Old 02-06-2014, 01:35 PM   #29
OrbitalEllipses
Drives: Attitude
I've heard this valve springs thing before - from someone that built their engine. @CSG Mike what's your reference point? You guys popped two blocks, but where are you coming from in saying the valve springs are scary, nomsayin'?
Old 02-06-2014, 01:38 PM   #30
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I find it hard to believe that the OEMs would make a valve spring that wouldn't work with an extra 600 RPM in this day and age. I have yet to hear of anyone breaking a valve spring or floating a valve on this motor.
Old 02-06-2014, 01:40 PM   #31
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Those with 240 wbhp wish they had more, like closer to 300 wbhp?
Originally Posted by jamesm View Post
Supercharger torque curve looks like a horsepower curve. Sure it may make decent peak power, but area under the curve is far more important in real life.
So wait, ESC torque curves look pretty damn flat after 2500rpm. My concern used to be the battery recharge. Educate me, what am I missing?
I'm as skeptical about supercharger torque curve as anyone, and I'm especially skeptical of the ESC, but I don't understand why the graphs and the commentary differs. I need to learn more!
(Also, I can dig the pick a gear argument. I like that idea too -- maybe I've just been thinking about my ideal boost the wrong way)
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 02-06-2014, 01:50 PM   #32
mrk1
Drives: Sterling BRZ Ltd
Rather than peak power, we'll be focusing on increasing the overall powerband
but but then how do I brag from my bar stool?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-06-2014, 01:57 PM   #33
Sounds like a challenge. Wish I still had my car so I could accept it. Perhaps I will get to run some laps in James or David's car one day. I can't wait to hear why it couldn't sustain that power over the course of a single lap like most time attack guys do. The only thing linear in that dyno plot is the torque and boost plot, definitely not the horsepower curve.
Easy. Do 10 back to back pulls on the dyno, hood closed.
Old 02-06-2014, 01:58 PM   #34
We may have purchased a single OEM spring to test the rate... we were going to increase our redline until we had it in our hands.
Remember, we come from Honda backgrounds... we like high redlines.
Old 02-06-2014, 02:02 PM   #35
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I don't know that that is the best way to replicate a single lap of a track no matter how good the dyno fans are. I am willing to bet a supercharger will lose power in that situation as well.
Old 02-06-2014, 02:08 PM   #36
jamesm
i'm not talking about the esc... talking about the centrifugals. the electric supercharger has crazy area under the curve... very good in that regard.
The Following User Says Thank You to jamesm For This Useful Post:
enwave (02-06-2014)
Old 02-06-2014, 02:12 PM   #37
Challenge accepted
Remember, SC's don't have a turbo's hotside that's radiating heat everywhere, even with coatings and blankets.
Old 02-06-2014, 02:21 PM   #38
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Challenge accepted
True, but compressing air still generates heat regardless of how it is accomplished hence the oil feed system on that kit.
Old 02-06-2014, 02:34 PM   #39
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Mike we would have given you the information about the springs as we have posted about the poor spring which are in the FA20. We found they have an install pressure of 35 lbs and at .005 lift it was 55 lbs. The rocker designs in similar to the 2AZ motor. However we have some advantages over the 2AZ uses a hydraulic lifter and the rocker arm has a slightly smaller pocket for the valve lash cap and lifter. The FA20 uses a solid lifter and the rocker that has a touch deeper slotting. We meet with Papadakis Racing last week and compared the 2AZ stock part, their upgraded 2AZ kit and the FA20 parts. At this time the best solution to control the rocker is to upgrade the springs as we have already done.
DAMotorsports is offline   Reply With Quote
The Following User Says Thank You to DAMotorsports For This Useful Post:
CSG Mike (02-06-2014)
Old 02-06-2014, 02:38 PM   #40
enwave
enwave's Avatar
Got it. I mentally merged your comment with Victor's. Victor saying that ESC wasn't going to be linear and then you talking about supercharger curves confused me. Shoulda quoted Victor in my question.
My primary concern still remains charge. The graphs are pretty dreamy.
Thanks man!
The Following User Says Thank You to enwave For This Useful Post:
jamesm (02-06-2014)
Old 02-06-2014, 02:50 PM   #41
Compressing air vs compressing (more) air and dealing with radiant heat... :p
Old 02-06-2014, 03:04 PM   #42
nelsmar
Originally Posted by LBC Por Siempre View Post
By the way this is a little off topic but does anyone know how much a typical Super Charger takes away from the motor, robs - steals to take from the engine to make the extra power. After all Super Chargers are are parasitic And they require a bit of power from the engine to make power.
c
This is semi-debateable. There is a lot more involved than people think. I made 360WHP @ 11.5PSI @ 7400RPM on my car with a bad tune on E85 on a low reading dyno. I just did a baseline dyno of a stock car with only a drop in filter installed and he put down 137WHP. Look at other cars running a 100% stock exhaust setup at that PSI on a turbo and you will see similar results. On a centrifugal supercharger the loss isn't as bad as people think.
My flickr - Canibeat
Local magazine scout
Has anyone taken a closer look at the gas pedal? smbstyle Engine, Exhaust, Transmission 14 04-28-2017 02:59 PM
A closer look at the optional Aero kit BenArmstrong Cosmetic Modification (Interior/Exterior/Lighting) 11 07-17-2013 06:50 PM
A closer look at the Volk and Project Mu FR-S ShowstoppersUSA FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-16-2012 10:39 AM
HKS Supercharger getting closer gtauto AUSTRALIA 166 09-03-2012 07:11 PM
Speed hunters first drive and closer look reviews (with photos of modded blue TRD 86) Spaceywilly Scion FR-S / Toyota 86 GT86 General Forum 19 11-28-2011 10:41 PM
