Old 10-15-2018, 06:50 PM   #29
86MLR
86MLR's Avatar
For a street car, you it wrong
Wrong rims
Wrong tyres
Wrong alignment
Your car now handles worse than OEM
Your braking is now worse than OEM
Read more
Your doing it wrong, unless of course all you care about is how "you think" your car looks best hard parked.
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
SuperTom (10-15-2018), Tristor (10-16-2018)
Old 10-15-2018, 09:00 PM   #30
strat61caster
strat61caster's Avatar
Originally Posted by fr-steezz View Post
But if the alignment is good enough the should be able to drive straight.
The alignment is not good enough, you need to balance your toe left to right or it will continue to pull to one side.
ineedyourdiddly
whataboutbob (09-26-2022)
Old 10-15-2018, 09:32 PM   #31
fr-steezz
Drives: 17 Toyota 86
I’m gonna get back on the alignment rack soon
fr-steezz is offline   Reply With Quote
Old 10-16-2018, 12:13 PM   #32
ZDan
ZDan's Avatar
Drives: '23 BRZ
That alignment is good enough. 0.1° toe in on one rear and 0.05° toe-in on the other side is really not a big deal.
If car pulls to one side on acceleration, *and* the rear tires are at the same appropriate pressure, *and* same make model and at similar wear level, the thing to do is swap rear tires left to right and see if the pull changes direction. If so, bad tire.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Leonardo (10-16-2018), Tristor (10-16-2018), wparsons (10-16-2018)
Old 09-26-2022, 09:46 AM   #33
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Well it's not uncommon that camber plates need to be in different positions to get equal camber on alignment rig but yours seem to have quite a big difference. Are both of your coilovers set to the same lenght ?
MrSkubi is offline   Reply With Quote
Old 09-26-2022, 10:04 AM   #34
Lunatic-monkey
Drives: Stock-ish
Hello MrSkubi
The coilovers are set at the same ride height.
Lunatic-monkey is offline   Reply With Quote
Old 09-26-2022, 02:06 PM   #35
strat61caster
Did your alignment guy max out the camber bolts before adjusting the camber plates?
ineedyourdiddly
Old 09-26-2022, 03:20 PM   #36
Lunatic-monkey
Drives: Stock-ish
Hello,
There is no camber bolt on the stock suspensions of a scion frs and i installed the coilovers with the oem bolt so there is no lower adjustement for the camber. The only way to ajdust camber in my cas is by moving the top camber plate.
Old 09-26-2022, 07:22 PM   #37
strat61caster
Originally Posted by Lunatic-monkey View Post
Hello,
BC coilover has a slotted upper bolt hole for camber adjustment with factory bolts.
ineedyourdiddly
Old 09-27-2022, 09:15 AM   #38
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Seems like any car I've done suspension to in the past decade.
Camber plate are for quick eye camber adjustment NOT for centering the car.
Most of the cars that I've dealt with were as easy as fixing the camber at the bottom of the strut. Then of course, 2 of the cars needed the entire subframe shifted.
KW coilovers and camber (without camber plates) wparsons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-09-2018 08:53 PM
Uneven rear camber after lowering springs Euphues Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-11-2015 08:27 PM
FS: HVT Non-raising camber plates & WL camber bolts trippinbillies40 Brakes, Suspension, Chassis 1 05-16-2015 09:00 PM
17x9 +42 & 245/40 w/ RCE yellow and maxed camber bolts jeebus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 09-30-2013 10:25 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
