 AM   #34
wheelhaus
wheelhaus's Avatar
This problem will not go away on its own, it needs to be diagnosed FAR more accurately than simple descriptions. We can help only so much, but you need to post a video to youtube or some other video service and link it here if we're going to help further. I'm not an engine/tuning guru, but some of the guys here are and they will need to see a video of the problem before anything constructive will develop.
Or, take it to your shop that did the work, or any shop capable of competently working on your engine. You may need to have it towed, but I wouldn't advise continuing to start/run/drive the engine if something is clearly not working correctly.
Help us help you!
wheelhaus is offline   Reply With Quote
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
Astroboy (06-16-2014), OICU812 (06-16-2014)
Old 06-16-2014, 01:15 AM   #35
OICU812
Just a dude
OICU812's Avatar
Help us help you!
EXACTLY! +1 I would be getting it looked at ASAP, why risk when there are so many variables?
Old 06-16-2014, 09:27 AM   #36
Astroboy
Astroboy's Avatar
Drives: None
maybe because the car is so brand new and not that many people know about this car
Sent from my LG-D800 using Tapatalk
Old 06-16-2014, 09:36 AM   #37
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Yes intermittent misfires almost always return. If it is intermittent it is most likely electrical historically with a subaru it is corrosion or a bad connection in with the plug that goes into the distributor or the distributor it's self.
Sent from my Q10
Where is the distributor on a BRZ?
It seems some folks have had issues with motor mounts being melted, all the exhaust heat is on the passenger side and so are the passenger side motor mounts.
Is the whole car shaking, or is the steering wheel bouncing back and forth.
celica73 is offline   Reply With Quote
The Following User Says Thank You to celica73 For This Useful Post:
Astroboy (10-04-2014)
Old 06-16-2014, 10:17 AM   #38
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
What they are getting at is that if there is an engine issue and it decides to throw a rod your engine is not under warranty because you are boosted. Granted in relation to a lot of other motors all of the boxer engines are pretty cheap but you are still looking at around $6,000 for a short block with install. Getting it looked at to see if it is something simple or something major should be the first step. If the engine is shaking like crazy while at idle you are most likely mis-firing. Because it's intermittent I would guess it's electrical or an issue with the tune on the car.
Sent from my Q10
Old 06-16-2014, 11:51 AM   #39
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Sent from my Q10
You can get a long block for 3K or less, then pay a reputable shop around $1K to swap bad motor with said long block.
Old 06-16-2014, 12:01 PM   #40
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Since your're local you can try taking it to AWDTuning in Flower Mound or give them a call. I know some of the Dallas peeps on here don't like them for certain reasons. But they are Subaru pros and they have been working on a lot of boosted twins lately.
Powerhouse Racing might be able to look at it as well.
JonAvalon is offline   Reply With Quote
Old 06-16-2014, 12:17 PM   #41
Accurate Race Shop
Drives: Scion FR-S
Your right I was thinking prices from the built motors. Which run around $5k.
Sent from my Q10
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
Sportsguy83 (06-16-2014)
Old 06-16-2014, 03:47 PM   #42
Astroboy
Astroboy's Avatar
Drives: None
how much would they charge for diagnosing?
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Ugh! Car won't start :( FRSGIRL❤ CANADA 53 05-10-2013 04:52 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Tad's CBS BRZ From The Start Tad_07 Member's Car Journals 8 10-12-2012 02:19 AM
