Old 09-20-2015, 07:54 PM   #29
Reflex
Drives: Whiteout FR-S
Originally Posted by Brzeph View Post
Look in the passenger footwell. Follow the carpet up towards under the dash until you find the edge. Near the edge, on the right side (i.e, on the side of the carpet near the door, not the center console), there is a little black plastic screw cap. Unscrew it and pull the carpet back. You'll see some white sytrofoam looking stuff, move that out of the way carefully. This exposes the AC drain hose. Pull it out of the floor, follow it up under the dash to the other end and pull it off. Take it outside, blow through it hard, and then reassemble.
If you can't get it, I'll make a video tomorrow.
Followed your instructions and figured it out! After removing the top part of the tube, I had probably a quarter of a bottle water worth of water run out. Haven't started the car yet or had AC on but hopefully the issue is solved.
Reflex is offline   Reply With Quote
Old 09-20-2015, 07:55 PM   #30
Brzeph
Drives: '13 BRZ DGM 6MT
Haha glad it worked- I guess I should ammend my instructions to say "have a towel ready"
Brzeph is offline   Reply With Quote
The Following 4 Users Say Thank You to Brzeph For This Useful Post:
DocWalt (09-20-2015), jcw99 (06-26-2016), PerCompLLC (08-22-2018), Reflex (09-21-2015)
Old 03-28-2019, 05:43 PM   #31
csol
My carpet is also stained. Is it replaceable under warranty?
csol is offline   Reply With Quote
Water leaking inside the trunk mashal Issues | Warranty | Recalls / TSB 5 03-04-2016 11:00 PM
Clear side markers.. No water please! ikkomaji22 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-04-2014 03:10 PM
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 05:46 AM
I found a place to make water and soil into the car inside ladios Issues | Warranty | Recalls / TSB 6 02-04-2013 10:11 AM
Water inside the car? YourFearlessLeader Issues | Warranty | Recalls / TSB 10 12-16-2012 05:55 PM
