Old 09-12-2018, 01:45 PM   #29
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I don't have any info to the contrary, but I don't think most stations would have a separate alcohol only tank installed.
Extra infrastructure, ground space, more complicated routing and pumps.
Wouldn't surprise me if the deep south does it because, uh ... uhm.
Old 09-12-2018, 02:41 PM   #30
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Tanks get filled wrong more then you would think. Like diesel in the 87 pump or vice versa. But flex fuel wont save you there lol.
Always get a receipt.
Old 09-12-2018, 04:24 PM   #31
Originally Posted by Scala View Post
Thanks. Make it two.
Let me state it one more time, just to be clear.
In theory, you CAN get identical results.
In reality, you WILL NOT get identical results.
Get Ecutek.
Old 09-12-2018, 09:03 PM   #32
churchx
churchx's Avatar
Drives: 2014 GT86
Do you have "reality" test cases to back that claim?
Of course cases with variables eliminated, like same tuner, that is competent with both ecutek & oft, that has modified same tables of timings/fueling and so on, and have not used some possible extra logic that may affect those changes, that car on same dyno same day showed different output with Ecutek vs OFT?
Yes, there are more professional tuners/shops that work with ecutek due ability to lock their work. Yes, some of they can make better tune then eg. worse tuner, so that may back customer's wish to choose their services to get most gains. Yes, some features of Ecutek may make tuning easier and quicker, saving time & money on expensive dyno. Yes, ecutek provides some extra features/code some users may wish to get. But that doesn't make it fair apples to apples comparison to make such claim that it's tuning solution fault and with OFT one will get consistently worse tune just because it's OFT even if basic tuning is considered. Different tuners, different tune, different result. Eliminate variables first. Or use different wording to not confuse. It's not reality vs theory. Cause and effect is one tuner vs other tuner doing different tunes. Or one tuner knowing one of tuning solutions much better .. and producing different tune. Otherwise that sounds like advertising of specific products vs belittling others.
Old 09-12-2018, 09:15 PM   #33
Grady
Grady's Avatar
Man I got half way through that 2nd paragraph and all I could hear was the adults from the Peanuts cartoon!
Old 09-12-2018, 09:36 PM   #34
I do. Your only choice for tuner with an OFT, is Shiv.
Case closed.
Old 09-12-2018, 10:12 PM   #35
redhalo
Drives: MY20 Hakone Toyota 86
Case closed.
Well, and Wayne. His OFT tune has been waaaaaay better than Shivs off the shelf tune for me.
redhalo is offline   Reply With Quote
The Following User Says Thank You to redhalo For This Useful Post:
CSG Mike (09-13-2018)
Old 09-12-2018, 11:10 PM   #36
stlgrym3
Drives: 2017 Subaru BRZ Limited
Case closed.
And good luck get a hold of him when you need to.
stlgrym3 is offline   Reply With Quote
The Following User Says Thank You to stlgrym3 For This Useful Post:
Old 09-13-2018, 05:39 PM   #37
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
OFT, Stage 2 E85 tune, v4 Beta. No FFK. Your fuel trims will stay within a safe range, no CEL between 60-90% ethanol on OFT. After that your fuel trims will get very high and possibly get a CEL.
I've been running E85 most of the time since last January. No problems with ethanol content around here, I mostly use Thorntons. I have never tested
I have an AFR gauge to watch how lean I'm getting and it's never gotten lean at all (or rich for that matter). When I fill up I load up Torque Pro and watch the fuel trims, no problems so far. Even if you try and use E85 on the default tune, it won't blow up your engine as long as you don't go WOT, but your car will run like shit & cause a CEL. The car does a good job of adjusting fuel trims to keep your engine safe.
IMHO if you are a person who likes to tinker and monitor, you don't need a FFK as long as you are careful and have the tools. If you are a hands off person who just wants to set it and forget it, you need a FFK.
Old 09-13-2018, 09:15 PM   #38
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Case closed.
or try to learn yourself.
But the reality for the majority of people is they want it done right and not have to fiddle with it, so Ecutek and flex fuel are the obvious choice.
Old 09-13-2018, 10:03 PM   #39
Lantanafrs2
Drives: 2013 frs red
Op learned absolutely nothing here lol.
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
CSG Mike (09-13-2018), MCTeeJ (09-14-2018)
Old 09-15-2018, 11:55 AM   #40
bfrank1972
Drives: 2013 FR-S Argento
I've tried the OFT stage 2 E85 tunes a couple different times (on a P&L EL header) - I do feel a bit of a difference but I swear it doesn't really feel that impressive at all! Header upgrade was a significantly bigger difference IMHO - maybe I'm doing something wrong. Fuel trims look fine btw. Maybe it's a subtle thing? I have to drive 20 minutes to Greenwich to get E85, so I just run 93.
bfrank1972 is offline   Reply With Quote
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit? stlgrym3 Engine, Exhaust, Transmission 4 03-23-2018 03:51 AM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 10:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 07:43 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 07:21 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 10:36 AM
