#29 |
Drives: Gray.
#30 |
Thanks
The number one reason to rev match on the street is because it is fun and sounds cool. Sure it is about 99% unnecessary but it helps combat the mundane commute
#31 |
Drives: 2013 SWP BRZ Premium
Scenario Time!
I am cursing along at 3000 RMP in 4th gear going 44 MPH, If I have 150 feet to come to a complete stop what should I do? |
#32 |
Thanks
brake, clutch in right before completing the stop?
amirite? wut do i win? |
#33 |
#34 | ||
Negative Mass
Drives: Orange Metallic AVO Turbo GT86 6MT
If you want to downshift to engine brake you must rev-match by blipping the throttle. This prevents the clutch wear because the two sides of the clutch will be spinning at very nearly the same speed. By your logic I will destroy my transmission if I'm in gear while not accelerating. That is completely absurd. I can rev to red line in a gear and coast down in that same gear and I will do no abnormal wear to the transmission. Quote:
Build thread for my Lovely Lady.
#35 | |
Drives: 450 awhp twin turbo vr4
That is true. However if you are in gear have pedal input at high rev...you will be fine. Reason is because the car the trans, and everything else is in Harmony...the way it was designed....again, if you let off your pedal at high rev suddenly...engine brake happens...you are burning clutch. Put it simply...can you brake your car without burning your discs and pads ? If you can..you will be the second einstein..... Yeah...i didnt think so...therefore whenever you engine brake...you are burning the clutch and fly wheel as you do so.....and more on the gears...they were designed to be moving...not braking. |
#36 | ||
Negative Mass
You are describing something I guess I'll call "clutch braking". That's driving like a moron. Engine braking does not involve any clutch wear whatsoever. Also I'm not Eintsein, nor did I claim to be.
#37 | |
However, your clutch may not burn....but i still would like to think that the transmission was designed to move...not to stop movements |
#38 | |
Negative Mass
Applying torque against the rotation of the gears isn't really that bad for them. I read a description of the effect that went something along the lines of this: When you use the gears to accelerate you wear down one "side" of the teeth. When you use the gears to decelerate you wear down the other "side". If you never engine brake you will end up throwing your transmission away without having applied that wear. I don't know how true that is, but I've never heard of a well-designed transmission having problems because of too many well-executed downshifts.
#39 |
I like to eat!
Please try to match revs, and be in the correct gear for the speed.
I learned a long time ago (in the 60's) how to drive a manual. What I learned: Be patient, don't be intimidated or bullied by passengers or people behind you, and practice technique when you have free time. Be patient! It's what I said from the start! You can do it! |
#40 | |
Yeah, me neither, but you cant never be too careful right ?
#41 | |
I like to eat!
When I come down down the west side of the Central Cascades (US Rt. 2), if I coast in my BRZ in neutral or in my Jeep JK unlimited I will far exceed my MPG by coasting for nearly 26 miles in neutral as opposed to running in gear and using engine braking. The computer in the Jeep snd BRZ aren't lying, are they? |
#42 |
Negative Mass
There's a fine line haha. I learned to drive manual on this car and started out thinking a single mistake would cause the transmission to fall out / clutch to incinerate / engine to flood. In all honesty you have to drive very terribly to do any major damage to this car.
I drove around overboosting for a few hundred miles and blasted away my stock clutch, and the was still driving ok, clutch working out of boost. Look at that guy who's engine just exploded because of bad tune. He talked about the engine surviving a near knock situation for 12000 miles... This car is strong. Strong like bull. But I digress. Back on topic my advice is just keep driving, watching videos and getting help from friends. Don't be shy about asking questions (which I can see you aren't OP since you started this thread). Manual transmission is the best part of driving a car in my opinion, just have fun and don't worry so much.
| Best place to learn how to drive my car | Pneub | Southern California | 1 | 06-07-2013 03:54 PM |
| what did you learn to drive on? | 7thgear | Off-Topic Lounge [WARNING: NO POLITICS] | 31 | 08-10-2012 10:39 PM |
| Where to learn how to drive manual.... | Saibot | CANADA | 12 | 03-13-2012 06:28 PM |
| Who needs to learn how to drive... | RRnold | Other Vehicles & General Automotive Discussions | 14 | 08-27-2011 12:15 AM |
| Learn to Drive | MtnDrvr86 | Other Vehicles & General Automotive Discussions | 102 | 03-14-2010 08:46 AM |
