#29 | |
#30 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I went full engine back simply to save weight. Any power gains are merely an unnecessary but fun byproduct.
I should save ~49.5 pounds compared to stock.
#31 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
my car put down 176/151 on a mustang dyno with all i have is a perrin intake and catback (so no serious mods) i think breaking 200 is possible but like people said, how deep are your wallets. i think what i'm going to do is go the Header front pipe and get tuned then eventually go the SC route if the motors are holding up. but i really like the idea of being NA...there is some kind of je ne said quoi about being all motor. |
#32 |
Best bet is to go with a High Quality EL header, exhaust, Intake (if you want), and a tune.
From there you can decide where to go, and how much you want to spend, A lightweight flywheel and Clutch will help free up some rotational mass. As mentioned already, Carbon fiber Driveshaft, pulleys, wheels, etc. will help. you could go ab it further on the NA power with a Flex-Fuel tune, or keep an eye out for some good NA powermods like Cams, Intake Manifold, headwork to rev it etc. If you really just want 225whp and you don't care about staying NA then just go with a S/C kit, get the power you want (and more) and be done with it, for less money. The nice thing about going with a S/C is pretyy much all of the above "NA" mods will work with a S/C kit and gain you more power. Or go Nitrous
#33 |
Thats pretty neat
Drives: LOADING......
Surprised nobody is looking into higher compession for more power. If boosted guys are pushing 10psi on 93 with 12.5:1 cr im sure a bump up in compression is do able, and pretty easy.....assuming that shaving the head and block dont affect the DI spray angle negatively.
#34 |
Drives: AE86, 2x GT86, TE27
Toda hi-comp stroker kit will be out soon. If you're baller enough that is.
Read a comment above about just putting an innovate sc kit on. I thought that as well. So I bought one. 4 weeks later I took it off and sold it. Nothing beats NA. |
#35 | |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
Sure you're going to get weight reduction and a lovely look and sound from a full exhaust, but it's money better spent elsewhere first if you're going for speed. For just over the price of most full header-back exhausts you can get a CF driveshaft which is going to give you an immense benefit over the exhaust. And as far as FI goes, I wouldn't consider SC over a turbo. Especially the AVO kit. |
#36 |
Re final drive. Best way to calc what to get is to base in on your local race track.
Our gearing is pretty good in these cars, except for 5th to 6th, its a big jump, certainly not one you want to have to make on a race track. When calculating this way, also consider that you may have extra revs to play with. For example, my 200rwhp NA ae86 hits 5th gear limiter about 100m before I need to brake. That's with a 4.3 FD, which seems tall, but I run 195/50/15. In 5th (which is 1:1 like most 6 speeds) @ 8000rpm, its doing 202km/h. Changing the FD to 4.1, gives me 211km/h at the same revs in 5th. So, I know that for myself, I want to aim around that 210km/h mark for the new 86. Because, even if it gets to 200rwhp, it won't weight 900kg like the ae86 does. I run 205/40/17 semis on the new 86. And I'll work to my rev limit being 7800rpm. Based on that, 4.1 is ideal for me. Say if I swapped out to a 4.5, I'd only reach 194km/h in 5th. What I'm getting at, is don't just assume "ZOMG final drive is teh business!11!1!!one!" It moves all your gearing. You need to do your own calc before changing final drive. Your rev range, tyre circumference, and target speed at a particular point, are all critical variables. And I for one, certainly want to avoid the 5th - 6th change on the back straight. Last edited by diss7; 10-28-2013 at 05:37 PM. |
#37 |
Drives: Pavement MT GR86
For the money I'm doing headers ( hks el or nameless if they ever get released) 2.5"dp , tune, aluminium ds(Axel exchange ), light battery (shorai LFX 27/36) depending on money and juice required.
Seems to be the best bang for your buck so far.
GR86 MT premium
#38 |
Although after watching 2 Phantom electric superchargers on the dyno and the beautiful torque curve on them, I'm seriously considering it. I just wish it turned on below 80-85% throttle. But once they get the intake obstruction issues fixed (coming soon I hear) that thing is going to be an AWESOME and cost effective FI solution that can be removed in 30-45 minutes.
Seriously, Bob at Drift Office will set you straight. Exhaust should be an afterthought after you're done with everything else, unless you're going full FI. Even then, the gains didn't seem to be anything spectacular. |
#39 |
Yep like the others said I plan to stay NA and do header, tune, FD, and lots of lighter weight parts.
#40 | |
Drives: Passat
I'm not saying that 225whp NA isn't "possible" but has anyone actually done it? I've yet to see more than 210whp NA. |
#41 |
Drives: Mt Fuji Red 86 GT
I have heard of 2.1 or 2.2L overbore in Japan. Shortblock only. Forged pistons and i *think* lighter rods. Can't remember the company though. I would consider overbore/stroking providing it didn't compromise revs.
| Highest WHP | edamons | Engine, Exhaust, Transmission | 21 | 09-17-2013 05:53 PM |
| Highest HP on stock motor using only 93/94 octane? | hmong337 | Forced Induction | 11 | 09-09-2013 10:53 AM |
| Help! Need torque specs for motor mount | Pele86 | Engine, Exhaust, Transmission | 5 | 08-05-2013 04:24 PM |
| Torque specs for trans and motor mounts | jah29 | Engine, Exhaust, Transmission | 0 | 06-27-2013 09:53 PM |
| highest mpg possible | steve87j | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 12-28-2012 08:06 PM |
