go_a_way1
Old 08-25-2012, 05:56 AM   #29
Panman
Panman's Avatar
Drives: 86 GTS
Originally Posted by w arghh x View Post
Im pretty confused with all this offset stuff
18x8 with a +42 offset. Will this be fine? 225/40/18 tires also....
Will fit fine. No issues at all.
Panman is offline   Reply With Quote
The Following 2 Users Say Thank You to Panman For This Useful Post:
DGM33 (04-07-2015), w arghh x (08-25-2012)
Old 08-25-2012, 05:59 AM   #30
w arghh x
[I 86 I]
w arghh x's Avatar
Drives: Toyota 86 GT
Thanks mate. I thought a +42 would be ok, but then started to doubt my choice. Managed to get some SA70's New
w arghh x is offline   Reply With Quote
Old 08-25-2012, 09:28 AM   #31
Panman
Panman's Avatar
Drives: 86 GTS
I'm 18x8 +48 with 225/40 no problems. +42 just means you'll be 6mm further out in the guards each side, and there's room to spare.
The Following User Says Thank You to Panman For This Useful Post:
Old 08-25-2012, 12:27 PM   #32
FantomRider
White Fantom
FantomRider's Avatar
Drives: Whiteout FR-S
Send a message via Yahoo to FantomRider
18x9 +25 with 1" drop? How much it stick out the fender?
Eibach Prokit Lower Springs
Injen Intake
Xenon 6000k HID
Beat-Sonic Shark Fin
Greddy Evo3 Catback
FantomRider is offline   Reply With Quote
Old 08-25-2012, 01:38 PM   #33
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Depends on your alignment.. That's fairly aggressive. 48mm further out than stock. (~2")
Grab a calculator and check. But, it's roughly poking 1"+ past the guards..
Wheel fitment isn't magic. Anyone can learn to measure.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-25-2012, 02:39 PM   #34
Thobjo
Drives: GT86
Originally Posted by Thobjo View Post
Would 16"x6.5" ET53 or 55 offset work for winter tires?
Rather not spend money on winter wheels at all but need to be able to move the car in and out of garage even in snow.
These are the original 2002 Impreza and Impreza WRX wheels.
Would anyone please chime in on this?
Thobjo is offline   Reply With Quote
Old 08-25-2012, 02:51 PM   #35
ill86
ill86's Avatar
Drives: iG FR-S
11mm in compared to stock. It will fit and look rather silly imo.
It will work for your intended purpose, however.
Edit- may want to test fit one for front caliper clearance.
The Following User Says Thank You to ill86 For This Useful Post:
Thobjo (08-25-2012)
Old 08-25-2012, 05:11 PM   #36
Thobjo
Drives: GT86
Thank you kindly sir, would get these very cheap but still have untill January to have wheels ready so guess I will hold out and see if something better comes up.
Old 08-25-2012, 10:41 PM   #37
ill86
ill86's Avatar
Drives: iG FR-S
No problem. Don't forget to check caliper clearance.
Old 08-26-2012, 09:04 AM   #38
oddworlds
oddworlds's Avatar
Kiwami CR ultimate
Guys I can't seem to find the answer to my question.
I'm thinking of getting kiwami's 18'' 9.5's with a +30 offset and for the front 8.5's with the same offset...my 86 is stock ride height. Just firstly want to know if that combo will work for the car?, probly will get a 1-1.5'' drop aswel.
Lastly can the car deal with an even more aggressive offset in the rear like a +20.
I apologise if I sound like a noob at this.
oddworlds is offline   Reply With Quote
Old 08-26-2012, 09:17 AM   #39
JoeBoxer
JoeBoxer's Avatar
I would probably go with 8.5 +38 front and 9.5 +38 rear, many others have and it fits well I don't see any reason to go more aggressive but i'm sure its possible with some negative camber and slightly stretched tires.
The Following User Says Thank You to JoeBoxer For This Useful Post:
dori. (08-26-2012)
Old 08-29-2012, 03:37 AM   #40
oddworlds
oddworlds's Avatar
But would a +30 all round fit?
Old 08-29-2012, 03:51 AM   #41
igorot
Sneakerhead
igorot's Avatar
Drives: 2003 Honda Civic Si
Yes itll fit with the right camber and tire size
igorot is offline   Reply With Quote
Old 08-29-2012, 04:05 AM   #42
ill86
ill86's Avatar
Drives: iG FR-S
Yes. Front out 37mm over stock. Rear out 50mm over stock.
8.5/9.5 offset +30 to +38 would be ideal if lowered some with a bit of neg. camber.
This is borderline aggressive/too aggressive.
Hth
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
