#29 |
Drives: 86 GTS
#30 |
[I 86 I]
Drives: Toyota 86 GT
#31 |
Drives: 86 GTS
#32 |
White Fantom
18x9 +25 with 1" drop? How much it stick out the fender?
Eibach Prokit Lower Springs
Injen Intake Xenon 6000k HID Beat-Sonic Shark Fin Greddy Evo3 Catback |
#33 |
VehicleDynamicsSpecialist
Drives: iG FR-S
Depends on your alignment.. That's fairly aggressive. 48mm further out than stock. (~2")
Grab a calculator and check. But, it's roughly poking 1"+ past the guards.. Wheel fitment isn't magic. Anyone can learn to measure.
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#34 |
Drives: GT86
Would anyone please chime in on this?
#35 |
Drives: iG FR-S
11mm in compared to stock. It will fit and look rather silly imo.
![]() It will work for your intended purpose, however. Edit- may want to test fit one for front caliper clearance.
#36 |
Drives: GT86
Thank you kindly sir, would get these very cheap but still have untill January to have wheels ready so guess I will hold out and see if something better comes up.
#37 |
Drives: iG FR-S
No problem. Don't forget to check caliper clearance.
#38 |
Kiwami CR ultimate
Guys I can't seem to find the answer to my question.
I'm thinking of getting kiwami's 18'' 9.5's with a +30 offset and for the front 8.5's with the same offset...my 86 is stock ride height. Just firstly want to know if that combo will work for the car?, probly will get a 1-1.5'' drop aswel. Lastly can the car deal with an even more aggressive offset in the rear like a +20. I apologise if I sound like a noob at this. |
#39 |
Drives: Whiteout FR-S
I would probably go with 8.5 +38 front and 9.5 +38 rear, many others have and it fits well I don't see any reason to go more aggressive but i'm sure its possible with some negative camber and slightly stretched tires.
#40 |
But would a +30 all round fit?
#41 |
Sneakerhead
Drives: 2003 Honda Civic Si
Yes itll fit with the right camber and tire size
#42 |
Drives: iG FR-S
Yes. Front out 37mm over stock. Rear out 50mm over stock.
8.5/9.5 offset +30 to +38 would be ideal if lowered some with a bit of neg. camber. This is borderline aggressive/too aggressive. Hth
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
