Old 01-03-2018, 09:54 PM   #29
arren123
Drives: 2013 BRZ (RIP), now 2017 BRZ
What date was your car built ....??
humfrz
The black label on my door jamb says 8/12
arren123 is offline   Reply With Quote
Old 01-03-2018, 10:04 PM   #30
humfrz
hmmm......that's pretty young.
However, it is what it is .......as they say in the old country, or somewhere ......
Well, hopefully the dealership will discover a simple solution with an easy fix.
humfrz
Old 01-03-2018, 10:37 PM   #31
ermax
ermax's Avatar
I've never had a spark plug back out either, but it was easy enough to check and hope for an easy fix.
I'm not driving the car between now and Monday. I'm getting it towed to the dealer since I still don't know the actual cause.
I just plugged in my Ecutek and used the DTC tool to verify there were no stored codes.
On the side note of doom and gloom..
There was a YouTube video I ran across where the guy had a rod/bearing issue. One of his comments "Ended up being a spun Rod 4 Bearing, apparently it wasn't out of the normal on the early first batch engines due to a front oil valley cover issue (passages too narrow or something along those lines). I got a replacement engine under warranty and it was fine ever since. The early engines have a #1 with an eagle looking logo stamped on the front cover, revised front covers have a #2 with no eagle. Sure they've done more revisions since then."
I looked at my cover and I found the eagle and I found the #1 on it
That is an interesting tidbit of info right there. Need to do some more research on this. If they had a bad design on the timing cover bad enough to starve the crank then this should be a recall. I have a fairly early 2013. When I get home I will check to see if I have a #1 on my timing cover.
Old 01-04-2018, 05:15 AM   #32
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
OK. Here's what I found out so far.
I thought that a spark plug may have backed itself out so I checked #1 and #3 on the passenger side and they were tight. Then I pulled the plugs out. No clues from the plugs, they look normal. I didn't bother with #2 and #4 since those a difficult to remove with all the injector/supercharger hoses in the way.
It's a Ford thing mostly. It's not uncommon for a plug to back itself out of some of the older Ford engines.
It's not a safety item, so there will be no recall. The best you can hope for is a TSB. I don't remember seeing a campaign for this though- but it's been a while since I checked.
Old 01-04-2018, 02:34 PM   #33
Ultramaroon
not playing cards
Ultramaroon's Avatar
Old 01-04-2018, 08:32 PM   #34
ermax
ermax's Avatar
I have the eagle and mine was built 11/12.
Old 01-05-2018, 01:21 AM   #35
Ultramaroon
not playing cards
I just listened again. I agree with you, @arren123. I think it's a spun rod bearing. I bet if you drain the oil into a clean container you'll see it's visibly contaminated with metal fragments. Dust.
Old 01-05-2018, 12:42 PM   #36
arren123
Did you find the #1 on the cover too? I think it was to the top and right of the eagle.
Old 01-05-2018, 05:18 PM   #37
ermax
ermax's Avatar
It was dark out and hard to see but I just checked again and as you said, there is a #1 to the top right of the eagle.
Old 01-05-2018, 05:38 PM   #38
The bad cover is one of the several theories. Another big one (the one I subscribe to through the evidence posted on this forum) is that many of the early ones had excessive silicone sealant floating loose in the channels. The #4 bearing is the end of the line so it gathered there and blocked the oil flow.
Old 01-08-2018, 11:54 AM   #39
arren123
Just got a call back from the dealer tech. The diagnosis is rod knock and he recommended a tear down and ordering a short block since they are already tearing it down. At minimum I'll need the short block.
The tear down includes head and valve inspection and everything in between.
I already authorized the tear-down and short block. I never told them that I thought it might be a rod knock so it's good to hear it matches up to what I thought it might be.
Opinions? Recommendations anyone?
Old 01-08-2018, 12:15 PM   #40
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Old 01-08-2018, 12:17 PM   #41
arren123
Lol!
Old 01-08-2018, 12:23 PM   #42
humfrz
Well, that sucks ......
At least you're going to get it fixed.
Thanks for the update.
I reckon I'm going to have to recalibrate my ears for FA20 "rod knock" ......
humfrz
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
SOLVED: Is this 2013 Scion FRS Engine Knocking/Tapping normal? N1rve Issues | Warranty | Recalls / TSB 215 08-24-2019 02:04 PM
Tapping/Knocking Sound from Front Coilovers Trefoil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-19-2017 10:25 PM
Popping noise from engine bay during start up, free rev, light roll on throttle heeltoe86 Tracking / Autocross / HPDE / Drifting 44 12-01-2014 09:28 PM
