Old 11-07-2015, 06:17 PM   #1
Euphues
Drives: 2015 Raven FRS
Uneven rear camber after lowering springs
So I installed hotchkis lowering springs last weekend. This weekend I went into Firestone and bought a lifetime alignment. The car has pretty even camber in the front at -.4" and -.3" I plan to bring it back and have camber bolts installed. I got some SPC ones online.
The rear however is -2.4 left and -1.4 right.
What would cause this to happen? Any advice on a solution for the situation?
Euphues is offline   Reply With Quote
Old 11-07-2015, 06:36 PM   #2
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You can attempt to center the subframe using rigid collars, or shifting the subframe after loosening then retightening, but not much you can do besides using adjustable control arms. I've tried using the first 2 methods I mentioned to no avail. If you measure your ride heights, it too will be lop sided. I thought this would be less severe on newer models... apparently not. Yours sound to be really severe. My car is about .5 degrees off and sits about 5~8mm taller on the passenger side.
Intent > Content
Old 11-07-2015, 06:45 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
its like that from factory. Most aren't that different but mine was. You wont get too much from the subframe. Get some LCAs for adjusment and call it good.
Old 11-07-2015, 10:11 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
A 12 mm camber bolt fits in the rear lower control arm inner bolt. You can get about half a degree plus or minus with them. That's what I used to fix my uneven camber.
Old 11-07-2015, 10:47 PM   #5
qwerty66
Drives: frs
did you load up the suspension when you tightened up the bolts?
qwerty66 is offline   Reply With Quote
Old 11-08-2015, 12:52 PM   #6
Euphues
Tightened what bolts? The suspension was handing freely up on jack stands when we tightened the center bolts and the bolts holding the top hat to the car
Old 11-08-2015, 01:13 PM   #7
Gunman
Drives: 2019 Mazda Miata RF
In the Hotchkis instructions, there are some bolts you don't full tighten until the car is back on the ground, and rolled fore/aft a little to settle the suspension.
Page 30:
http://www.jegs.com/InstallationInst.../515-19445.pdf
Gunman is offline   Reply With Quote
The Following 2 Users Say Thank You to Gunman For This Useful Post:
Porcupint (11-08-2015), solidONE (11-08-2015)
Old 11-09-2015, 12:34 PM   #8
solidONE
solidONE's Avatar
^ That might be a contributing factor of your camber and ride height uneven-ness. If it was even before you installed then that's probably the cause. Couple of other things is stiction in the suspension if you really pinched those control arms back on by over torquing (although stock bushings aren't quite as smooth as rod-ends or ball bearings), or the springs themselves are uneven in height and spring rate left to right. It's pretty common with cheapo $50 ebay/china springs. I haven't installed hotchkis brand springs but I highly doubt this is the case.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
wparsons (11-09-2015)
Old 11-10-2015, 12:11 PM   #9
ChrisP
Same thing happened when I installed the TRD lowering springs. I have -1.5 on the left and -2.6 on the right. I'm planing on getting the SPC lower control arms to adjust it.
ChrisP is offline   Reply With Quote
Old 11-10-2015, 12:21 PM   #10
solidONE
solidONE's Avatar
Where were the camber specs at before changing out the springs?
Intent > Content
Old 11-10-2015, 12:24 PM   #11
ChrisP
Unfortunately I dont know. I probably should have had it checked before the install but I didnt.
Old 11-10-2015, 12:42 PM   #12
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Our cars don't have adjustable camber, so when we lower them they get out of wack.
Easiest solution is to add camber bolts to the front and lower control arms in the rear and then get another alignment.
Instagram: trevor.parque
Old 11-11-2015, 08:27 PM   #13
tyler_win_photo
tyler_win_photo's Avatar
A lot of our cars came from factory with uneven camber in the rear. When you lower your car, the difference is likely to become more apparent. Only way out is with adjustable lower control arms.
tyler_win_photo is offline   Reply With Quote
TRD Lowering Springs Camber. ChrisP Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 10-26-2015 02:21 PM
Eibach Sportline Lowering Spring front and rear camber bolts WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-20-2014 10:09 AM
Any way to lower rear lowering springs further? BlueDubbinTDI Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-03-2014 09:03 PM
Rear camber after lowering mike_ekim1024 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-09-2013 04:01 AM
