Old 07-02-2020, 04:46 PM   #1
gravitylover
It's not the AC drain hose
The leak I've had coming from the condenser behind the glovebox is really bad now. I replaced the drain hose and made sure there are no blockages but the water is pouring out now when the AC or defroster is on. This really sucks because now that the carpet is soaked the windows fog up if I don't have the defroster on making the car nearly undriveable in the rain or at night. I drive with the windows open as often as I can but that's not always possible. What the F else could it be? I don't see any cracks in the housing, is there a breather somewhere that I'm not seeing that may be blocked? Please don't tell me the heater core is shot...
Old 07-02-2020, 05:20 PM   #2
humfrz
Well now, that's a bummer -
Is the liquid leaking out water or coolant?
I suggest you go to ol @Ultramaroon 's signature block and click on the parts manual he has posted there to see a breakout of the A/C or heater system, depending on what the liquid is.
With that much liquid coming out, you should be able to see or feel where it's leaking.
Old 07-03-2020, 01:27 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
I would pull the interior carpet and then run the a/c while trying to locate the leak.
Old 07-03-2020, 02:03 AM   #4
Compelica
Compelica's Avatar
Drives: 86 GT
Any pictures of the leak, not sure where it is but try pulling out the glovebox and reach behind to check where the water is coming from? Or wrap your phone in cling and record a video, that should give you a better idea.
Compelica is offline   Reply With Quote
Old 07-04-2020, 02:03 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Sounds like it's clogged at the bottom of the pan itself. Happened to a friend's. Turned out to be a mouse nest somewhere up in there. Rice from the pantry came out.
humfrz (07-04-2020), Tcoat (07-11-2020)
Old 07-05-2020, 06:38 PM   #6
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
the drain hose is not connected properly, or part of the system is plugged.
Or the part that the drain hose is connected to is broken just before the drain itself allowing the water to bypass the drain hose completely
JohnH is offline   Reply With Quote
Old 07-08-2020, 06:32 PM   #7
gravitylover
Sorry folks, I haven't been here in a few days. Life just kind of got in the way. Yesterday was pretty rough, 300 miles at 90 degrees with no AC meant I had to drive pretty fast with the windows open to stay comfortable. Not that I mind driving fast...
Ya know that makes sense. Hmm, gonna have to go do some real diggin around in there. I guess I need to go through the breakdown in the service manual and see what there is to see. If you find the page let me know which one it is
I've had the hose on and off a dozen times now so I know it's seated correctly and that the piece it attaches to is good. With the hose off the water drains out from somewhere above, there's no blockage in there that I can find, I've stuck long pipe cleaners up as far as they'd go with no resistance.
Old 07-08-2020, 07:20 PM   #8
ls1ac
ls1ac's Avatar
You know that it has to be condensation on the evaporation coil. So where is the water getting out of the heater box and why is the drain not working. I say this guardedly, you could use compressed air from the bottom of the drain line up. no more than 5 PSI and then with caution. If you do not have a compressor with a good regulator then get a Blowoff can at a computer store. I have used the line from a string trimmer for drain tubes from sun roofs.
Old 07-09-2020, 09:45 PM   #9
Ultramaroon
not playing cards
got jokes
https://gt86stuff.onrender.com/t3Por...03FXE009X.html
Now you have me curious.
Old 07-09-2020, 11:13 PM   #10
humfrz
And there it is - right there in plain sight, just ream it out - piece of cake -
gravitylover (07-11-2020), Ultramaroon (07-10-2020)
Old 07-11-2020, 12:15 AM   #11
Ultramaroon
not playing cards
I bet if you remove the blower you'll find a little moat right around where it mounts up in there.
Old 07-11-2020, 11:22 AM   #12
gravitylover
I've been slacking and haven't been back here or under the dashboard since I posted this. I've gotten #coronalazy
The Following User Says Thank You to gravitylover For This Useful Post:
humfrz (07-11-2020)
Old 07-11-2020, 04:00 PM   #13
humfrz
So, THAT'S what I got -
soundman98 (07-11-2020)
Old 07-11-2020, 05:34 PM   #14
gravitylover
Nah you're just old and missed your nap
The Following 2 Users Say Thank You to gravitylover For This Useful Post:
humfrz (07-11-2020), Ultramaroon (07-12-2020)
battery drain along with dtc? _keepkushin_ BRZ First-Gen (2012+) — General Topics 2 09-20-2019 08:04 AM
Need help with mystery connector, and drain hose Gabzor BRZ First-Gen (2012+) — General Topics 3 09-21-2016 01:02 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Is 300ma too much drain while the car is off? tracerit Electronics | Audio | NAV | Infotainment 6 11-19-2015 12:20 PM
EZ oil drain same as Fumoto? wbradley CANADA 18 06-15-2015 03:40 PM
