Old 04-06-2014, 08:48 PM   #29
onzippy
Drives: 2014 FRS
Direction of coolant flow through the turbo housing doesn't matter.
Whatever lets the hoses fit best for you.
onzippy is offline   Reply With Quote
The Following 2 Users Say Thank You to onzippy For This Useful Post:
Astroboy (04-06-2014), ZionsWrath (04-08-2014)
Old 04-06-2014, 09:24 PM   #30
Astroboy
Astroboy's Avatar
Drives: None
Really? Is yours already running or are you in the process of installing it to?
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
The Following User Says Thank You to Astroboy For This Useful Post:
Old 04-06-2014, 09:25 PM   #31
Astroboy
Astroboy's Avatar
Drives: None
I just find it kind of odd but ok. Thanks ALOT!!
Old 04-06-2014, 09:34 PM   #32
onzippy
Drives: 2014 FRS
Just went through the install three weekends ago; and it runs like a solid diet of taco bell burritos.
If it wasn't mentioned already, check all the bolts, nuts and alignment on everything that came pre-assembled from AVO. I'm sure you notices as you went through the parts list that some of it was already installed. That doesn't mean it is tight. just fyi.
Old 04-06-2014, 09:48 PM   #33
Astroboy
Astroboy's Avatar
Drives: None
Ok and how about this? If I don't have the breather can I just cover it with something? Or must I have a breather to run the turbo?
Old 04-06-2014, 09:48 PM   #34
Astroboy
Astroboy's Avatar
Drives: None
Old 04-06-2014, 10:02 PM   #35
onzippy
Drives: 2014 FRS
There should have been a long hose that came with the kit for the breather. I don't have the catch can yet so I put a little breather filter on it for now. (or zip tie a rag if you want to go for a quick ride).
Game of Thrones in five minutes.. I'm out..
The Following User Says Thank You to onzippy For This Useful Post:
Old 04-07-2014, 01:26 PM   #36
Astroboy
Astroboy's Avatar
Drives: None
Ok was the ago turbo kit suppose to come with a bbov
Old 04-07-2014, 02:36 PM   #37
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by protpibe View Post
The only thing I've seen is that it's listed as an AVO 18/49 Turbo. I'm assuming 49 is the trim since it's not exactly known for it's giant power numbers? edit; Or maybe the a/r? I have no idea, just speculating lol
Originally Posted by dwx View Post
It's pretty much a standard 7cm TD05-18G turbo. So it's larger than a VF39.
^ This...
Yeah it really doesn't matter.
The BOV is additional to the kit as far as I know.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Astroboy (04-08-2014), ZionsWrath (04-08-2014)
Old 04-08-2014, 12:57 PM   #38
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Sportsguy83 View Post
^ This...
So I don't really need one asap correct? I can just plug the tube that connects to the air box with a plug correct? As well with the tube that connects with the throttle body? Also must I have a boost guage? And how do I find out what psi the turbo is set to? This is my first turbo installation so sorry if I'm starting to annoy anybody, its just that I don't want this engine to blow fail on me
Old 04-08-2014, 12:59 PM   #39
protpibe
protpibe's Avatar
You can just cap the bov ends, but if you go up past the 5psi base, you'll want to get one. AVO makes an OEM style recirc BOV which is a minimum imo, but you can just cap the two ends (don't attach them)
You dont need a boost gauge but I would recommend it. I suggest an aem failsafe so you have boost and afr in one spot , and will be able to see 2 critical bits of data to prevent blowing up your engine
Sent from my HTC One using Tapatalk
The Following User Says Thank You to protpibe For This Useful Post:
Old 04-08-2014, 01:00 PM   #40
protpibe
protpibe's Avatar
Sorry, double post
Old 04-08-2014, 01:00 PM   #41
Sportsguy83
Drives: Limited BRZ
Boost AND AFR gauge are a must IMHHO.
You can't just plumb those lines, you will make a mess of boost/vacuum. (Protpibe is correct, I personally would just not use the kit without a BOV or recirculating valve).
Either purchase AVO's BOV or the generic recirculating valve (Both are on the AVO page for sale).
The PSI is dictated by the WG spring. What kit did you get, stage 1 or 2?
Old 04-08-2014, 01:46 PM   #42
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
So the AVO kit can be purchased without even a BPV?
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 11:58 PM
Installing a hood for the fr-s? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-16-2013 12:06 PM
installing harness andrew5826 Cosmetic Modification (Interior/Exterior/Lighting) 16 07-25-2013 11:41 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 02:17 PM
tips for installing amp and sub brichard0625 Electronics | Audio | NAV | Infotainment 4 05-19-2013 08:25 AM
