Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
06-04-2013, 12:39 PM | #29 |
Ridge Racerrrrrrrrr
Yes, a lot of people have done this already. I have been reading it on the forums for months now.
06-04-2013, 12:41 PM | #30 |
Drives: Scion FR-S
06-04-2013, 01:06 PM | #31 |
Drives: Scion FR-S
For anyone interested i found this http://www.ft86club.com/forums/showt...wheels+spacers
The Following User Says Thank You to phloozy For This Useful Post: | P86RAVES (09-11-2014) |
07-31-2013, 09:07 PM | #32 |
Drives: Scion FR-S
where can i get these spacers asap?
08-01-2013, 12:59 AM | #33 |
Technically they are "Adapters" when the spacer bolts up to the existing hub.
Adapters are usually 20mm and larger. Spaers are anywhere from 3mm to 20mm. Lots of people make "Adapters" H&R, Ichiba, Etc Etc... Look for Hubcentric ones... I believe the OP of this thread sells the spacers through their business. If you want to pickup locally, I know a few dealers in your area. |
08-01-2013, 09:25 PM | #34 | |
Drives: Scion FR-S
08-01-2013, 11:51 PM | #35 |
Time Traveller
OEM+++
Springs and Spacers/adapters (spacers a week back, springs today). I bought the adapters from another vendor (no threadjack here) and had them shipped (arrived in 3 days). 20mm front, 25mm rear. Springs should settle to -1.0" to 1.18" F and -1.20" - 1.30" rear". Will work till I figure out exactly what to do for wheels (both track and street). |
The Following User Says Thank You to DAEMANO For This Useful Post: | ML (08-05-2013) |
08-02-2013, 07:11 PM | #36 |
We used ICHIBA hubcentric version II spacers. (bolt-on) type.
15mm / 17mm / 20mm / 22mm / 25mm / 27mm / 30mm <-Available sizes. |
08-02-2013, 07:25 PM | #37 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I used 20mm H&R spacers for the front and 30mm H&R spacers for the rear. Went with some 18x7.5 wheels and a 1" drop. I really did like the way my Volks looked with the spacers on (besides the fact that the spacers were aluminum in color - need to anodize them black), but in all honesty the car drives better without the spacers on. I've been driving w/o spacers for the past 3 weeks and I feel the car has more responsive steering and generally just feels better. I'm going to experiment with maybe just leaving the spacers on the back and not having anything for the fronts. It might look a little funny, or I might just do spacers all around again "just for looks".
08-02-2013, 07:45 PM | #38 | |
Order from the OP in this thread, they have an online store. |
08-04-2013, 01:59 PM | #39 |
Drives: FRS(sold), AP2, R35, FJC, ED9
08-05-2013, 03:42 AM | #40 |
Drives: Passat
Not even close. The minimum safe thread engagement is 12mm or 10 turns. Take a lug nut off and count how many turns it takes until tight. Subtract 10 turns from that number and multiply that by 1.25 to get your max spacer thickness.
The Following User Says Thank You to Fast_Freddy For This Useful Post: | garfull (08-05-2013) |
08-05-2013, 04:19 AM | #41 |
Longer wheel studs are a must with "spacers" most of the time. The only time it is not is if it is a 3mm spacer but those are garbage (most are cast aluminum).
If you are unable to do the wheel stud change yourself, the extra cost may be so much that selling what you have and buying the proper fit wont be out of the question. |
08-05-2013, 03:05 PM | #42 |
That's basically the same as general rule of thumb of needed 1 bolt diameter worth of thread engagement, but used to figure out the max spacer size. I'll have to try this method. I figured 10mm is too thick but many have stated that they've used 5mm spacer on oem studs without issue.
Similar Threads | ||||
Ichiba and H&R Wheel Spacers on Sale!! Check It Out!! | Mike@CZP | Wheels and Tires | 363 | 06-17-2018 03:38 AM |
Pictures of lowered FR-S/BRZ | nocurfew | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 146 | 03-26-2014 05:18 PM |
How to avoid scraping your lowered vehicle | PMok | DIY (Do-It-Yourself) Guides | 9 | 11-20-2012 07:49 PM |
anyone with their car lowered ~2.8in! | white86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 08-18-2012 11:54 AM |
H&R Wheel Spacers! | vividracing | Wheels and Tires | 3 | 06-19-2012 05:11 PM |
