#29 |
Thanks
I usually read T day to T day. Thanksgiving to Tax day (april 15).
I usually start watching the forecast november and put them on when the first snow is forecast. Take them off begin of april. I'm in NY so may not apply to canadians and lake dwellers. |
#30 |
Drives: 2013 Scion FR-S (Argento)
My father in law is absolutely convinced you can put snow tires on just the rears of any RWD car. I keep telling him he's nuts and any performance car needs all four winter shoes. Is he wrong, or am I?
#31 |
Drives: WR Blue BRZ, 240Z
For those of you waiting to put your winter tires on, you're doing it all wrong.
Summer tires are designed to operate in temperatures above 40-45F. Below that temperature the rubber compound that makes these tires so wonderful in warm temperatures makes them "less then optimal" in near freezing temperatures and down-right dangerous in sub-freezing temperatures. Yes, winter tires are designed to give superior handling on snow and ice, but the rubber compounds used in these tires also provide superior handling to Summer and even All Season ties below 45F. So this time of year, why in the world are your winter tires in your basement or garage? Put 'em on the damn car where they belong.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
| The Following User Says Thank You to Gary in NJ For This Useful Post: | Mister (11-22-2013) |
#32 | |
Drives: Traded BRZ for Supra
| The Following User Says Thank You to avp1 For This Useful Post: | AznBRZer (11-20-2013) |
#33 |
If he wants to end up in the ditch, this is almost a sure way!
#34 |
#35 |
Second question:
Is the TMPS kit from Tire Rack a good deal, or should I go about that part of the winter tire equation another way? |
#36 | |
Drives: 2013 Satin White Pearl BRZ Premium
I have personally tested on the stock summers and my winters (Dunlop Wintersport 3D's) over the last few weeks and summer tires where fine in 40 and some 36F morning commute. Since I bought one of these [IMG] [/IMG]I've swap my summers and winters 4 times in the last 3 weeks. Yeah crazy I know. |
| The Following User Says Thank You to caradd For This Useful Post: | AznBRZer (11-20-2013) |
#37 |
Drives: 2013 Subaru BRZ Limited SWP
i read on tire rack i think they suggest when the temperatures are consistently below 40 degrees that is when you put your snow tires on.
#38 | |||
Drives: 16 CBS WRX Limited
#39 |
Drives: 2014 FR-S MT Asphalt Grey
No need for winter tires until temps are continuously below 40 degrees as previously stated. The tires on our cars are not summer only tires.
TPMS are not needed on a set of winter wheels/tires, if you can deal with the light. In MA there is no law requiring them and you cannot be failed at inspection for it. Save yourself the money for other useful things. I suggest a quality air pressure gauge which should be used frequently as opposed to relying on a sensor. |
#40 | |
Drives: 2013 Scion FR-S Whiteout 6MT
#42 |
I was under the impression that most shops won't install non-OEM tires without TPMS installed. Is that incorrect?
| Wheel Directory: OEM Subaru Impreza STi (JDM 2001) 17x7.5 +53 | wtout86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 11-29-2015 05:26 PM |
| Winter tires ? | bk201_q8 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 10-19-2013 08:08 PM |
| Anyone in NC put on winter tires? | Elgancho | Southeast | 0 | 01-26-2013 01:13 PM |
| Hate the Tires I got with my winter tires | PoRco | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 01-01-2013 12:49 AM |
| Winter Tires? | joergasm | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 10-04-2012 12:02 AM |
