Old 01-28-2014, 01:24 PM   #29
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Yeah a tubro is one of the worlds most awesome mufflers. They are just so expensive
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-28-2014, 04:46 PM   #30
humfrz
Originally Posted by carma143 View Post
Would the 4 inch or 5 inch muffler be preferred? It's only a $10 difference but if there was an advantage over the other I would like to know.
Also, would I need to tune my car after the installation?
If you are not going with future power mods (FI), I would recommend the 2.5" piping. If you're going to be spending a considerable amount of time driving your car (DD and/or long hauls), I would recommend the 5" mufflers.
I don't believe a different tune is necessary.
Any power gain is probably more a function of your ear dyno rather than your butt dyno.
However, my axle back muffler along with my K&N drop in air filter, gives me a perceived (at least), modest power increase.......
[ame]http://youtu.be/WX0XJIJQ4xs[/ame]
Old 01-28-2014, 05:01 PM   #31
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
Originally Posted by FrsDuke View Post
Compromise
http://shop.namelessperformance.com/...ed-track-pipe/
I love my track pipe, but worry how loud it'll be once I get my header.
It'll be too loud with any other exhaust mods more than likely. If you are only changing the stock muffler to the track pipe it isn't bad at all. Cold starts are the loudest and it's loud, but only momentarily. There is a drone at around 2k RPM. I've been DD'ing it now for a month and it hasn't bothered me or my passenger at all.
I went with one because I won't be doing any engine/exhaust mods for the next year and it was a cheap option for a good sound, good look, and weight reduction.
GTHachiRoku is offline   Reply With Quote
Old 01-28-2014, 05:38 PM   #32
FrsDuke
Fanboy
FrsDuke's Avatar
Yeah I've been running mine for 18 months or so, and the exhaust has kinda cooked in I guess. More mellow much less drone than I had initially. I am prepared for the header to make it unbearable, which is one reason I kept my stock axleback.
TL;DR:
-Duke
Old 01-28-2014, 06:49 PM   #33
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Alright. I've decided to go with the Nameless axleback 2.5'' exhaust with a 5" muffler.
If it worth it to get the Nameless exhaust brushes(the rings that hold the exhaust pipes in place). And if so, should I just buy 2?
Edit: Also wondering about jack sands that can withstand the weight of the BRZ fully off the ground. Dont want it buckling over when I'm under it.
carma143 is offline   Reply With Quote
Old 01-28-2014, 06:52 PM   #34
carma143
carma143's Avatar
Any power gain is probably more a function of your ear dyno rather that your butt dyno.
So your saying that if I want to install, let's say, an intake sometime in the future then I shouldn't get 2.5"?
Old 01-28-2014, 07:15 PM   #35
humfrz
Sorry for not being clear. What I meant was that if in the future you might be going with a supercharger or turbocharger you would want to consider a 3" exhaust.
A simple air intake modification would NOT call for a larger exhaust.
The stock rubber hangers work just fine for non race situations. No need to replace them.
It's not necessary to jack the car up to replace the axle back muffler, although it would make it a bit easier.
OR, you can do it the "humfrz" way. Toss the muffler in the trunk, drive up to the muffler/auto shop, have a cup of coffee and they will have it on before you finish your first cup of coffee. Pay them about $30 and you don't get your knuckles skinned up, your back sore, your elbow twisted, stuff in your eye, WD-40 all over your hands, ...... and you will have time for a nap .....
Old 01-28-2014, 07:26 PM   #36
humfrz
Well, I figure, since the car is relatively light, just about any store bought jack stands (properly placed) will hold it up.
However, having said that, I don't trust any jacks or jack stands .... completely. I always back them up with a cement block and pieces of 4"x4" .....
Old 01-28-2014, 07:44 PM   #37
carma143
carma143's Avatar
I'm the kind of guy that likes to do everything manually.
Glad you cleared my confusion about the 2.5"
Old 01-28-2014, 08:18 PM   #38
humfrz
OK, if you're going to install that muffler yourself, here are some hints:
Spray the two nuts with something like WD-40 and let it set for a few minutes.
Spray the rubber hangars with soapy water. After you have removed the two bolts, "swing" the old muffler on the rubber hangars to work the soapy water under them.
Be careful with getting the gasket off the old muffler/mid pipe, because you won't be supplied with a new one.
There ya go ....... sports car sound ..... and the tips are perty .....
Old 01-28-2014, 08:48 PM   #39
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
I've got the nameless track pipe. I really don't think it's that loud at all. I also have the nameless frontpipe w/ resonator that is going in this weekend and plan to order a header pretty soon. I imagine it will get pretty loud but I shall see.
TruRace is offline   Reply With Quote
Old 01-29-2014, 09:59 AM   #40
carma143
carma143's Avatar
one more thing. Will installing an aftermarket exhaust or header in the future affect any warranties?
Old 01-29-2014, 10:02 AM   #41
Malt
Drives: 2015 WRX
Typically speaking auto manufactures don't like people modifying emission equipment. You should be fine with a cat back but replacing anything from the front pipe forward may be an issue.
Malt is offline   Reply With Quote
Old 01-29-2014, 11:20 AM   #42
humfrz
Especially in California .....
cost, deletes, exhaust
Rear Seat Deletes EvoFanatic Cosmetic Modification (Interior/Exterior/Lighting) 110 02-23-2015 07:59 PM
FT-86 SpeedFactory Exhaust Hole Deletes - Now you can look good single. FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 47 01-30-2015 09:12 AM
To those with muffler deletes: jshadeck Engine, Exhaust, Transmission 23 08-17-2013 01:05 PM
Rear Seat Deletes ??? KVDB31 Cosmetic Modification (Interior/Exterior/Lighting) 40 08-17-2013 09:16 AM
