#29 | |||
Drives: 1993 Impreza w/ WRX Swap + FWD!
#30 | |
CHECK ENGINE
Drives: 2004 STi
That is why I bought everything needed and made this write-up
i don't cry about crickets
#31 | |
CHECK ENGINE
Drives: 2004 STi
Other option would be to weld a pipe to fit a 3/8 inch hose onto the BRZ water pipe near where the oil cooler hose would join the FXT pipe. I went for a bolt-on solution and thats why I used almost all of the OEM parts without modification.
#32 |
Drives: 2012 FR-S
Thank you for sharing!
#33 | |
Drives: 13 BRZ Limited 6MT GBS
When oil is colder than the coolant, the coolant heats up before the oil, so this supposedly will bring the oil up to operating temperature faster. When oil is hotter than the coolant, the coolant cools off the oil.
| The Following User Says Thank You to nalc For This Useful Post: | Kimsey47 (11-01-2013) |
#35 |
Drives: 2016 STI DGM
Thanks for the education guys!
And special thanks to OP for the write up, as I forgot to thank you originally!
Subaru STI :![]() |
| The Following User Says Thank You to Kimsey47 For This Useful Post: | CARNZ (11-01-2013) |
#36 |
Drives: Toyota 86 TRD Version AT
Great write up OP! Will look into this, seems like a good oil cooling solution!
#37 |
AIM4APX
Drives: 2013 WRB BRZ Limited
Just ordered everything through Wilde Subaru. 285.22 after tax.
Thanks so much for the write up and parts list. For someone who drives in the winter, and drives hard in the summer, this seems like a great, great mod.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
| The Following User Says Thank You to Superhatch For This Useful Post: | chanomatik (11-01-2013) |
#38 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Awesome, really simple and clean. Wish I could run a cooler, I would like this over a external heat exchanger for sure.
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
#39 | |
AIM4APX
TIA
#40 | |
She said member
Drives: fr-s firestorm
I like it but might prefer to have the cooler after the radiator, I'll have to take a look at mine and see if that is even possible |
#41 | |
CHECK ENGINE
Drives: 2004 STi
You will need 2 fittings: http://www.jegs.com/i/JEGS-Performan...ductId=1281861 <- JEGS -8AN Female to 1/2 hose barb http://www.jegs.com/i/Russell/799/670490/10002/-1 <- Russell M14x1.5 to -8AN Male Hook these 2 fittings together and you are set. I got lucky and my co-worker had a M14x1.5 to 1/2 barb fitting for me to use. updating the first post now. Mike
| The Following 5 Users Say Thank You to CARNZ For This Useful Post: | autobrz (11-14-2013), chanomatik (11-01-2013), MannyO (01-12-2014), P@ul (11-03-2013), Superhatch (11-01-2013) |
#42 |
Drives: FR-S 10 #103 AT
So if you are more concerned with an easy installation that works more than looking factory, you could just tap into the heater core supply and exit lines with tee fittings, run the hoses as you see fit and be done with it, quick and painless, correct?
Thank you for posting this. I like it. Edit: Just finished checking out the other thread and it looks like the cooler needs to be plumbed in sequence to maintain pressure to force water through the cooler. Putting it effectively in parallel with something like the heater core won't work as well because the coolant will take the path of least resistance through the heater core. Edit 2: Just finished reading the how-to portion of this thread more carefully and it looks like the cooler is installed in parallel and appears to work, so the other thread has bad information. Can someone who knows please clarify this?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." Last edited by mid_life_crisis; 11-01-2013 at 02:58 PM. |
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) — General Topics | 37 | 03-21-2013 06:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) — General Topics | 12 | 02-01-2013 12:29 PM |
