Old 01-21-2018, 10:04 PM   #29
Hold up. Only one side was blocked. Why are we going for the pump?
Old 01-21-2018, 11:34 PM   #30
He must be a tech at a dealership .......
Ultramaroon (01-22-2018)
Old 01-22-2018, 12:13 AM   #31
Originally Posted by EzyBreezy View Post
I had a car with similar problem. At the bottom of your winshield washer fluid bottle there should be a small pump with an electrical connection. That piece could be faulty. I would suggest replacing it. Instead of blowing through the lines just replace them tho i doubt thats your problem.
You can go dealer specific part or local parts store should also stock the item.
Hello EzyBreezy and welcome to posting to our forum ......
Yep, ol @Ultramaroon and I are jest ah messen wich ya ......
However, I have found that it's always good to read the entire thread before offering advice ........
Old 01-22-2018, 11:23 PM   #32
EzyBreezy
EzyBreezy's Avatar
Drives: 2016 Subaru BRZ (ZC6)
My appologies, I missed that deduction. I skimmed throught the posts guilty as charged.
Pleasure to be here, I seriously didnt see anything that pointed to one side but lesson learned. Thanks for catching my slip up guys, Keep up the solid work.
EzyBreezy is offline   Reply With Quote
Old 01-22-2018, 11:35 PM   #33
Good to have you here.
Do you have a FR-S/BRZ/86 .....?? If not, are you planning on getting one .. ??
Yep, you will find that most of the time, an OP (original poster) doesn't give out all the relevant information in the first post. They will dribble it out throughout the thread. Sometimes we have to drag it out of them.
You'll catch on ......
Old 01-23-2018, 12:04 AM   #34
You'll catch me at it soon enough.
So, posting after a couple years of lurking? Can we read anything into that? Did you replace the honda with a BRZ?
Old 01-24-2018, 12:35 AM   #35
EzyBreezy
EzyBreezy's Avatar
I'n the buying process should be closing monday its a 2016 BRZ Limited not a fan of the new dash style for 2017 but its in dark gray, I still have the honda for the time being.
The Following 2 Users Say Thank You to EzyBreezy For This Useful Post:
humfrz (01-24-2018), Ultramaroon (01-24-2018)
Old 01-24-2018, 12:37 AM   #36
CONGRATULATIONS ..........!!
Old 01-24-2018, 01:28 AM   #37
Sweet! Congrats!
Keep the honda if you have enough room, IMHO.
Old 09-23-2019, 02:27 PM   #38
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
does anyone know the proper way to take out the washer spray nozzle? does the entire cowl have to come off? or do I just grab it with needle nose pliers and yank them out? I'm not sure on the proper way to get the old spray nozzle out (clogged on driver side)
DandoX is offline   Reply With Quote
Old 09-24-2019, 01:14 AM   #39
https://demos.starbase7.net/t3Portal...03EWJ02EX.html
Tcoat (09-24-2019)
Old 09-25-2019, 08:25 PM   #40
gravitylover
Pull the hose from the washer fluid reservoir and use some compressed air to blow the hose and nozzle out. A few short bursts shouldn't damage anything and is less likely to cause a leak than trying to poke a wire or similar through the nozzle or hose.
The Following User Says Thank You to gravitylover For This Useful Post:
ShadowReaper (01-02-2023)
Old 03-19-2020, 07:13 PM   #41
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Anyone else suffering from low pressure on the driver side sprayer? I swapped out the sprayers, blew air through the lines, and still have the issue.
*Update* seems to have been there liquid I was using. Went back to rain x and issue is resolved.
Sent from my Pixel 4 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 07-05-2020, 04:36 PM   #42
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
My washer spray gave out entirely. When I pull the wiper stalk there is no spray and no sound to indicate the sprayer motor is working.
In this case, I think it actually might be the pump instead of the lines being clogged.
The 2 Subaru dealers in my area both have service department reputations that give me pause. I'm worried that they're going to charge me a bunch of money to diagnose the issue and then not cover it under warranty.
To complicate matters, I'm hitting 3 years with my car in about a week. So it's now or never for bumper to bumper coverage.
Any idea on how much time an independent shop would need to bill to replace the pump?
I'd rather not have the stress of fighting with a crappy dealer service department right now. Prefer to just go to a mechanic I trust.
Looks like the pump is about $35: https://www.subarupartwholesale.com/...6611CA010.html
TofuJoe is offline   Reply With Quote
Total windshield washer amt? SteveGrillo BRZ First-Gen (2012+) — General Topics 21 03-04-2022 11:21 AM
DIY: Smaller Windshield Washer Reservoir zeal86 DIY (Do-It-Yourself) Guides 15 06-05-2021 02:25 AM
Where can I get the Smaller Windshield Washer Tank? Cross Forced Induction 37 01-19-2017 05:23 PM
where to buy a windshield washer tank shif7i7down Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-23-2015 09:09 AM
Windshield Washer Motor and Pump Assembly Fainten BRZ First-Gen (2012+) — General Topics 0 09-06-2014 08:14 PM
