Old 05-04-2014, 10:34 PM   #29
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 05-08-2014, 08:05 PM   #30
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged @tiz22's topic = same wheel w/ same spec
The Following User Says Thank You to DarrenDriven For This Useful Post:
tiz22 (05-08-2014)
Old 07-01-2014, 07:49 PM   #31
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Originally Posted by tiz22 View Post
Just put on my summers after a ridiculously long winter
TSW Interlagos (matte black) 17x8+35 with Michelin Super Sports 225/45/17
Stock suspension
Ride feels great. Love this setup!
Hey, a couple of questions from down the 401:
How do you like the PSS? I'm thinking of either them or the Conti ExtremeContact DW in the same size.
How do you like the steering feel with the +35 offset? I'm thinking of getting some 720Form GTF1s in 17x8 because they are cheap, light and available here through 1010, but they only come in +35 and I am worried about screwing up the steering feel. That is the best thing about the twins, IMANHO.
Talus1 is offline   Reply With Quote
Old 07-03-2014, 11:30 PM   #32
tiz22
tiz22's Avatar
After my setup, every aspect of handling has either gotten better or stayed the same. Nothing worse.
The PSS are nice and sticky so you can fly around corners without losing grip. The pickup is also a little nicer too
The +35 hasn't really changed the steering at all from what I've found. Like I said since I changed out OEM it has only gotten better and more responsive
The Following User Says Thank You to tiz22 For This Useful Post:
Talus1 (07-04-2014)
Old 09-03-2014, 01:44 PM   #33
fguadamuz
Drives: 2013 BRZ Silver M/T
Originally Posted by PNW FRS View Post
17 x 8 / 35 offset (sq.) TSW Interlagos Wheels / Mich PSS 225/45/ZR17 / Stock suspension
EDIT (7/2/14): Installed coilovers and dropped. The +35 still works fine.
I'm interested in getting this setup with stock suspension as you had it first but also thinking of getting 1in drop springs. How much are you lowered on the coilovers? What camber settings did u have at stock and lowered? Did you get lcas as well?
fguadamuz is offline   Reply With Quote
Old 09-03-2014, 10:16 PM   #34
PNW FRS
PNW FRS's Avatar
1.25" drop -- front and back
-2.0 camber in front with coilovers
* Don't know what the camber was with stock
Did not get LCAs
Now that I've had the rig dropped for a few months... still happy with the setup. There is still an occasional "clunk" or minor spring-wind noise... but it's not a big deal.
For my DD... it's fine.... hoping to do some HPDE at some point in the future... it will be interesting to see how this setup works then!
The only "downside" of the drop is I have to be REALLY careful around curbs, parking blocks, etc. Luckily all the minor scrapes and such are "down low" and can't be seen... but I'd hate to crack the front bumper cover higher-up through a freak contact with something concrete!!
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 12-09-2015, 04:37 PM   #35
Benschneider06
Benschneider06's Avatar
Drives: Satin White Pearl Subaru BRZ
Question
Temperatures are on the rise in SW Washington... so finally swapped OEM out... snow tires will eventually go on OEM wheels.
Front-left
Left-rear
Left-rear
Props to the Discount Tire in Lacey... they had me in and out in 30 minutes... and it might have been quicker, but once the rig was up on the hoist, most of the staff suddenly had something "to do" at that hoist. Cost: $0 -- what better way to start a Saturday?
Observations: With a bit of reduced weight (per wheel) and the stickier tires... acceleration (1st, 2nd) is a bit more fun... and the difference in turns is every evident (over OEM)... sticks even better in the hard, aggressive turns. Liking this setup a lot!
WOW that looks good!
How many inches did you drop in the front & the back?
Benschneider06 is offline   Reply With Quote
Old 12-10-2015, 02:20 AM   #36
PNW FRS
PNW FRS's Avatar
Originally Posted by Benschneider06 View Post
WOW that looks good! How many inches did you drop in the front & the back?
Approx. 1.3" drop.
And just switched to Conti ExtremeContact DWS06 shoes... much better for the cold temps and wet... we'll see if it snows...
2013 Asphalt / MT
Olympia, Washington
Old 03-07-2017, 11:21 PM   #37
mbrs1.0
Drives: 2015 FRS RS 1.0
Just installed the Interlagos. Same setup as OP, Michelin PSS 225/45. With TRD springs. Name:  IMG_1488905344772.jpg
Sent from my SM-G928V using Tapatalk
mbrs1.0 is offline   Reply With Quote
The Following User Says Thank You to mbrs1.0 For This Useful Post:
Lynxis (03-07-2017)
Old 03-07-2017, 11:44 PM   #38
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by mbrs1.0 View Post
Just installed the Interlagos. Same setup as OP. With TRD springs. Attachment 150580
Thumbs up! Your car looks great! I was planning to get a set of these with the mirror cut finish but before I could solidify the funds, the CAD tanked and now they are way out of my price range.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
mbrs1.0 (03-08-2017)
Old 03-08-2017, 02:48 PM   #39
mbrs1.0
Thanks!
That sucks. Check autoanything.com. They might be able to lower the price for you.
Lynxis (03-08-2017)
Old 12-24-2018, 12:18 AM   #40
Jpembry
Drives: 2019 Subaru BRZ Series.Gray
anyone know if these will clear PP brakes?
Jpembry is offline   Reply With Quote
Old 12-26-2018, 09:14 PM   #41
Lynxis
Lynxis's Avatar
I can't promise they will clear the PP brakes in particular but I've seen a set on a car with AP sprint kit and had plenty of room for something even larger. The spoke profile will facilitate most brake kits.
Old 12-27-2018, 10:37 AM   #42
Jpembry
cool, yea it seems like clearance would be ok!
Wheel Directory: TSW Interlagos 18x8.0 +35 denkigrve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 03-19-2014 04:01 PM
XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop AGM6789 AUSTRALIA 17 11-10-2012 06:10 AM
Photoshop needed! Asphalt FR-S on TSW Interlagos! selandej Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 11-07-2012 04:40 AM
>>> GREAT DEAL-ALL TSW MODELS: Nurburgring/Jarama/Interlagos/Donington & ALL OTHERS BestWheelDeals Wheels and Tires 9 09-21-2012 03:10 PM
TSW Interlagos Rotary Forged Wheels Eric@GetYourWheels Wheels and Tires 9 08-01-2012 01:15 PM
