Old 07-16-2013, 06:55 PM   #29
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Different from the WRX rear rotor by a couple millimeters. It's the 2010 LGT rotor; there was an LGT through 2012.
Yeah, you're right. But I'm pretty sure the two are interchangeable (isn't one like 316mm and the other 312mm?) in practice, and I know some aftermarket sources list the same part for both applications.
It's used on turbo Foresters too.
Admiral Ballsy is offline   Reply With Quote
Old 07-16-2013, 07:02 PM   #30
OrbitalEllipses
Drives: Attitude
Here's some Centric diagrams:
2013 BRZ:
2010 LGT:
2008+ WRX:
2008+ STI:
Note that the 2008+ WRX does not have vented rears.
Old 07-17-2013, 03:28 AM   #31
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Draco-REX View Post
I find that very surprising. Still, doesn't change the part numbers for the Limited which are wrong.
I don't understand the confusion. In Australia where they do have a model with the smaller brakes then they are listed correctly and seeing as they are an Australian company I can understand that they would provide listings for these. Have you considered they may not have been aware that the American models are different? You just have to be aware of this when ordering from overseas. This isn't uncommon, we regularly have the same issue over here when buying from you lot over the pond
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-17-2013, 09:21 AM   #32
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If I were ordering from an Austrailian vendor, I would accept that. But I think you missed my post where I said:
Unfortunately, they are marketed to the US market as the appropriate parts in both their published jobber catalog and our in-house EPC.
And might I also remind you, these are the low-spec rotors and they are listed for the Limited which is the top-spec in this market. I didn't order them for a Premium.
And do we know if the correct rotors have the "Kangaroo Paw" vanes?
Old 07-17-2013, 01:42 PM   #33
Kodename47
Kodename47's Avatar
Drives: UK GT86
Might just be a case of the US vendor using the Australian EPC etc. I doubt that DBA themselves would change that so you can't really blame DBA.
I thought the cooling vanes would be used on all vented discs. Seeing as the incorrect ones you had were not ventilated discs then that'd be why they didn't have the kangaroo paw vanes (I'd assume).
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-17-2013, 03:48 PM   #34
Draco-REX
Corner Junkie
Draco-REX's Avatar
Fronts were vented with radial vanes.
There was a * by the "Kangaroo Paw" picture on the box that said not all rotors have those. So, ultimately, if a particular set of rotors don't have their special vane design (which I would like since it increases surface area for cooling) then there's no reason to get the DBAs.
I'm just saying that due to their lack of due diligence, I had an afternoon go pear-shaped on me when I dicovered halfway through a full brake job that the rotors I ordered were 100% not what I was expecting. Wrong size, improper venting, and not even the DBA venting design. That completely soured me to the brand.
I guess my point is, double-check everything because you can't be sure they've verified the fitment. And if the rotors don't have the DBA "Kangaroo Paw" then don't pay extra for them.
Old 07-17-2013, 07:45 PM   #35
Kodename47
Kodename47's Avatar
Drives: UK GT86
Actually that was very much what I was trying to say and hopefully this thread with correct part numbers for front and rear should prevent the same thing from occurring.
Van anyone confirm that he 4000 series front and rear disc come with the kangaroo paw ventilation? @FT-86 SpeedFactory?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-17-2013, 08:08 PM   #36
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Kangaroo Paw Confirmed on the front FRS DBA 4650S
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
DBA T3 rotors fitted AVOturboworld Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-16-2013 02:28 PM
Color, how important is it to you? Iixii BRZ First-Gen (2012+) — General Topics 63 11-09-2012 10:25 AM
OptionJDM - DBA Rotors OptionJDM Brakes, Suspension, Chassis 6 07-21-2012 11:50 AM
StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-13-2012 10:58 AM
How important is an LSD on this car? colHolm Scion FR-S / Toyota 86 GT86 General Forum 92 05-13-2011 05:53 PM
