Old 12-09-2013, 06:18 PM   #29
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
I agree the stock suspension, especially geometry, are not bad. Corner balancing is one of the main advantages to coilovers as well as tune-ability to current road surface. I will do a few track days before I even think of modifying anything. I only want to upgrade where the car is lacking currently.
shaunsweeney is offline   Reply With Quote
Old 12-09-2013, 08:15 PM   #30
u/Josh
Drives: GBS Limited 6MT
Originally Posted by rallysrt View Post
Hahaha. I'm always building unique and useful parts for all my vehicles.
If you like the car at stock height there's really nothing wrong with the stock springs and struts except corner balancing is a little tough but my spacers could take care of that little problem as well. Lol running stock suspension(with poly bushings) allowed me to run 275 Hoosiers and be one of the very fastest autoxers in my region along with being the biggest money winner in Scion Canada's contingency program. I really do like the stock suspension but probably will go with some good coilovers for next summer. :-/
How in the world did you clear 275 hoosiers with stock springs?
Also, any sway bar mods? Camber?
u/Josh is offline   Reply With Quote
Old 12-10-2013, 01:15 AM   #31
rallysrt
Drives: shitboxes
I certainly wouldn't recommend my autox setup to anyone that cares about proper autox classing but IMO my setup gave the best times for the least dough, which in turn made me the most dough with overall raw wins and ftd's within my region.
My suspension setup was very simple. Shitty garbage whiteline tophats(castor/camber). Whiteline castor/anti-dive front control arm bushings. Rear whiteline camber adjustable upper control arm bushings. And I did have to grind down the front spring perches and a little of the front springs but only where they're fully in contact with the perch. The sways and subframe bushings were 100% oem. Yes, in some pictures it looked like the car was going to tip over. Lol Much of this will change if I decide to autox again next year.
Final alignment settings were -1.3 deg camber, 1/8 toe out up front and -1.8 camber, 0 toe in the rear. I definitely needed more camber, especially in the front but I wasn't even able to slot my front struts because of the 275's. :-/ damned compromises.
Wheels are 17x9 +45 rpf1's with 10mm spacers in the front with arp studs all around. And 275/35/17 A6's that are signicantly shorter than stock which kept my fenders pretty(hellapoked FTW)
I wasn't 100% satisfied with any of this ^^^^but my car proved to be faster than anyone could've imagined, especially me.
rallysrt is offline   Reply With Quote
The Following 2 Users Say Thank You to rallysrt For This Useful Post:
mfbmike (12-11-2013), u/Josh (12-10-2013)
Old 06-06-2014, 11:30 PM   #32
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Originally Posted by pheoxs View Post
I need those wheels in my life.
NissanGuy is offline   Reply With Quote
The Following User Says Thank You to NissanGuy For This Useful Post:
rallysrt (06-25-2015)
Old 08-11-2014, 01:29 AM   #33
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'd love a set of Ronal R50s, but they weigh and cost too much. Why does everyone who puts a set on the twins paint them white? WTF? PAIN!
Old 08-11-2014, 09:07 AM   #34
jdmblood
jdmblood's Avatar
Drives: white subaru brz
props to the op for being the first to try this on our cars
hoping this doesnt turn into a form vs function argument lmaoo
jdmblood is offline   Reply With Quote
Old 08-13-2014, 07:13 AM   #35
Baramzisyan
turbo turtle
Baramzisyan's Avatar
Drives: exit GT86 enter STI
Bump!
what about spacers? I need to lift my brz.
Any sellers?
Baramzisyan is offline   Reply With Quote
Old 08-13-2014, 11:12 AM   #36
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Baramzisyan View Post
Bump!
Any sellers?
I have 1/2 a set of subtle solutions spacers if you are interested (kit is for wrx, but fronts are the same as brz, just need to purchase the rears). PM me if interested.
Old 09-01-2014, 08:46 PM   #37
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
GT-86 rally cars FTW!
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
The Following 2 Users Say Thank You to Weasel Soup For This Useful Post:
Muaddib (09-01-2014), rallysrt (06-24-2015)
Old 06-24-2015, 02:07 PM   #38
rallysrt
Drives: shitboxes
jsimon7777, please don't confuse my wheels with Ronals......
Sent from my SM-N900W8 using Tapatalk
Old 06-24-2015, 10:39 PM   #39
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
I'm pretty sure lift spacers like this for '08+ Imprezas will bolt onto a FRS/BRZ
Kostamojen is offline   Reply With Quote
Old 06-25-2015, 02:32 AM   #40
EAGLE5
Dismember
EAGLE5's Avatar
My bad. Didn't realize your wheels were old knockoffs of Ronals. X)
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 05-10-2016, 11:08 PM   #41
Hot Wheels
Drives: 2014 WRB BRZ Limited
I saw that Subtle Solutions has a premade 1" kit like this one. I know fooling with suspension requires an alignment after, but would raising it the 1" put too much positive camber on the rear? I've tried looking into being able to adjust rear camber for cheap, but all I've found was expensive control arms. Sorry, but you'll need to keep it simple with me, as I am just learning about our cars. I live in Kansas around a lot of dirt/gravel farm roads, and the extra ground clearance would give me more peace of mind.
Hot Wheels is offline   Reply With Quote
Old 05-11-2016, 12:40 AM   #42
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
If its just dirt/gravel concerns in a DD situation, wouldnt the JDM full underbody panel and some mud flaps be enough?
Lifting the car wont stop gravel from being kicked up by your or other's wheels and smacking the paint :\
But yea, no way to adjust camber in the rear without aftermarket control arms.
PandaSPUR is offline   Reply With Quote
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 08:51 AM
Lift rental Calidrifter Southern California 15 06-04-2013 10:23 PM
EZ Car lift RRnold Other Vehicles & General Automotive Discussions 13 11-09-2012 04:20 PM
How to lift? Mo707 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-28-2012 12:57 PM
don't lift pr086 Scion FR-S / Toyota 86 GT86 General Forum 27 08-17-2012 11:51 AM
