Old 06-04-2013, 09:25 PM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Has anyone taken a closer look at the gas pedal?
So I was installing my Cusco gas pedal tonight, I followed this great DIY that took 2 seconds to remove the OEM gas pedal assembly out in order to easily install the Cusco pedal:
http://www.ft86club.com/forums/showthread.php?t=36203
Pedal comes out with 2 bolts and a quick un-plug of a wire:
Anyways, when playing with the pedal out of the car, and giving it a closer look, I noticed that the opening that the pedal shaft comes out of, down to the actual pedal, the pedal sits at the top in resting position, and I am able to completely depress it all the way to the bottom point; it travels the entire range of the opening.
However, after re-installing the pedal, I noticed it only travels about 90% of the range in the opening before hitting the stopper behind the pedal attached to the carpet, and not the full range like I was able to get with the pedal out of the car.
Maybe I'm just thinking of the mindset of a cable type throttle; in which case you would only be giving it 90% throttle if not able to fully depress it, but does anyone with more knowledge of this drive by wire system know if this is significant at all, that you can only travel 90% of the range in the gas pedal?
Sorry for the stupid random question; just thought it was interesting, and it was my first time ever really looking over a throttle by wire pedal out of the car.
smbstyle is offline   Reply With Quote
Old 06-04-2013, 09:38 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Interesting find. Reminds me of this post where they were doing some measurements with the car hooked up to a computer and noticed that at full throttle depress it was only registering 80% throttle open in the ECU.
http://www.ft86club.com/forums/showthread.php?t=34629
Originally Posted by humfrz
I'm old and lazy
Old 06-04-2013, 09:43 PM   #3
ramiram1984
Drives: 2016 STi DGM
Cruise control purposes?
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 06-04-2013, 09:43 PM   #4
smbstyle
smbstyle's Avatar
Im wondering if it's just a reliability issue for the pedal mechanism itself; as it is a plastic unit, and continuous pounding against the bottom part of the mechanism at 100% of the range could cause some issues.
Old 06-05-2013, 01:26 AM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I know a lot of cars are like this, ie, my neon Srt4 would show 15-20% at idle and 80ish% at WOT
Old 06-05-2013, 01:43 AM   #6
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
I'm very interested in what comes of this thread!
BlueSTaR is offline   Reply With Quote
Old 06-05-2013, 01:44 AM   #7
wootwoot
Drives: FRS
+100hp for the win!
wootwoot is offline   Reply With Quote
Old 06-05-2013, 01:57 AM   #8
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
Sounds like this could be easily fixed with my "raise gas pedal" mod. Put spacers underneath the gas pedal assembly on the two threads for the nuts. See if that fixes the problem.
I raised both gas pedals on my two FRSs ~1cm or more so that I could make heel-toe a bit easier.
TyperRspec789 is offline   Reply With Quote
Old 06-05-2013, 01:58 AM   #9
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
It's cool to see your thread being quoted!!!
That is the point of the forum! Now get to work a figure out how to install something else so we can all benefit :happy0180:
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 06-05-2013, 02:06 AM   #10
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
This is probably exactly it. Since the mapping between pedal position->torque requested->throttle blade position is all done in the ECU, there wouldn't be much benefit to using 100% of the range of the mechanism anyways.
FrX is offline   Reply With Quote
Old 06-05-2013, 05:45 AM   #11
Anban
Anban's Avatar
Drives: Red high Spec 86
Hi..Adjusting the pedal makes no difference..The electronics limit the WOT to 8X%..
I saw this and spaced the pedal...travel was physically longer but torque still showed same WOT percentage... :-(
Anban is offline   Reply With Quote
Old 06-05-2013, 05:46 AM   #12
Anban
Anban's Avatar
Torque as in Torque App
Old 06-05-2013, 07:35 AM   #13
mad_sb
Drives: 2013 Asphalt FR-S
^This
It's drive by wire folks the ecu controls the throttle angle request based on the accelerator angle. After an ecu reset the ecu compares the readings of both sets of sensors (two tps and 2 app i believe) as you drive to determine the maximum pedal travel. This is why you loose throttle response for a few day after an ecu reset.
In short you can re map the drive by wire so you get max throttle angle (82 degrees in the midrange with a smooth taper to 79 degrees at redline) at 10% accelerator pedal position if you want to.. though i see no reason why you would.
No harm in asking and poking at it, but sadly it won't make any difference in how far the throttle plate opens.
Old 06-05-2013, 08:56 AM   #14
Mikem53
Drives: FR-S 6MT
A simple test since its DBW, Im sure they compensate for position.. But you can turn the ignition on, floor it and look in the TB to see the position of the throttle plate.
Mikem53 is offline   Reply With Quote
A closer look at the Volk and Project Mu FR-S ShowstoppersUSA FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-16-2012 10:39 AM
HKS Supercharger getting closer gtauto AUSTRALIA 166 09-03-2012 07:11 PM
Gas pedal tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-22-2012 09:42 AM
Speed hunters first drive and closer look reviews (with photos of modded blue TRD 86) Spaceywilly Scion FR-S / Toyota 86 GT86 General Forum 19 11-28-2011 10:41 PM
Speedhunters Review "A Closer Look" blur Scion FR-S / Toyota 86 GT86 General Forum 17 11-28-2011 07:07 PM
