Old 08-10-2012, 08:26 AM   #29
Nazarite
0 RWHP
Nazarite's Avatar
Drives: 2008 Mazdaspeed 3
Looking great @Draco-REX, what's the weight on these badboys?
Nazarite is offline   Reply With Quote
Old 08-10-2012, 08:37 AM   #30
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I don't have a good scale so I can't give you a real-world weight. But the manufacturer's listed weight is 6.75kg (14.85lbs). They do feel like it too. I pulled one out of the box and was waving it around one-handed.
Of the ~15lb wheels under $500 I think this is the best looking one. It was a little out of my budget, but the weight plus the looks sold it to me. I even ended up liking the color too.
The Following User Says Thank You to Draco-REX For This Useful Post:
Nazarite (08-10-2012)
Old 08-10-2012, 09:13 AM   #31
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Those look great!
MVJ1975 is offline   Reply With Quote
Old 08-15-2012, 03:03 AM   #32
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
The Following User Says Thank You to DarrenDriven For This Useful Post:
Draco-REX (08-26-2012)
Old 08-26-2012, 12:30 AM   #33
LineNoise
Drives: Fiesta XR4, Toyota 86 on order
Draco, any comment on how they alter the handling?
Looking at possibly going with this exact combo on my 86. Happy to up the overall grip but I really don't want to tinker with the stock handling feel and balance too much if you know what I mean.
Notice any change to the character of the car's handling?
LineNoise is offline   Reply With Quote
Old 08-26-2012, 05:42 PM   #34
Draco-REX
Corner Junkie
Draco-REX's Avatar
It's a huge improvement with very little change in the character of the car at 8/10 and below.
However, when really pushed, things change. Not necessarily in a bad way though. WHat happens is you become aware of how tires and suspension need to compliment each other.
With the stock setup from the factory the car is fantastic and the tires are grippy enough for fun cornering. As you approach 9/10ths and greater performance, the stock tires begin to break away in an easy and predictable manner. The amount of lateral load they can generate is only so much, so the alignment and suspension is set up to compliment that.
Now put on some much stickier tires. Suddenly the lateral forces the tires can generate get much higher. At 8/10s and below, the tricks you can go to get a little wiggle out of the car still work and the car is essentially unchanged except for higher cornering speeds. At 9/10ths the greater grip lets you transfer more weight. This, in turn, causes more body roll. More body roll means the 0 camber up front goes WAY positive and you loose front grip.
With the new tires I could drive the car like stock with plenty of on-throttle oversteer and wonderfully neutral handling as long as I kept the car below the point where the front tires began to scrub. Breakaway at the rear is still easy to catch, but the "plateau" where oversteer begins is noticeably narrower which is expected from grippier tires.
But, understeer is like a light switch. Once the front lets go, the car continues to understeer and punching the throttle does not shift the car to oversteer. Instead you just continue to push wider. So the trick is to stay just within the front tire's grip. Otherwise you have to back off the throttle, shift weight to the front with a tap of the brakes if lifting isn't enough and unwind the steering wheel a bit to get front grip back. But once you get it back, you can literally yank the car back on line.
Now, this isn't the end of the world. A good alignment and a little more roll stiffness (through stiffer springs or larger sway bars) should let this car explore 10/10ths and keep the balance we love so much. I have the RCE Suspension Starter Kit going on this week. That should take care of what I'm experiencing and unlock the upper 10ths. This car with good tires has amazing levels of grip. I can't wait to see what happens with a good alignment.
The Following 9 Users Say Thank You to Draco-REX For This Useful Post:
15limited (11-09-2015), Brzce (08-26-2012), crimespree (08-30-2012), Fly Guy (03-31-2013), Jetscape (06-09-2013), Khyron686 (03-15-2013), Metabrz (08-28-2012), suaveflooder (02-24-2014), unsurety (08-05-2014)
Old 08-26-2012, 08:18 PM   #35
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
These are nice, you are making me rethink my wheel game....
JimmyMac is offline   Reply With Quote
Old 08-26-2012, 10:23 PM   #36
Draco-REX
Corner Junkie
Draco-REX's Avatar
20mm less fender gap by this weekend. I think the fat tires will make it look even lower.
Old 08-27-2012, 03:39 AM   #37
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
can't wait to see it after the drop!
thatWESguy is offline   Reply With Quote
Old 08-27-2012, 04:35 PM   #38
LSxJunkie
LSxJunkie's Avatar
Drives: Car
That's at stock height? That looks great!
LSxJunkie is offline   Reply With Quote
Old 08-27-2012, 05:26 PM   #39
Draco-REX
Corner Junkie
Draco-REX's Avatar
Yup. 100% stock suspension.
Old 08-27-2012, 07:55 PM   #40
jmkv
Drives: really slow
Tires look beefy. Nice setup
jmkv is offline   Reply With Quote
Old 08-28-2012, 08:53 AM   #41
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Amazing what just lower offset will do for looks.
Old 08-28-2012, 06:53 PM   #42
DanMac
Drives: NA8 MX-5
Looks immac! Would love to see this on my red 86
DanMac is offline   Reply With Quote
Wheel Directory: SSR Competition 17x8.0 +38 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 08-07-2015 06:38 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 03:58 PM
Wheel Directory: Advan RG II 17x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-11-2012 07:28 PM
17x8 +35, will it rub? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-31-2012 03:26 AM
Pre Order TC105N vividracing Wheels and Tires 27 07-30-2012 03:28 AM
