Old 06-02-2017, 01:18 PM   #29
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
http://www.ft86club.com/forums/showthread.php?t=116090
Throwing this guy out there. The offset is different, but width etc etc seems to be what you're looking for.
Old 06-02-2017, 01:24 PM   #30
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Originally Posted by Vital View Post
what tires are you running?
Firestone Indy 500, check out my journal in my sig for pictures and some other thoughts on them.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
Keenercarguy (06-03-2017)
Old 06-03-2017, 11:52 PM   #31
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Good to know that the 245/40 Indy 500 fits on a 17x8 well, I may try it out next.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 06-04-2017, 11:56 AM   #32
mrg666
pessimistic skeptic
mrg666's Avatar
I am using 225/45-17 Yokohama tires on stock 17x7 rims which is within specs of this tire size. There is absolutely no disadvantage, pinching whatsoever. I only see the benefit of better traction which is especially needed with a supercharger and a slightly better shock absorption. Grain of salt: the advantages I see are relative to the stock 215/45-17 Bridgestone Turanza tires. I am planning to go with 245/40-17 on 17x8 +45 rims next, again within recommended specs of the tire and car.
Unless there is a significant increase in power, I think 225/45-17 is ideal for our cars; 245 width will make the car look faster but go slower.
Old 06-05-2017, 01:30 AM   #33
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Thanks! But what if I actually plan to stay all stock.
I just want to lighten the car but maintain my odometer/speedometer measurements. Shouldnt I basically stick to a 17x7/7.5 rim amd 215/45 tire?
leevanf is offline   Reply With Quote
Old 06-05-2017, 04:33 AM   #34
mrg666
pessimistic skeptic
mrg666's Avatar
The effective diameter of a tire decreases in time as they wear out. 225/45 has ~2% larger diameter than 215/45. So speedometer reading will be that much lower and become closer to true value in time. 215/45 starts closer to true value and become higher in time. It doesn't look like a difference that matters to me. I preferred the ride quality and grip of 225, actually 225 was cheaper and had a wider selection. The weight difference is negligible but some tires are lighter than others. I think Yokohama was lighter than Michelin. As you see, it comes down to personal decision but it won't make much difference. Good luck.
Old 06-06-2017, 12:02 AM   #35
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
The effective diameter of a tire decreases in time as they wear out. 225/45 has ~2% larger diameter than 215/45. So speedometer reading will be that much lower and become closer to true value in time. 215/45 starts closer to true value and become higher in time. It doesn't look like a difference that matters to me. I preferred the ride quality and grip of 225, actually 225 was cheaper and had wider selection. The weight difference is negligible but some tires are lighter than others. I think Yokohama was lighter than Michelin. As you see, it comes down to personal decision but it won't make much difference. Good luck.
Most likely wont be that noticeably but using the gear ratio calculator the difference between 215 and 225 makes the new 4.3 gears act like 4.24. Again not a huge difference but almost half the change from 4.1 to 4.3. And you can feel the change in the 17's vs the older models.
SuperTom is offline   Reply With Quote
will this wheel and tire combo fit with stock suspension without rubbing? Andreasbrz14 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-23-2017 04:25 PM
Most Close to stock fit tire on 17x8.25 Norinradd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 10-29-2016 01:20 PM
How close is too close?: Gap between tire & spring perch kodyo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-20-2015 01:32 PM
Can you stagger this tire combo? Brody602 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 03-13-2014 07:12 PM
Functional tire combo tintumz22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 02-06-2013 12:12 PM
