Old 06-04-2013, 01:39 PM   #29
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by phloozy View Post
someone must have done this
Yes, a lot of people have done this already. I have been reading it on the forums for months now.
Old 06-04-2013, 01:41 PM   #30
phloozy
phloozy's Avatar
Drives: Scion FR-S
hmm i tried searching, could you link any pictures?
Otherwise I'll search harder
phloozy is offline   Reply With Quote
Old 06-04-2013, 02:06 PM   #31
phloozy
phloozy's Avatar
Drives: Scion FR-S
For anyone interested i found this http://www.ft86club.com/forums/showt...wheels+spacers
The Following User Says Thank You to phloozy For This Useful Post:
P86RAVES (09-11-2014)
Old 07-31-2013, 10:07 PM   #32
Teknian_Culprate13
Teknian_Culprate13's Avatar
Drives: Scion FR-S
where can i get these spacers asap?
Teknian_Culprate13 is offline   Reply With Quote
Old 08-01-2013, 01:59 AM   #33
KONVERTER
KONVERTER's Avatar
Technically they are "Adapters" when the spacer bolts up to the existing hub.
Adapters are usually 20mm and larger. Spaers are anywhere from 3mm to 20mm.
Lots of people make "Adapters" H&R, Ichiba, Etc Etc...
Look for Hubcentric ones...
I believe the OP of this thread sells the spacers through their business.
If you want to pickup locally, I know a few dealers in your area.
KONVERTER is offline   Reply With Quote
Old 08-01-2013, 10:25 PM   #34
Teknian_Culprate13
Drives: Scion FR-S
send me over im in south orange county where can i go? to get a good deal though other wise i was thinking ebay but i dont know what size?
Old 08-02-2013, 12:51 AM   #35
DAEMANO
Time Traveller
OEM+++
Springs and Spacers/adapters (spacers a week back, springs today). I bought the adapters from another vendor (no threadjack here) and had them shipped (arrived in 3 days). 20mm front, 25mm rear. Springs should settle to -1.0" to 1.18" F and -1.20" - 1.30" rear". Will work till I figure out exactly what to do for wheels (both track and street).
The Following User Says Thank You to DAEMANO For This Useful Post:
ML (08-05-2013)
Old 08-02-2013, 08:11 PM   #36
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
We used ICHIBA hubcentric version II spacers. (bolt-on) type.
15mm / 17mm / 20mm / 22mm / 25mm / 27mm / 30mm <-Available sizes.
Touge Factory is offline   Reply With Quote
Old 08-02-2013, 08:25 PM   #37
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I used 20mm H&R spacers for the front and 30mm H&R spacers for the rear. Went with some 18x7.5 wheels and a 1" drop. I really did like the way my Volks looked with the spacers on (besides the fact that the spacers were aluminum in color - need to anodize them black), but in all honesty the car drives better without the spacers on. I've been driving w/o spacers for the past 3 weeks and I feel the car has more responsive steering and generally just feels better. I'm going to experiment with maybe just leaving the spacers on the back and not having anything for the fronts. It might look a little funny, or I might just do spacers all around again "just for looks".
mit_peid is offline   Reply With Quote
Old 08-02-2013, 08:45 PM   #38
KONVERTER
KONVERTER's Avatar
Orange County I don't know... Would have to go up to the San Gabriel valley...
Order from the OP in this thread, they have an online store.
Old 08-04-2013, 02:59 PM   #39
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
Are the factory studs long enough for a 10mm spacer?
Originally Posted by Touge Factory View Post
The wheels have clearance to allow for the stock studs to poke through.
So, you should be safe with even 10mm spacers.
garfull is offline   Reply With Quote
Old 08-05-2013, 04:42 AM   #40
Fast_Freddy
Drives: Passat
Not even close. The minimum safe thread engagement is 12mm or 10 turns. Take a lug nut off and count how many turns it takes until tight. Subtract 10 turns from that number and multiply that by 1.25 to get your max spacer thickness.
Fast_Freddy is offline   Reply With Quote
The Following User Says Thank You to Fast_Freddy For This Useful Post:
garfull (08-05-2013)
Old 08-05-2013, 05:19 AM   #41
KONVERTER
KONVERTER's Avatar
Longer wheel studs are a must with "spacers" most of the time. The only time it is not is if it is a 3mm spacer but those are garbage (most are cast aluminum).
If you are unable to do the wheel stud change yourself, the extra cost may be so much that selling what you have and buying the proper fit wont be out of the question.
Old 08-05-2013, 04:05 PM   #42
garfull
garfull's Avatar
That's basically the same as general rule of thumb of needed 1 bolt diameter worth of thread engagement, but used to figure out the max spacer size. I'll have to try this method. I figured 10mm is too thick but many have stated that they've used 5mm spacer on oem studs without issue.
Ichiba and H&R Wheel Spacers on Sale!! Check It Out!! Mike@CZP Wheels and Tires 363 06-17-2018 04:38 AM
Pictures of lowered FR-S/BRZ nocurfew Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 03-26-2014 06:18 PM
How to avoid scraping your lowered vehicle PMok DIY (Do-It-Yourself) Guides 9 11-20-2012 08:49 PM
anyone with their car lowered ~2.8in! white86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-18-2012 12:54 PM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 06:11 PM
