| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 subaru brz limited
battery drain along with dtc?
anyone ever have a altenator fail while driving if so did you get any DTCs? trying to solve an issue but can only get so far as to weither its a cam sensor or a failed alt. thanks in advance
Drives: WRB Subaru BRZ Limited 6MT
Can't say that's ever happened to me. But it's pretty easy to sort out an alternator failure by checking battery voltage when the car is on. This car holds rock steady at 13.98-14.02 V when the alternator is running.
I've had an alternator go out on me while driving when I use to own a Camaro and plenty of other cars I've worked on. The dash lights and headlights started to dim right be fore everything shut off. As teadmiral976 mentioned you can check the voltage out put at the alt or batt and it should be high 13s to low/mid 14s on average.
This can throw codes without a check engine light coming on. Generally you can get some codes about battery issues and other sensors with low voltage. There's also a battery icon/dash light that should come on when you have battery issues. I've had cam angle sensor codes pop up every now and then but go away with out causing me issues. |
| Will staying in a turned off BRZ Limited drain the battery? | btan219 | BRZ First-Gen (2012+) — General Topics | 33 | 04-20-2017 11:15 PM |
| Battery Drain from Dash-Rear Cams + Advice? | covance | Electronics | Audio | NAV | Infotainment | 12 | 04-04-2016 11:08 PM |
| Does the bluetooth drain battery even when the car is off? | lupindub | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-30-2015 02:54 PM |
| Keyless fob and battery drain | taiguy | BRZ First-Gen (2012+) — General Topics | 3 | 05-01-2015 08:49 PM |
| BRZ LTD battery drain issue, can't stop open door beep | DoomsdayJesus | Issues | Warranty | Recalls / TSB | 9 | 02-06-2015 06:05 PM |
