Old 10-28-2013, 08:50 AM   #1
Atropine
Drives: 2021 Toyota Supra 2020 4Runner
What is the highest HP/Torque going all motor?
Hi!
Love my BRZ. I am a huge enthusiast...that is why I bought the car.
I eventually want to do a "build".
Obviously, handling and throttle response is where I feel this car can be improved.
Wheels, Tires, breaks. Those are will be the first things for me to mess with.
Eventually I want to get a little more power out of the engine.
In the past I have had larger engines (350Z, SRT8 Challenger...6.4 liter).
I have had Turbos (2011 STI)
I have had a Supercharged Car (88 MR2 S/C)
I never really enjoyed my STI. Great car, but I missed the instant throttle response of a N/A motor or even a S/C motor.
So I am guessing I will go with a S/C or try to do smaller changes to engine to remove the torque dip.
Idea...
Full Exhaust
CAI
Reflash
New larger injectors?
Down the road...new Cams should be available?
Or is the S/C just the way to go?
I put a ton of time and money into the 350Z for very marginal gains.
While the S/C MR2 was easy...swapped 2 pulleys and boom more power.
Anyway, I have been doing a TON of research on here. I am just curious what kind of numbers people are getting from staying N/A.
I have seen what appears to be reliable 250HP 200ft/lbs torque from S/C. (WHP #'s here)
Wonder if 225 HP/ 175 ft/lbs torque is attainable? (going N/A)
With the engine already having such high compression pistons...I wonder if it had all of the power already wrung out?
Atropine is offline   Reply With Quote
Old 10-28-2013, 08:57 AM   #2
TwinturboCamry
Drives: 4 wheels
Of course 225 NA is possible. How big is your wallet?
TwinturboCamry is offline   Reply With Quote
The Following User Says Thank You to TwinturboCamry For This Useful Post:
suaveflooder (10-28-2013)
Old 10-28-2013, 09:02 AM   #3
WhiteFR-S
Drives: 2013 BRZ MT WRB
i got 191.4 hp/ 151.9 torque with just borla headers, k&n, berk muffler delete and a tune on 93 octane. so you could get a few more maybe with replacing the rest of the exhaust components. Then you would probably have to go internal if you wanted to keep it n/a.
WhiteFR-S is offline   Reply With Quote
Old 10-28-2013, 09:03 AM   #4
Atropine
LOL afraid of that answer!
I don't want to go down that road again.
Will keep scanning looking forward to builds.
There must be a reason that most builds end up going the FI route.
Old 10-28-2013, 09:05 AM   #5
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Highest RWHP *FULL* Bolt-Ons? (Looking for 200-215)
na hp
Max NA HP on pump gas as of now?
Have you hit 200whp NA?
Most power Normally Aspirated?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following 6 Users Say Thank You to Anthony For This Useful Post:
ATL BRZ (10-28-2013), Atropine (10-28-2013), Hawaiian (10-28-2013), Marchy (10-28-2013), MaXimus (10-29-2013), suaveflooder (10-28-2013)
Old 10-28-2013, 09:08 AM   #6
TwinturboCamry
Drives: 4 wheels
That's because it's easy to make power on boosted cars. For 500 bucks you can pick up 70 tq and 25hp on a GTI. I'm sure you knew that with your STI
Old 10-28-2013, 09:14 AM   #7
ft_sjo
Drives: GT86
I don't know of many modern 2 litre engines that won't break 150bhp/litre with enough money spent on them. I'm not talking about bolt-ons, either. You'd need to find a proper engineer/engine builder.
Old 10-28-2013, 09:21 AM   #8
Atropine
Yeah...can always go to machine work and forged internals (though I think our car already has forged internals?)
Pipe dream from my AW-11 days...the Formula Atlantic motor. Though it was essentially 25 grand for that (not willing to spend that).
@Anthony TYVM for the links. I had found 2 of those...seems there hasn't been someone to nail it down yet.
I guess what I really need to look into is which S/C I am going to get lol.
The Following User Says Thank You to Atropine For This Useful Post:
Anthony (10-28-2013)
Old 10-28-2013, 09:24 AM   #9
Anthony
Weight Nazi
Anthony's Avatar
Yeah, the general consensus seems to be that the stock throttle body is already pretty big, no one makes an intake manifold, and the factory cams are good enough that there probably won't be any good off-the-shelf aftermarket ones available for a while, as all the companies are still mostly focused on boost. Best you can do for now without breaking the bank is I/H/E and a tune.
Old 10-28-2013, 09:26 AM   #10
Anthony
Weight Nazi
Anthony's Avatar
Oh, and E85, of course. If you're so lucky.
Old 10-28-2013, 09:34 AM   #11
FR-S Matt
Exactly what I'm doing on 93 octane. Waiting a few years on FI due to cost and monitoring reliability of kits.
My only beef with E85 is the fuel lines, lack of gas stations that cary it, and the car not being designed around it. I'm sure it works outstanding for some and the power boost is great, but for a daily driver, killing my gas mileage for more power doesn't make much sense.
Old 10-28-2013, 10:27 AM   #12
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I'm lucky to be in the midwest. There is an abundance of E85 here so I run it almost exclusively in the summer. Due to cold start issues, and snow i go back toy stock tune for the winter to keep the spinning tires down.
Althogh your mpg may go down, the cost per gallon is down as well and my actual cost per mile on 85 is below 93 at least here in the midwest.
I've also run it in my car for well over 15k miles inclucing several autocrosses with no adverse effects.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 10-28-2013, 10:53 AM   #13
Anthony
Weight Nazi
Anthony's Avatar
I talked to several people about the fuel lines, pump, and stuff, and I was reassured that it would be fine long term. I think it was in this thread: http://www.ft86club.com/forums/showthread.php?t=45155
Old 10-28-2013, 11:09 AM   #14
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Really? Those are two of the best things about this car in stock form.
campy is offline   Reply With Quote
Highest WHP edamons Engine, Exhaust, Transmission 21 09-17-2013 05:53 PM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
Help! Need torque specs for motor mount Pele86 Engine, Exhaust, Transmission 5 08-05-2013 04:24 PM
Torque specs for trans and motor mounts jah29 Engine, Exhaust, Transmission 0 06-27-2013 09:53 PM
highest mpg possible steve87j Scion FR-S / Toyota 86 GT86 General Forum 29 12-28-2012 08:06 PM
