Old 11-01-2013, 06:28 AM   #29
Kostamojen
Originally Posted by imom View Post
Is it possible to bend the pipe from the FXT pipe (21328AA220 - PIPE, OIL COOLER) to same angle as the original BRZ oil pipe? Or even better if someone can make a new or modified BRZ oil pipe cooler to use with the FXT oil cooler
There isn't any oil going throuhh said pipe just coolant. If you don't want to use that pipe as your return feed you could T off the heater hose instead.
Also how different is this from say a Perrin oil cooler?
Perrin is an air-oil oil cooler this is water cooled.
I take it that since the FXT is a turbo this oil cooler is good enough to be used for all the other FI systems i.e. Vortech, KW, JR etc.?
Yes
The Following 2 Users Say Thank You to Kostamojen For This Useful Post:
imom (11-02-2013), SirBrass (05-01-2014)
Old 11-01-2013, 07:10 AM   #30
CARNZ
CHECK ENGINE
Drives: 2004 STi
Originally Posted by no chrome View Post
Without studying plumbing diagrams it looks like this runs the cooler in parallel with the heater core
Do we actually need all those extra parts?
You COULD plumb it in differently, I wanted it to look and fit like OEM.
That is why I bought everything needed and made this write-up
i don't cry about crickets
CARNZ is offline   Reply With Quote
The Following 2 Users Say Thank You to CARNZ For This Useful Post:
Kakawate (11-03-2013), tigermack (01-20-2015)
Old 11-01-2013, 07:15 AM   #31
CARNZ
CHECK ENGINE
Drives: 2004 STi
Kostamojen answered your other questions, but I suppose with a pipe bender and some time you could bend the rear-facing tube to be straight up. Or you could try to cut the bent part off and add a new bead to the pipe then install the heater hose.
Other option would be to weld a pipe to fit a 3/8 inch hose onto the BRZ water pipe near where the oil cooler hose would join the FXT pipe.
I went for a bolt-on solution and thats why I used almost all of the OEM parts without modification.
Old 11-01-2013, 07:25 AM   #32
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Thank you for sharing!
AceHeader-MT is offline   Reply With Quote
Old 11-01-2013, 07:47 AM   #33
nalc
Drives: 13 BRZ Limited 6MT GBS
Originally Posted by Kimsey47 View Post
So for a engine newb like me, what I take from this is that the oil heats up faster in this configuration; yet stays at a cooler temp during hard driving? That math doesn't add up to me so can someone explain what this system is doing?
The other oil cooling kits I viewed seemed to make more sense in that you're running the oil through a radiator type device to air cool it during hard driving... So I guess I just don't understand how this "wet" system works.
Not knocking the system, just trying to improve my horrible mechanical knowledge!
Thanks!
It's using the coolant to heat/cool the oil.
When oil is colder than the coolant, the coolant heats up before the oil, so this supposedly will bring the oil up to operating temperature faster.
When oil is hotter than the coolant, the coolant cools off the oil.
nalc is offline   Reply With Quote
The Following User Says Thank You to nalc For This Useful Post:
Kimsey47 (11-01-2013)
Old 11-01-2013, 08:12 AM   #34
troek
troek's Avatar
Drives: 2012 Toyota 86
nice job! i love this kind of stuff
troek is offline   Reply With Quote
Old 11-01-2013, 09:31 AM   #35
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Thanks for the education guys!
And special thanks to OP for the write up, as I forgot to thank you originally!
Subaru STI :
The Following User Says Thank You to Kimsey47 For This Useful Post:
CARNZ (11-01-2013)
Old 11-01-2013, 10:02 AM   #36
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Great write up OP! Will look into this, seems like a good oil cooling solution!
Tye300 is offline   Reply With Quote
Old 11-01-2013, 11:35 AM   #37
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Just ordered everything through Wilde Subaru. 285.22 after tax.
Thanks so much for the write up and parts list. For someone who drives in the winter, and drives hard in the summer, this seems like a great, great mod.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
The Following User Says Thank You to Superhatch For This Useful Post:
chanomatik (11-01-2013)
Old 11-01-2013, 11:54 AM   #38
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Awesome, really simple and clean. Wish I could run a cooler, I would like this over a external heat exchanger for sure.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 11-01-2013, 12:40 PM   #39
Superhatch
AIM4APX
Superhatch's Avatar
Originally Posted by CARNZ View Post
[*]M14x1.5 to 1/2 Barb Fitting (like this one http://www.aeroflowperformance.com//.../view/AF746-03)
So that company doesn't seem to ship, and it's distributors are all out of AU. On ebay I can find an M18, M16, and M12 but not an M14. Did you get yours locally?
TIA
Old 11-01-2013, 12:55 PM   #40
no chrome
She said member
Drives: fr-s firestorm
So this does effectively put the cooler in parallel with the heater core?
I like it but might prefer to have the cooler after the radiator, I'll have to take a look at mine and see if that is even possible
no chrome is offline   Reply With Quote
Old 11-01-2013, 01:05 PM   #41
CARNZ
CHECK ENGINE
Drives: 2004 STi
TIA
I realized this last night, but have a new solution!
You will need 2 fittings:
http://www.jegs.com/i/JEGS-Performan...ductId=1281861 <- JEGS -8AN Female to 1/2 hose barb
http://www.jegs.com/i/Russell/799/670490/10002/-1 <- Russell M14x1.5 to -8AN Male
Hook these 2 fittings together and you are set.
I got lucky and my co-worker had a M14x1.5 to 1/2 barb fitting for me to use.
updating the first post now.
Mike
The Following 5 Users Say Thank You to CARNZ For This Useful Post:
autobrz (11-14-2013), chanomatik (11-01-2013), MannyO (01-12-2014), P@ul (11-03-2013), Superhatch (11-01-2013)
Old 11-01-2013, 01:56 PM   #42
mid_life_crisis
Drives: FR-S 10 #103 AT
So if you are more concerned with an easy installation that works more than looking factory, you could just tap into the heater core supply and exit lines with tee fittings, run the hoses as you see fit and be done with it, quick and painless, correct?
Thank you for posting this. I like it.
Edit: Just finished checking out the other thread and it looks like the cooler needs to be plumbed in sequence to maintain pressure to force water through the cooler. Putting it effectively in parallel with something like the heater core won't work as well because the coolant will take the path of least resistance through the heater core.
Edit 2: Just finished reading the how-to portion of this thread more carefully and it looks like the cooler is installed in parallel and appears to work, so the other thread has bad information.
Can someone who knows please clarify this?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
