Old 12-05-2013, 12:53 PM   #29
strat61caster
strat61caster's Avatar
Originally Posted by cnk View Post
My point is that if the engine only ran port injection, there would be no need for the hpfp.
I think you missed the point of my post, without DI Tada claims they could only get 120 hp out of the 2.0L boxer with Subaru and that D4-S is far from crappy with only a minority (who predominantly track and mod) suffering failures of the DI seals. A funny noise is just a funny noise, it bothers some but not all.
ineedyourdiddly
Old 12-05-2013, 01:26 PM   #30
cnk
Drives: '13 DGM BRZ Limited
I understand your point. My point is that Toyota failed in their design/QC of the HPFP for their implementation of D4S in the twins as evidenced by the IS350/GS350 which do not chirp. The fact that they are on their 3rd revision of the pump indicates that they still are making blind attempts at resolving the issue.
cnk is offline   Reply With Quote
Old 12-05-2013, 01:35 PM   #31
strat61caster
Ah, see I don't consider the 'chirp' a failure. I consider a (so far) reliable 200 hp 2.0L boxer that gets good gas mileage a success. Agree to disagree, cheers.
ineedyourdiddly
Old 12-05-2013, 01:46 PM   #32
cnk
We will have to agree to disagree as you stated then. Considering NVH is a major component in car design these days, I would definitely consider the chirping a failure. It has not been proven to cause any issues thus far, but it is still a failure in my mind because of the added NVH that shouldn't be there. It's not like the STi where Subaru didn't put any sound deadening in the cabin and put disclaimers on their brochures when it was released. This chirping is not an intended design feature.
The Following User Says Thank You to cnk For This Useful Post:
strat61caster (12-05-2013)
Old 12-05-2013, 01:47 PM   #33
autobrz
Drives: Mazda 3
I suppose someone has just tried wrapping that puppy up with multi-layers of Dynamat to shut it up ... ??
dynamat absorbs vibration to reduce noises produced by vibrating surfaces but does not block sound very well. some mass loaded vinyl will work better I think...
autobrz is offline   Reply With Quote
The Following User Says Thank You to autobrz For This Useful Post:
humfrz (12-05-2013)
Old 12-05-2013, 02:39 PM   #34
kuhlka
Drives: 2013 BRZ Limited AT
Mine are consistent no matter what the temps. Once the engine is all warmed up, they manifest.
Same here. It's usually chirping like crazy by the time it's fully warmed up (temp gauge at ~50% mark). Aside from the obnoxious noise, the pump performs well enough. I'll be waiting for a confirmed long-term 'fix' before bothering Subaru about a replacement.
kuhlka is offline   Reply With Quote
Old 12-05-2013, 06:59 PM   #35
jeebus
Drives: 2015 Mustang GT (on order)
On my original pump, 17k miles, noise went away around 10k and I'm happy as a clam.
I'm on my original pump too. I got the noise around 1500 miles, it went away a few thousand miles later as well. However, it came back at 20k miles...now it's mostly gone again for the winter.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
Old 12-05-2013, 10:29 PM   #36
fistpoint
Drives: Supercharged Golf Cart
You're damned right it counts as a failure.
I made the visual analogy long ago of the engineers all standing around the first time they fired it up and heard the crickets for themselves...they all looked around and began giving out "hi fives" to each other for what would only be considered an awesome sound that every owner would be proud to show off to their neighbor and other potential customers.
In reality, they probably cringed...likening the sound to that of an old, beat to shit engine that needs one or more belts replaced.
Nah, who am I kidding. They're quite proud of the noise the engine makes, that's why they keep making revised pumps that clearly cost zero money to redesign.
fistpoint is offline   Reply With Quote
Old 12-06-2013, 12:34 AM   #37
Tromatic
LOL at the haters, fuel-pump designers and fluid dynamics PhD's.
Tromatic is offline   Reply With Quote
Old 12-06-2013, 06:45 AM   #38
FR-S Matt
I told my service adviser to just give me another shot at the latest pump version again if they can. Waiting to hear info about a possible "another" revision to the current SU003-05176 pump but with the holidays around, might not get an answer till after New Years.
Old 12-06-2013, 06:58 AM   #39
5AD86D
5AD86D's Avatar
I hope to know soon. After New Years is looking more and more likely.
5AD86D is offline   Reply With Quote
Old 12-06-2013, 07:45 AM   #40
utekineir
blowhard
Drives: frs, project forester
Woodpeckers in the engine bay are where it's at
utekineir is offline   Reply With Quote
Old 12-06-2013, 10:17 AM   #41
SteveGrillo
Drives: Brz
2nd FI unit - chirp - engine sounds broken
I'm have a BRZ and had the chirp within maybe 5k miles. Subaru replaced the FI part, and it was great again, for a while. Now it's HORRIBLE (10K later).
The chirp happens under ALL loads from idle up to almost 2K RPM.
And after driving for a while, you can hear it stopped at lights etc, regardless of ambient temps.
But when it's hot out, MAN is it annoying and LOUD. It really sounds like a bad water pump or other metal-on-metal problem.
I'm embarrassed to drive up near anyone when it's chirping loudly.
So I for one am very VERY interested in a real fix to this.
Steve
SteveGrillo is offline   Reply With Quote
Old 12-07-2013, 03:38 AM   #42
fistpoint
I can almost bet your life that most of the people telling us haters to shut it will be one of the first assholes lined up at their dealership when it's finally announced that a real working pump exists.
IMPORTANT QUESTION AZOOZ_95 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 08-21-2013 02:44 AM
Important: DBA Rear Rotors (BRZ/FR-S) FRS2000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-17-2013 08:08 PM
**IMPORTANT ISSUE****READ THIS****NEED YOUR HELP** fred864 Issues | Warranty | Recalls / TSB 33 04-20-2013 12:57 AM
Color, how important is it to you? Iixii BRZ First-Gen (2012+) — General Topics 63 11-09-2012 10:25 AM
How important is an LSD on this car? colHolm Scion FR-S / Toyota 86 GT86 General Forum 92 05-13-2011 05:53 PM
