Old 08-11-2013, 02:30 AM   #29
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
You guys using the fumoto valve, one with nipple, short nipple or no nipple? Wondering what clearance there is and how much these actually protrude? Thanks
Old 08-11-2013, 08:45 AM   #30
Foobar
SLO NO MO
Foobar's Avatar
Short nipple is tucked within the aluminum under panel. The long nipple protrudes past it.
Sent from my Nexus 4 using Tapatalk 2
The Following User Says Thank You to Foobar For This Useful Post:
OICU812 (08-11-2013)
Old 08-11-2013, 11:20 AM   #31
DJCarbine
Thupercharged
DJCarbine's Avatar
If I didn't already use an oil extractor to do my changes I would go with the fumoto valve
2013 FRS
Vortech V3 11psi
Old 08-19-2013, 09:59 PM   #32
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
I have an oil extractor from a previous car. How much oil are you getting out? I would love to continue to use the extraction method.
TheseColorsDontRun is offline   Reply With Quote
Old 08-19-2013, 10:01 PM   #33
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Whatever you do, stick to the short nipple.
tech4pdx is offline   Reply With Quote
Old 08-20-2013, 09:00 AM   #34
DJCarbine
Thupercharged
DJCarbine's Avatar
All of it. Cracked the drain plug after I used it the first time and only a few drops came out.
I have a DIY thread on it, I remove the oil dipstick tube as it only takes a minute and then I can use the largest hose size for speed
Getting a fumoto valve for my parents car for sure though, no way to easily use the oil extractor on their corolla
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
TheseColorsDontRun (08-20-2013)
Old 08-20-2013, 09:27 AM   #35
TheseColorsDontRun
Excellent, then I'll continue using the extractor method.
Old 08-20-2013, 09:52 AM   #36
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by chenshuo View Post
ok just placed my order. Damn shipping to Canada cost almost the same as another valve...
Actually, its the Canadian government insisting on you using a customs broker to collect their lousy GST or HST. You don't even know that you hire a customs broker but you do.
Your shipper could just mail it to you and it likely would get through without these surcharges, or get a friend in the US to buy it and mail it to you as a tax exempt "gift". You can "give" him some money if you like. Maybe the two gifts will match in value.
Suberman is offline   Reply With Quote
Old 09-07-2013, 06:19 AM   #37
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
If you get the long nipple it's fine the tip needs to be dremelled off
448hpsti is offline   Reply With Quote
Old 09-08-2013, 09:19 PM   #38
BRZnut
Drives: BRZ DGM Limited
Which extractor do you have ?? And, can you direct me to your DIY?
Old 09-08-2013, 09:23 PM   #39
DJCarbine
Thupercharged
DJCarbine's Avatar
Info in this thread
http://www.ft86club.com/forums/showthread.php?t=32427
2013 FRS
Vortech V3 11psi
Old 09-08-2013, 09:27 PM   #40
TheseColorsDontRun
http://www.pelaproducts.com/
That's what I use. There really is no DIY necessary. Drive a bit to warm the oil, remove your dipstick, stick the extractor hose in the dipstick tube and start pumping (now would be a good time to unscrew your oil filter and let drain). The oil from the oil pan will be sucked into the container. Pump more when the flow slows. Keep extracting until you hear gurgling. Pump some more until you're sure no oil is left. Replace your filter, remove the extractor, replace your dipstick, fill oil, check level and you're done.
Edit: I'm slow, the DIY was posted in the response before mine. That thread is good to check if your extractor has a larger tube than your dipstick tube can handle.
Old 09-10-2013, 02:11 PM   #41
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I currently have Greddy Magnetic plug. no problem at all.
It really depends on person's preference. I personally like to unbolt and drain the oil.
cant trust myself that safety mechanism might break or something even thought it won't.
who knows, i might switch to Fumoto later to try out.
Old 09-10-2013, 09:43 PM   #42
OICU812
Just a dude
OICU812's Avatar
The Pela product looks interesting especially for folks like myself who like to do things at home and dont have a lift etc.. I do wonder however is it getting "all" the oil out and how about small particles of metal and so fourth?
Fumoto valve quick question #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 130 11-21-2015 04:32 AM
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 01:51 PM
