Old 01-20-2014, 08:51 PM   #29
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
@nataku
I am very insecure. I have no friends. I want people to love me
The Following User Says Thank You to IloveBaldEagles For This Useful Post:
ZionsWrath (01-20-2014)
Old 01-20-2014, 09:10 PM   #30
ZionsWrath
Thanks
ZionsWrath's Avatar
The number one reason to rev match on the street is because it is fun and sounds cool. Sure it is about 99% unnecessary but it helps combat the mundane commute
The Following User Says Thank You to ZionsWrath For This Useful Post:
Gilwith1l (03-27-2014)
Old 01-20-2014, 09:22 PM   #31
calidus
Drives: 2013 SWP BRZ Premium
Scenario Time!
I am cursing along at 3000 RMP in 4th gear going 44 MPH, If I have 150 feet to come to a complete stop what should I do?
calidus is offline   Reply With Quote
The Following User Says Thank You to calidus For This Useful Post:
Old 01-20-2014, 09:24 PM   #32
ZionsWrath
Thanks
ZionsWrath's Avatar
brake, clutch in right before completing the stop?
amirite? wut do i win?
Old 01-20-2014, 09:31 PM   #33
calidus
I will give you a smiley face
So don't bother down shifting when coming to a complete stop?
Old 01-20-2014, 09:34 PM   #34
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Originally Posted by Whitigir View Post
By doing engine Brake, you put too much Torque Tensions onto the transmission through the gears...which it was never an intentional engineering. Transmission and gears were engineered to distribute the Torque from small to bigger via momentum....put it simple.....your Transmission was never designed to be driven from 6---to 1....you will burn your Clutch, and Crack the gears....slip the Synchros....whatever
Conclusion.....Engine Brake kills your Drive train much faster than expected....that is Transmission (whole) + Clutch + Flywheel....some after market Aluminum flywheel will be easily warped.
Unless you're talking about someone who has no idea how to drive a manual properly this is complete misinformation.
If you want to downshift to engine brake you must rev-match by blipping the throttle. This prevents the clutch wear because the two sides of the clutch will be spinning at very nearly the same speed.
By your logic I will destroy my transmission if I'm in gear while not accelerating. That is completely absurd. I can rev to red line in a gear and coast down in that same gear and I will do no abnormal wear to the transmission.
Originally Posted by IloveBaldEagles View Post
hi
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 01-20-2014, 09:56 PM   #35
Whitigir
Drives: 450 awhp twin turbo vr4
hi
You will destroy your transmission if...you engine brake....say you are at redline....engine braking without accelerating.
That is true. However if you are in gear have pedal input at high rev...you will be fine. Reason is because the car the trans, and everything else is in Harmony...the way it was designed....again, if you let off your pedal at high rev suddenly...engine brake happens...you are burning clutch.
Put it simply...can you brake your car without burning your discs and pads ? If you can..you will be the second einstein.....
Yeah...i didnt think so...therefore whenever you engine brake...you are burning the clutch and fly wheel as you do so.....and more on the gears...they were designed to be moving...not braking.
Whitigir is offline   Reply With Quote
The Following User Says Thank You to Whitigir For This Useful Post:
kcam86 (01-20-2014)
Old 01-20-2014, 10:05 PM   #36
nataku
Negative Mass
nataku's Avatar
You will destroy your transmission if...you are at redline....engine braking without accelerating.
If you do this on a regular basis you will damage every part of your car. No one who would defend engine braking would ever suggest this as a good way to drive. I was simply saying you exaggerate the wear on the transmission beyond reason.
The entire second paragraph is false and unnecessarily sassy. Using the vacuum of the engine during closed throttle to slow the movement of the car does not cause any undue wear to your transmission. If your clutch EVER slips while fully engaged you need a new clutch.
You are describing something I guess I'll call "clutch braking". That's driving like a moron. Engine braking does not involve any clutch wear whatsoever.
Also I'm not Eintsein, nor did I claim to be.
The Following 3 Users Say Thank You to nataku For This Useful Post:
Drebin252 (01-21-2014), tbertran (01-20-2014), Wattage (02-22-2014)
Old 01-20-2014, 10:17 PM   #37
Whitigir
My appologize...you are actually right....it is clutch braking .... That i mentioned....
However, your clutch may not burn....but i still would like to think that the transmission was designed to move...not to stop movements
Old 01-20-2014, 10:20 PM   #38
nataku
Negative Mass
nataku's Avatar
Haha I just reread your first post and I realized what you were getting at...
Applying torque against the rotation of the gears isn't really that bad for them. I read a description of the effect that went something along the lines of this:
When you use the gears to accelerate you wear down one "side" of the teeth. When you use the gears to decelerate you wear down the other "side". If you never engine brake you will end up throwing your transmission away without having applied that wear.
I don't know how true that is, but I've never heard of a well-designed transmission having problems because of too many well-executed downshifts.
The Following User Says Thank You to nataku For This Useful Post:
Whitigir (01-20-2014)
Old 01-20-2014, 10:21 PM   #39
Pete156
I like to eat!
Please try to match revs, and be in the correct gear for the speed.
I learned a long time ago (in the 60's) how to drive a manual. What I learned: Be patient, don't be intimidated or bullied by passengers or people behind you, and practice technique when you have free time.
Be patient! It's what I said from the start!
You can do it!
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
leicaboss (01-21-2014)
Old 01-20-2014, 10:28 PM   #40
Whitigir
Yeah, me neither, but you cant never be too careful right ?
Old 01-20-2014, 10:31 PM   #41
Pete156
I like to eat!
Originally Posted by Suberman View Post
Coasting doesn't save fuel though as another poster pointed out because all emission controlled engines shut off the fuel when on overrun!
Sorry. Have to respectfully disagree,
When I come down down the west side of the Central Cascades (US Rt. 2), if I coast in my BRZ in neutral or in my Jeep JK unlimited I will far exceed my MPG by coasting for nearly 26 miles in neutral as opposed to running in gear and using engine braking. The computer in the Jeep snd BRZ aren't lying, are they?
Suberman (01-20-2014)
Old 01-20-2014, 10:34 PM   #42
nataku
Negative Mass
nataku's Avatar
There's a fine line haha. I learned to drive manual on this car and started out thinking a single mistake would cause the transmission to fall out / clutch to incinerate / engine to flood. In all honesty you have to drive very terribly to do any major damage to this car.
I drove around overboosting for a few hundred miles and blasted away my stock clutch, and the was still driving ok, clutch working out of boost. Look at that guy who's engine just exploded because of bad tune. He talked about the engine surviving a near knock situation for 12000 miles...
This car is strong. Strong like bull.
But I digress.
Back on topic my advice is just keep driving, watching videos and getting help from friends. Don't be shy about asking questions (which I can see you aren't OP since you started this thread). Manual transmission is the best part of driving a car in my opinion, just have fun and don't worry so much.
Best place to learn how to drive my car Pneub Southern California 1 06-07-2013 03:54 PM
what did you learn to drive on? 7thgear Off-Topic Lounge [WARNING: NO POLITICS] 31 08-10-2012 10:39 PM
Where to learn how to drive manual.... Saibot CANADA 12 03-13-2012 06:28 PM
Who needs to learn how to drive... RRnold Other Vehicles & General Automotive Discussions 14 08-27-2011 12:15 AM
Learn to Drive MtnDrvr86 Other Vehicles & General Automotive Discussions 102 03-14-2010 08:46 AM
