#29 |
Haha, yeah I couldn't wait to get it in.
![]() And with the Grimmspeed cover on ![]() Can't even tell it's there! I still have 91oct in the tank but 10PSI feels awesome. I find you really notice the additional power in the top end. I love it
#30 |
MAP sensor in
![]() Clamping down the bastard evap lines. AC Compressor and throttle body out
#31 |
Drives: White FR-S
Did you lengthen the wires on the boost controller or did it come like that? Mine looks a bit different and the wires are only 2" long.
#32 |
That's a different one. Mine came with a long wiring harness. Seemed perfect length to mount it at the front. Shouldn't be hard to lengthen... I would take longer wires over long vacuum hose
Sent from my HTC One using Tapatalk
#33 |
Picked up an external mic for my go pro and decided to snag some turbo noise
[ame="http://www.youtube.com/watch?v=Ulq1KZjWW4o"]Turbo Noises External Mic - YouTube[/ame]
#34 |
Drives: White FR-S
The turbo sounds so good when you're on it in a high gear.
![]() I noticed you're getting compressor surge on the street though. Have you thought about loosening the adjustment screw on your BOV? |
#35 |
Yeah I noticed that too. The BOV is the AVO 50/50 unit, so I wasn't sure if it was adjustable. I'll take a look tonight. It only flutters at low boost, so I wasn't overly concerned
#36 |
Drives: White FR-S
Are you getting 11psi or maybe a little over or under? I read the value from the ECU and find I get 10psi on my 11 map. Trying to figure out if it's simply a tune calibration issue or if I have a leak. I haven't found any loose hoses.
#37 |
I'm getting about 1psi less than I should be on all my maps, which I'm guessing is due to my leaking header gaskets. Hope to have that resolved through AVO asap
#38 |
Drives: 2013 Raven FRS MT
Nice set up, sound, and performance! And love your 4 runner. BF Goodrich tires are always a nice addition.
#39 | |
Drives: White FR-S
My base map doesn't use the boost controller as far as I know. I have the 6psi actuator and find the boost is really closer to 5. My theory is that Bill's duty cycles are based off what the spring pressure is supposed to be, so if it's low, all the targets end up being low. Which gaskets did you use btw? |
#40 | |
I'm on my 2nd set. The first ones were Grimmspeeds and now I'm using OEM.
#41 |
Some new updates:
Ordered front and rear control arms from Buddy Club ![]() ![]() Also did a fresh oil change with another round of Motul 300v 0w20, Installed a Full Blown Motorsports Oil Cooler ![]() New lug nuts ![]() ![]() I also installed an auto-dimming home link mirror from Subaru, and ordered Perrin lightweight water pump and alternator pulleys. So much to do!
#42 |
Ridge Racerrrrrrrrr
Have you confirmed your waste-gate is set up properly? Pre-load could be off (accounting for the 6 on your map 1)
| Boosted's BRZ | Boosted | Member's Car Journals | 41 | 11-05-2018 09:32 PM |
| what oil are you boosted guys using | sid3way5 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 69 | 03-19-2014 09:01 AM |
| Boosted BRZ | mike the snake | Member's Car Journals | 3 | 12-28-2013 11:11 AM |
| RIP Boosted BRZ & Driver | ft_sjo | BRZ First-Gen (2012+) — General Topics | 103 | 11-17-2013 10:07 PM |
| AU Boosted club | nix | AUSTRALIA | 18 | 01-19-2013 12:50 AM |
