#29 |
not playing cards
Hold up. Only one side was blocked. Why are we going for the pump?
#30 |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (01-22-2018) |
#31 | |
![]() Yep, ol @Ultramaroon and I are jest ah messen wich ya ...... ![]() However, I have found that it's always good to read the entire thread before offering advice ........ ![]() humfrz |
#32 | ||
Drives: 2016 Subaru BRZ (ZC6)
#33 | |
Do you have a FR-S/BRZ/86 .....?? If not, are you planning on getting one .. ?? Yep, you will find that most of the time, an OP (original poster) doesn't give out all the relevant information in the first post. They will dribble it out throughout the thread. Sometimes we have to drag it out of them. You'll catch on ...... ![]() humfrz |
#34 | |
not playing cards
So, posting after a couple years of lurking? Can we read anything into that? Did you replace the honda with a BRZ?
#35 |
I'n the buying process should be closing monday its a 2016 BRZ Limited not a fan of the new dash style for 2017 but its in dark gray, I still have the honda for the time being.
| The Following 2 Users Say Thank You to EzyBreezy For This Useful Post: | humfrz (01-24-2018), Ultramaroon (01-24-2018) |
#36 |
#37 | |
not playing cards
Keep the honda if you have enough room, IMHO.
#38 |
Senior gif poster
Drives: 2013 Asphalt FRS
does anyone know the proper way to take out the washer spray nozzle? does the entire cowl have to come off? or do I just grab it with needle nose pliers and yank them out? I'm not sure on the proper way to get the old spray nozzle out (clogged on driver side)
#39 |
not playing cards
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (09-24-2019) |
#40 |
Pull the hose from the washer fluid reservoir and use some compressed air to blow the hose and nozzle out. A few short bursts shouldn't damage anything and is less likely to cause a leak than trying to poke a wire or similar through the nozzle or hose.
| The Following User Says Thank You to gravitylover For This Useful Post: | ShadowReaper (01-02-2023) |
#41 |
Drives: Asphalt FR-S
Anyone else suffering from low pressure on the driver side sprayer? I swapped out the sprayers, blew air through the lines, and still have the issue.
*Update* seems to have been there liquid I was using. Went back to rain x and issue is resolved. Sent from my Pixel 4 XL using Tapatalk Last edited by Rican_D; 04-13-2020 at 10:26 PM. |
#42 |
Ohne Titel
Drives: 2017 BRZ PP ISM
My washer spray gave out entirely. When I pull the wiper stalk there is no spray and no sound to indicate the sprayer motor is working.
In this case, I think it actually might be the pump instead of the lines being clogged. The 2 Subaru dealers in my area both have service department reputations that give me pause. I'm worried that they're going to charge me a bunch of money to diagnose the issue and then not cover it under warranty. To complicate matters, I'm hitting 3 years with my car in about a week. So it's now or never for bumper to bumper coverage. Any idea on how much time an independent shop would need to bill to replace the pump? I'd rather not have the stress of fighting with a crappy dealer service department right now. Prefer to just go to a mechanic I trust. Looks like the pump is about $35: https://www.subarupartwholesale.com/...6611CA010.html Last edited by TofuJoe; 07-05-2020 at 04:41 PM. Reason: Update |
| Total windshield washer amt? | SteveGrillo | BRZ First-Gen (2012+) — General Topics | 21 | 03-04-2022 11:21 AM |
| DIY: Smaller Windshield Washer Reservoir | zeal86 | DIY (Do-It-Yourself) Guides | 15 | 06-05-2021 02:25 AM |
| Where can I get the Smaller Windshield Washer Tank? | Cross | Forced Induction | 37 | 01-19-2017 05:23 PM |
| where to buy a windshield washer tank | shif7i7down | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-23-2015 09:09 AM |
| Windshield Washer Motor and Pump Assembly | Fainten | BRZ First-Gen (2012+) — General Topics | 0 | 09-06-2014 08:14 PM |
