Old 05-13-2014, 01:12 PM   #29
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Haha, yeah I couldn't wait to get it in.
And with the Grimmspeed cover on
Can't even tell it's there!
I still have 91oct in the tank but 10PSI feels awesome. I find you really notice the additional power in the top end. I love it
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Draco_PR23 (05-22-2014)
Old 05-13-2014, 01:16 PM   #30
protpibe
protpibe's Avatar
MAP sensor in
Clamping down the bastard evap lines. AC Compressor and throttle body out
Old 05-18-2014, 02:30 PM   #31
qtwre
Drives: White FR-S
Did you lengthen the wires on the boost controller or did it come like that? Mine looks a bit different and the wires are only 2" long.
qtwre is offline   Reply With Quote
Old 05-18-2014, 03:10 PM   #32
protpibe
protpibe's Avatar
That's a different one. Mine came with a long wiring harness. Seemed perfect length to mount it at the front. Shouldn't be hard to lengthen... I would take longer wires over long vacuum hose
Sent from my HTC One using Tapatalk
Old 05-19-2014, 10:34 AM   #33
protpibe
protpibe's Avatar
Picked up an external mic for my go pro and decided to snag some turbo noise
[ame="http://www.youtube.com/watch?v=Ulq1KZjWW4o"]Turbo Noises External Mic - YouTube[/ame]
Old 05-19-2014, 10:48 AM   #34
qtwre
Drives: White FR-S
The turbo sounds so good when you're on it in a high gear.
I noticed you're getting compressor surge on the street though. Have you thought about loosening the adjustment screw on your BOV?
Old 05-19-2014, 10:54 AM   #35
protpibe
protpibe's Avatar
Yeah I noticed that too. The BOV is the AVO 50/50 unit, so I wasn't sure if it was adjustable. I'll take a look tonight. It only flutters at low boost, so I wasn't overly concerned
Old 05-25-2014, 01:19 PM   #36
qtwre
Drives: White FR-S
Are you getting 11psi or maybe a little over or under? I read the value from the ECU and find I get 10psi on my 11 map. Trying to figure out if it's simply a tune calibration issue or if I have a leak. I haven't found any loose hoses.
Old 05-25-2014, 10:20 PM   #37
protpibe
protpibe's Avatar
I'm getting about 1psi less than I should be on all my maps, which I'm guessing is due to my leaking header gaskets. Hope to have that resolved through AVO asap
Old 05-25-2014, 10:37 PM   #38
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Nice set up, sound, and performance! And love your 4 runner. BF Goodrich tires are always a nice addition.
AVodka14 is offline   Reply With Quote
Old 05-26-2014, 08:22 AM   #39
qtwre
Drives: White FR-S
Hmm, so you're saying your 11psi is more like 10, and your 9 is 8? I wouldn't think it's a problem with a leak because if you can do 10, the 9 should be spot on.
My base map doesn't use the boost controller as far as I know. I have the 6psi actuator and find the boost is really closer to 5. My theory is that Bill's duty cycles are based off what the spring pressure is supposed to be, so if it's low, all the targets end up being low.
Which gaskets did you use btw?
Old 05-26-2014, 09:30 AM   #40
protpibe
protpibe's Avatar
The reason I thought that is because my waste gate is set at 7psi and I'm hitting 6 or so on map 1. I'll find out once AVO gets back to me on a fix for my header (hoping a replacement)
I'm on my 2nd set. The first ones were Grimmspeeds and now I'm using OEM.
Old 06-04-2014, 02:39 AM   #41
protpibe
protpibe's Avatar
Some new updates:
Ordered front and rear control arms from Buddy Club
Also did a fresh oil change with another round of Motul 300v 0w20, Installed a Full Blown Motorsports Oil Cooler
New lug nuts
I also installed an auto-dimming home link mirror from Subaru, and ordered Perrin lightweight water pump and alternator pulleys.
So much to do!
SkAsphalt (06-04-2014)
Old 06-04-2014, 03:54 PM   #42
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Have you confirmed your waste-gate is set up properly? Pre-load could be off (accounting for the 6 on your map 1)
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
what oil are you boosted guys using sid3way5 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 69 03-19-2014 09:01 AM
Boosted BRZ mike the snake Member's Car Journals 3 12-28-2013 11:11 AM
RIP Boosted BRZ & Driver ft_sjo BRZ First-Gen (2012+) — General Topics 103 11-17-2013 10:07 PM
AU Boosted club nix AUSTRALIA 18 01-19-2013 12:50 AM
