#29 |
Drives: 2013 FR-S, raven
Thanks
They are the standard 18x9.5 +40, 2 degrees camber all around. Never measured how low I actually dropped it but probably around 2" all around.
悪魔のハチロク
2013 Scion FR-S, Raven Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite |
#30 |
Drives: Asphalt Monogram Fr-s
Nah thats an extra 100-200 lol
#31 |
Your car is basically my dream car, i want the trd kid and the te37sl' so bad
#32 |
Thanks buddy hang in there take your time your dream will come true
![]() A few month ago SpecPer's car was my dream car. here are some pics of his: ![]()
悪魔のハチロク
#33 | |
Drives: I own an FR-S. . . whatelse!
#34 |
Well look at it like this, unless you are tracking the car then you probably don't need V3s. Hell, even if you are racing your car, getting V3s isn't the only option(an expensive one at that). If your goal is good looks, then aim for a suspension set up that will allow you to get the drop you want, without destroying the ride quality.
#35 | |
#36 | |
Some good suggestions for cheaper coilovers are Fortune Auto, my friend has Feal and he seems to like it, ST is a good budget coil, and you can check out KW V1s, not as adjustable as the V3 but still amazing. Do not get Megans or Racelands, I have heard they are pretty terrible. |
#37 | |
#38 | |
Two more points I do want to make. First, tire fitment is subject to many different opinion. I follow the school of proper fitment over stretched, so for a 9.5" wheel I suggest at least 245/35/18. Second, when it comes to coil overs, unless you go with the best of the best (also the most expensive), it will be difficult to get excellent performance while maintain outstanding streetability (proper dampening on the streets, minimal noises, etc). Have a budget it mind, and then get the best value for what you could afford. Good luck!
悪魔のハチロク
#39 |
Drives: Ultramarine toyobaru
The new Corvette comes with 8.5" fronts and 10" rear. Anyone who thinks 9.5 for our car is a reasonable performance mod, is delusional. This is made even more true by the fact that people put tires on 9.5" wheels, that would fit on 8" or 8.5" rims. Clearly they are not thinking of grip.
This "bit extra grip" only makes sense if you're going to put very wide tires on those 9" wheels. Tires that would not fit on 8 or 8.5. If not you will be looking at less not more grip. Keep in mind, you can fit 245+ on 8" rims. |
#40 | |
![]() the extra 30mm does provide additional "grip" reasoanably
悪魔のハチロク
#41 | |
#42 |
| FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) | kanundrum | Wheels and Tires | 19 | 10-11-2013 09:26 AM |
| Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! | stratodyne | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 07-17-2013 02:21 PM |
| 17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? | SteveH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-14-2013 10:26 PM |
| Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 10:08 PM |
