Old 02-19-2013, 04:43 PM   #29
Retro86
Retro86's Avatar
Drives: Awesome
Originally Posted by Sco2355 View Post
It's not that it isn't recommended, people just don't want the dead spot where the "auto" lights are. I plan on hooking up the auto lights later when I do the other conversions (GT86 headlights, seat heaters, dual climate, etc). Just personal preference. The big thing we are finding out is Toyota and Subaru kept a lot of stuff there between the trim levels, just removed the extra bits and some of the wiring to them.
im also considering to convert to the gt86 trim and i will start off with the foglights. and i would want that auto spot, but what whats hooked up in the "auto" spot anyway?? the leds for the headlights??
Retro86 is offline   Reply With Quote
Old 02-19-2013, 05:00 PM   #30
d1ck
Drives: Black 2013 FRS
To the OP:
I may have misunderstood, but it seems like you're powering your fogs through the stalk, and not using a relay. This is a bad idea, as the fogs when turned on pull about 10 amps. The switch in the stalk likely isn't made for this much current, so you should install a relay ASAP.
For reference: 2 x 60watt bulbs = 120 Watts
P = I x V
120 = I x 12 (Car is a 12v system)
I = 10 Amps
d1ck is offline   Reply With Quote
Old 02-19-2013, 06:30 PM   #31
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
i wired my fogs to a seperate switch. i'll wait somebody do the prius or tundra stalk before doing in mine. lol
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 02-19-2013, 06:42 PM   #32
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Subarupartsforyou.com now has the stalk listed:
http://subarupartsforyou.com/cp_part...p?partid=23294
kmbkk is offline   Reply With Quote
Old 02-19-2013, 08:12 PM   #33
Sco2355
Originally Posted by d1ck View Post
To the OP:
P = I x V
I = 10 Amps
Power is actually coming from a separate cable ran from the battery with an inline fuse. The switch on the stalk is only acting as an on and off and it's wired to the grounds.
Sco2355 is offline   Reply With Quote
Old 02-19-2013, 08:18 PM   #34
zooki
Drives: waiting on a 2021...
Well, if that's the only place you have the lights grounded, the power will flow from the battery, through the lights, and through the ground. That completes the circuit. You really shouldn't put that many amps through that small of wire. It should be the same size as the power wire.
zooki is offline   Reply With Quote
Old 02-19-2013, 08:38 PM   #35
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I meant to mention this earlier.
OP, he's correct. You could easily smoke your new stalk.... at minimum.
FRSFirestorm is offline   Reply With Quote
Old 02-19-2013, 08:50 PM   #36
FRSFirestorm
Red is Fastest
Another tidbit from the wiring diagrams. If the wire from pin 30 of Body ECU happens to be found under the hood somewhere.... you won't need to run any wires through the firewall to turn on the fogs.
Old 02-19-2013, 09:10 PM   #37
FRSFirestorm
Red is Fastest
And appears the fogs should only come on if the parking/tail lights are on.
Old 02-19-2013, 10:21 PM   #38
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Op, why didn't you buy a pre-made hardness? It would have made things way easier on you/safer.
Juanito08 is offline   Reply With Quote
Old 02-19-2013, 10:39 PM   #39
Sco2355
If I understand what you're asking, there wasn't a place and the fuse box had no terminals going to it either. At the time I didn't have the means of doing it.
This is true too, but I wanted to be able to turn them on even with no lights on.
If you are referring to a harness like Nigel's, I just didn't want to have a button that I'd have to either place somewhere or hide. I wanted a more OEM look and I planned on making the auto lights work later on, hence why I wanted the stalk.
I have been using the comments y'all have been giving me and doing more research into the wiring myself. The wiring is going to change soon to be safer/more reliable. Sorry my first attempt was somewhat of a ghetto one.
Old 02-19-2013, 10:59 PM   #40
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
You don't "need" a switch, you can still have the oem look. Instead of using the switch from the harness you would just use the stalk, because that's basically what it is a "switch"
Old 02-19-2013, 11:01 PM   #41
zooki
I wasn't trying to criticize you. Just didn't want to see you melt anything. Thanks for identifying what wire we need to tap into if we want to run the stalk. Appreciate it!
Old 02-19-2013, 11:11 PM   #42
Sco2355
Yeah I guess I didn't really look at it that way.
By no means did I take it in a negative way. Wiring in a vehicle is still new to me. It's a learning experience and I'm glad that people here like what I have found and are helping refine it. This is why I love this community! All the car forums I've been on will tell you it can't be done, then when you prove them wrong they tell you it's dumb and a waste of money. No help at all, but this place is the exact opposite!
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
