#29 | |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | LimitedSlip (07-23-2020), soundman98 (07-24-2020) |
#30 |
So I popped the hose off and stuck a pipe cleaner in the hole and there was a block about 2cm's in. I twisted the thing a little bit and something that looked like a mothball came out. It had sealed up the hole pretty well judging by how gummed up the edges were. I hope that's been the root of the problem the last few years and maybe, just maybe I solved it sufficiently that it doesn't cause wet feet again for a while.
| The Following 5 Users Say Thank You to gravitylover For This Useful Post: | Busybee (09-12-2023), humfrz (07-23-2020), Opie (07-23-2020), Tcoat (07-23-2020), Ultramaroon (07-24-2020) |
#31 |
Drives: 2020 GMC Canyon Denali Diesel
Might want to clean the evaporator core, might be filled with mold & mildew from being plugged.
https://www.amazon.com/dp/B0007PHD0S...osi&th=1&psc=1
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following 3 Users Say Thank You to Opie For This Useful Post: |
#32 |
Drives: 22 BRZ limited
Spider egg sac?
#33 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Ultramaroon (07-24-2020) |
#34 |
It sure could be. I put that new drain hose in right before I drove down to the Florida Keys at the beginning of Feb. The car spent some time in quiet corners of parking lots where I could definitely see spiders looking to get out of the sun finding a nice damp ac drain hose to hang out in. Then the car did a lot of sitting around, parked on the grass, here at home while we were under stay at home guidance. Perfect cool, damp, quiet time for spiders to do their egg laying thing.
#35 | |
Drives: GR86 Trueno Edition
Just came across while I was further searching the forum (sorry for my post - at least there is a video now). Little confused regarding the hose you mentioned. Is the the draining hose, under the carpet from the left to right behind the styrofoam like part? Haven’t checked yet. What would be the best way to clean it. I can also get a new one if it can be taken out easily Thanks Sent from my iPhone using Tapatalk |
#36 |
not playing cards
OP sold his twin a couple years ago. The drain tube blockage is common. Sometimes even rodents set up camp.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Busybee (09-12-2023) |
| battery drain along with dtc? | _keepkushin_ | BRZ First-Gen (2012+) — General Topics | 2 | 09-20-2019 08:04 AM |
| Need help with mystery connector, and drain hose | Gabzor | BRZ First-Gen (2012+) — General Topics | 3 | 09-21-2016 01:02 PM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
| Is 300ma too much drain while the car is off? | tracerit | Electronics | Audio | NAV | Infotainment | 6 | 11-19-2015 12:20 PM |
| EZ oil drain same as Fumoto? | wbradley | CANADA | 18 | 06-15-2015 03:40 PM |
