Old 05-11-2015, 12:15 PM   #29
FR-Shred
FR-Shred's Avatar
Originally Posted by Cope52 View Post
Are these the same thing, the "triple C". they look different. Amazon.com: H&R TC112 'Triple C' Camber Adjustment Bolt - Pair: Automotive
If you look at the picture on amazon with them in the actual package they look more like the one pictured earlier.
Also I would look on eBay cause I got mine for $35.
FR-Shred is offline   Reply With Quote
Old 05-12-2015, 02:45 PM   #30
Cope52
Drives: 2014 BRZ
I also found these. They only seem to be available from overseas.
http://www.subispeed.com/2013-subaru...g#.VVJKJJMmkuG
Originally Posted by LeeMaster View Post
I cannot stress this enough, when I changed my rear differential fluid with Motul 300, my clutch engagement point felt smoother.
Cope52 is offline   Reply With Quote
Old 05-12-2015, 05:26 PM   #31
FR-Shred
FR-Shred's Avatar
You can get those at a few online shops.. I think ft86speedshop has them even.
Old 05-12-2015, 06:55 PM   #32
CallmeDave
CallmeDave's Avatar
Drives: 13 BRZ, 07 WRX
So Is this confirmed because it seems way better than paying $200-$600 for arms to fix camber after lowering 1in.
13 BRZ Premium. 07 WRX.
CallmeDave is offline   Reply With Quote
Old 05-12-2015, 08:57 PM   #33
FR-Shred
FR-Shred's Avatar
Yes, but like others have said it only adjusts +/- .5 so not a lot but can even out the sides or add a little more if you want.
LCA can add a TON more camber but cost a lot more money. But for a 1" drop you 1. might not even need these bolts. 2. the bolts would work to make sure you're even on both sides.
The Following User Says Thank You to FR-Shred For This Useful Post:
CallmeDave (05-13-2015)
Old 05-13-2015, 09:23 AM   #34
CallmeDave
CallmeDave's Avatar
Would the OEM Crash bolts work just as well? I imagine they would be cheaper.
Old 05-13-2015, 10:19 AM   #35
bfrank1972
Drives: 2013 FR-S Argento
No, wrong size, you have to use proper size/strength bolts. Don't cheap out on this, last thing you want is for them to shear and have your lower control arm collapse.
bfrank1972 is offline   Reply With Quote
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SPC/Whiteline front camber bolts in GTA? f0rge CANADA 2 03-20-2013 10:56 PM
