#29 | |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#30 |
Drives: 2013 Brz sport-tech
i had a invidia resonated frontpipe, with my overpipe and catless uel header(jdl) i also have a borla catback which i love it has no rasp just brute sound. i wanted to quiet it down a bit and remove the stench because catless does stink, i went with a custom frontpipe that used a 200cell Vibrant HFC, the car got louder, it droned like mad too, the frequencys that the resonator removed were the droney ones i quess, there was no difference in power and the logs were the same, i got headahes from the drone and the car was stupid loud, so i went back to my stock frontpipe, the car has a beautiful exhaust note now , no drone, much more quiet and to my supprise pulls alot harder from 3000-5000 before it felt a little dead, althouth i have a great tune, but that is prob because of back pressure , a lack of to be exact. im very happy now with my setup i couldnt ask for a better exhaust note, and now that i solved my gas problem my car runs super strong. when i went back to stock front pipe it did go lean a bit at in that range where it pulls harder and it knocked a bit but got that dialed out easy from my tuner.
#31 |
i highly recomend if you have catless header, dont even change the frontpipe unless you have a very quiet exhaust, i had a greddy spelite and with my catless setup it rasp like mad it was embarassing. then my borla didnt rasp but was way loud, so i think that you have to either keep the oem header or frontpipe , or else it will be either too loud , or sound like garbage with a rasp. it sounded like slapping steel sheets together , it was gross, cold starts were horrific.
#32 | |
Go-Kart Enthusiast
FRS
#33 |
humm my guess is that youll get alot of rasp. its gonna rasp bad with that kind of muffler. i know when i put my overpipe it made it louder too. it made the cold starts rasp way more. maybe tho with the OFH it wont be as bad as my JDL, maybe the invidia resonated frontpipe would be better for you, i know for me it was quieter and keept down drone compared to hfc
#34 |
Drives: 2013 Raven FR-S
Do you have any idea the piping size? Looked and couldn't find it listed. It's supposed to be an OEM replacement so idk if that means same piping size too?
Edit: read your build thread Sent from my HTC One using Tapatalk
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
#35 | |
Drives: Yes
Was tempted to drop another couple bills on a HFC 2.5" front pipe but good to know I'm not the only one who thinks the stock front pipe is decent.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#36 | ||
aeiou
Drives: WRB BRZ
I was going to get the FT86SF catted UEL but the wait and cost turned me away. I'm going with a quiet catback (Corsa), the Magnaflow catted and resonated FP and gonna get a 2.5" OP and the OFH. Should sound really good. Just broscience, no proof behind it... but I think when the pipe diameter is uniform throughout, it generally sounds better.
#37 | |
Drives: Yes
![]() What I have now is: Header post-cat 2.5" > OP 2.5" > FP + cat ~2.118" > Catback 2.5" I would think that the cat in the FP makes the diameter kind of trivial since flow is already disrupted anyway?
| Gutting out the stock cats | diss7 | Engine, Exhaust, Transmission | 90 | 04-02-2018 12:57 AM |
| Just replacing the stock cats? | brillo | Engine, Exhaust, Transmission | 4 | 07-08-2015 11:12 AM |
| OEM cats only ? | 350matt | Engine, Exhaust, Transmission | 7 | 11-26-2013 07:30 PM |
| I giggled... Cats have it made | seven | Off-Topic Lounge [WARNING: NO POLITICS] | 51 | 12-21-2012 03:46 PM |
| Speed cats (or other driving shoes) | Symbiont | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 06-14-2012 11:10 PM |
