Old 12-26-2012, 05:32 PM   #1
steve87j
steve87j's Avatar
Drives: Scion FR-S RAVEN
highest mpg possible
So guys I'm averaging 26.2 mostly city. I shift around 3k rpm. What's the best way to maximize mpg ?
1st seems like it chugs under 2k . So I tend to rev high to avoid the bumpy start.
Pointers?
steve87j is offline   Reply With Quote
Old 12-26-2012, 05:40 PM   #2
Celica00
Celica00's Avatar
Drives: 86
i get about 30 mpg when w/ mostly city driving, 34 if mostly highway (this includes plenty of 'spirited' revving)... it sounds stupid but treating the pedal like theres an egg inbetween your foot and the pedal really helps. also, when coasting in traffic or anticipating a stop or just general decelaration, always put the clutch in asap which acts as if your car is in neutral while youre still moving, greatly improves mpg
Celica00 is offline   Reply With Quote
Old 12-26-2012, 06:05 PM   #3
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
Ive gotten 29.8 over the first 2200 miles on the car overall. Thats less than 40% highway, and definitely some spirited driving
jshadeck is offline   Reply With Quote
Old 12-26-2012, 06:11 PM   #4
Shagaliscious
Drives: Firestorm FR-S (MT)
Wait...are you saying you rev it higher then 2k rpms when starting from a dead stop? That is very high, and you shouldn't need to do that. Not to sound like a jerk, but are you new at driving manual?
For me, recently i've been getting around 26mpg, I would say 50/50 driving, and I have fun driving it.
Old 12-26-2012, 06:23 PM   #5
that_one_guy
Drives: none
I think with no input on the gas pedal, the engine will try to stay at idle speed. If you are getting off the freeway for example and you push the clutch in to coast to a stop, you are spending that fuel needed to idle for the entire time you have the clutch in or are in neutral. If you leave it in gear however, the wheels turning connected to the engine will keep the engine spinning faster than idle so the engine will give no fuel. This saves fuel and brake pads, I just wouldn't recommend downshifting to brake.
Other tips are to start slow and if you are on flat ground going a constant speed, put it in 6th where you can put around at a low rpm. try to reduce inconsistent speeds, if you usually go on a road at 50mph, but you know there is a turn you have to slow to 30mph then speed back up, try just going 30 and never have to slow/speed up. If you are running errands, go to your furthest destination first, this will allow your engine to warm up completely so you get better mileage on the shorter runs back.
There are plenty of other ways but these are things that are easiest to change and most people don't think about when trying to get the most mpg. I'm at 31.5mpg now and I only drive city, less than 5 miles to work.
that_one_guy is offline   Reply With Quote
The Following User Says Thank You to that_one_guy For This Useful Post:
strat61caster (12-26-2012)
Old 12-26-2012, 06:25 PM   #6
Jpen115
Drives: 2013 Ultramarine FR-S
Im at 22 mpg. I suck.
Jpen115 is offline   Reply With Quote
Old 12-26-2012, 06:31 PM   #7
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Pointers?
highest mpg possible? ive done 42 mpgs all highway in one trip doing 65 i average about 31 on the display about 30-32 mpg between fillups 35 city/65 highway (i fill up 10.5 gallons when the light comes on)
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 12-26-2012, 06:38 PM   #8
Celica00
Celica00's Avatar
Drives: 86
that just means you have the most fun
Old 12-26-2012, 06:46 PM   #9
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I think 26.2 mpg mostly city driving is good.
I get just over 30 mpg, 1/2 city & 1/2 highway.
I would just have fun driving it without worrying about the mpg.
Sigh-on-Rice is offline   Reply With Quote
Old 12-26-2012, 06:51 PM   #10
Jpen115
Hahahaha thanks for making my negative a positive!!!
Old 12-26-2012, 07:46 PM   #11
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
One of the best places to check what people are experiencing fuel consumption wise is here:
http://www.fuelly.com/car/scion/fr-s/2013
This car, whether AT or MT appears to experience a very wide range of FE depending on driving style, ambient temperature, topography,trip length, you name it, it appears to have a noticeable difference.
My best FE so far is 46.9 100% highway with a worst of 25.2 100% city(winter short trip) based calculation from refuelling additions.
As you can see from the info on this site, normal is very broad!
smbrm is offline   Reply With Quote
Old 12-26-2012, 08:07 PM   #12
kanundrum
Drives: 2013 Whiteout FR-S
During break in long road trip to NY was getting 34mpg consistently
now its like Sub 25
Old 12-26-2012, 08:12 PM   #13
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I'm doing almost always city driving, and it's really freakin cold out and I get about 25 MPG. Anything better than that would be easy to acheive unless you have a heavy foot!
Rayme is offline   Reply With Quote
Old 12-26-2012, 08:15 PM   #14
ayau
Drives: Some rust bucket
Check your tire pressure and verify that it's about 35psi.
Highest mileage FRS\BRZ Grishbok BRZ First-Gen (2012+) — General Topics 199 09-22-2018 03:40 PM
Best cruising speed for highest MPG. BrandonFYIA Scion FR-S / Toyota 86 GT86 General Forum 95 03-29-2015 10:53 PM
Dynosty Turbo FR-S FA20 Highest Horsepower Record 324WHP Hal@Dynosty Forced Induction 363 11-19-2014 10:03 AM
Highest Mileage FR-S?!? BlaineWasHere Scion FR-S / Toyota 86 GT86 General Forum 6 12-03-2012 10:28 PM
highest price youve seen? fatoni Scion FR-S / Toyota 86 GT86 General Forum 11 08-22-2012 05:49 AM
