Old 12-03-2013, 05:01 PM   #1
MrMarinakos
Drives: Asphalt Monogram Fr-s
I need help with my wheels
Okay so i ordered the varrstoen 18x9.5 +34 but i' just found out that it doesnt fit with stock suspension. Does anyone have any ideas because me being young and all i don't know much and my mom refuses to let me stretch the tires because it'll cause a problem (pretty sure it doesnt) and she thinks fender rolling is going to fuck up my car because its messing up the body.. Can someone just like help out and explain if these would fit if i stretched the tires to fit on a stock suspension
MrMarinakos is offline   Reply With Quote
Old 12-03-2013, 05:34 PM   #2
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
It might fit with stretched tires, but another thing you can do is get some coilovers to get some extra room, a fairly nice set is about 1000(the nicer you want the more expensive).
You may have to take a dremmel to certain parts of the wells to get them to stop rubbing.
And although I may not know you...I think you should listen to your mom. Stretched tires aren't the safest thing in the world.
IAmNotTheDriftKing is offline   Reply With Quote
Old 12-03-2013, 05:36 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Return/sell the wheels. Problem solved.
-alex
P.S. I'm totally serious on this. You got wheels that are way too aggressive fitment-wise for a stock suspension car.
Old 12-03-2013, 06:26 PM   #4
MrMarinakos
Dont have the money for coilovers you think 18x8.5 would fit?
Old 12-03-2013, 06:49 PM   #5
Abenaki
Curmudgeon@gezzer.com
Abenaki's Avatar
So your mom knows more about your car than you do..... Do you see a problem here? Return the wheels.... Get some education / understanding of what does work for your car from the forum and try again.
Abenaki is offline   Reply With Quote
Old 12-03-2013, 06:53 PM   #6
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
-alex
Bingo.
furthermore 9.5s on this car is outrageous, unless youre building a car strictly for show/appearances. There is no reasonable advantage for having wheels that wide on a 200hp lightweight.
headlikeahole is offline   Reply With Quote
Old 12-03-2013, 07:04 PM   #7
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
I'm running 18x9.5 +35 square on stock suspension without any issues.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
Old 12-03-2013, 07:05 PM   #8
MrMarinakos
Originally Posted by headlikeahole View Post
Bingo.
Well what about 8.5's? I did do alot of research but the one thing i didn't realize was suspension because everyone else that i read about with fitment and etc has coilovers and adjusements to there suspension
Old 12-03-2013, 07:05 PM   #9
IAmNotTheDriftKing
Don't settle because you are short on cash. Make the money and then get the wheels you want and the coilovers!
Old 12-03-2013, 07:06 PM   #10
MrMarinakos
What tires?
Old 12-03-2013, 07:07 PM   #11
MrMarinakos
Well i want KWv3 coilovers thats the major problem, if i bother saving for that then i might as well get volk te37sl
Old 12-03-2013, 07:11 PM   #12
headlikeahole
The most appropriate size for this car is from 7.5 to 8 inch. 8.5" and to some degree 9" is a decent medium between performance and just showing off.
Old 12-03-2013, 07:14 PM   #13
mav1178
mav1178's Avatar
Nah, I have 18x9/9.5 F/R on my car, mostly for looks.
The issue isn't that there are "no issues". The issue is that OP can't even run a stretched tire, and running a "normal sized" tire on this wheel setup will just look.... odd.
I know, I had this for a few days then got embarrassed enough to throw on the coilovers.
-alex
Old 12-03-2013, 07:19 PM   #14
headlikeahole
-alex
In what way are you disagreeing with me?
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
