Old 03-25-2017, 02:26 PM   #29
Ultramaroon
not playing cards
Ultramaroon's Avatar
Ok, OP. Mixed in with our usual ribbing are some valuable observations. Let us know which parts make sense and which, if any, leave you scratching your head.
Old 03-25-2017, 03:49 PM   #30
humfrz
Maybe the OP went and turned off all the nannies and took that 40 degree (C or F ...??) at 60 mph and is now doing laundry .....
humfrz
Old 03-25-2017, 03:58 PM   #31
Yeah! What he said. Duh.
Besides, isn't it Strat's turn? Nobody likes a pedant.
This one is sort of cool
Oh wait...
Old 03-25-2017, 05:45 PM   #32
Ultramaroon
not playing cards
Maybe the OP went and turned off all the nannies and took that 40 degree (C or F ...??) at 60 mph and is now doing laundry ..... z
104F?
Old 03-25-2017, 06:42 PM   #33
cmurp96
Drives: Black 2013 Scion FR-S
This ol boy would like some clarification.
Are you saying the turn is a 60 degree curve (flat) OR a 60 degree (banked) curve ..... ??
humfrz
Its a flat 40 degree turn at 60mph
cmurp96 is offline   Reply With Quote
Old 03-25-2017, 06:46 PM   #34
cmurp96
You have no camber and take it to the track? I would imagine you understeer like mad and the outside edge takes a crazy beating.
Also, new tires take a bit to burn the grease off. Plus, the car doesnt like the different aged tires front and rear. I ran tires like that for a while and had terrible time with the TC til I replaced all 4 then it went away. Not sure if its due to varying size or the levels of grip
I'm also gonna go with there is likely an input somewhere (helping) cause this.
How much camber should I have?
Originally Posted by Cole View Post
Pro tip: the 96 in his user name probably stands for 1996, which means he's a young buck full of hubris and ready to make bad decisions.
I also doubt that the track experience is real, if it was, I'm sure he'd have a far better idea of what's going on mid-turn. Doubly hard to believe he tracks given that alignment, didn't realize understeery alignments were so good for track days.
The 96 refers to the year I graduated from VT. No advice, no need to comment
Old 03-25-2017, 06:48 PM   #35
cmurp96
For the mos part it seems the car i just not made for this, the only other suggestion was to mess with the camber which idk what to put it at and front or back? Not very specific. I also had this problem before new tires so its not that
Old 03-25-2017, 06:50 PM   #36
cmurp96
I have also said i am not where near a professional. is it not okay for me and some friends to do daily track driving? No reason for me to lie. WHatis wrong with my alignment, it is in specs?
Old 03-25-2017, 06:56 PM   #37
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The second post here is a starting point based on peoples set-ups
http://www.ft86club.com/forums/showthread.php?t=103609
Old 03-25-2017, 11:49 PM   #38
Ultramaroon
not playing cards
Alignment is acceptable, IMO. My gut says you're just overdriving the car.
1. What car have you driven that does what the frs doesn't do?
2. When the VSC kicks in, which end is letting go?
3. What's the outside temperature when you are driving
4. What's your tire pressure. If they're not even, tweak them and try again.
Old 03-26-2017, 03:05 AM   #39
navanodd
Drives: 2013 BRZ Sport-tech WRB
No I called Toyota to do it about a months ago and they would not do it bc they do not "recommend it"
They wouldn't do it? Give Subaru a call then. Surprised to see a shop refuse a simple job like that.
I changed mine at about 25,000 km. Before changing, the LSD did not engage smoothly at all, it was like an on-off switch. Afterwards it was much more progressive, with a lot less tire squeal.
I'm up to around 45,000 km on the car now, and the LSD still works great, so I think the issue was more down to diff gears wearing in than short fluid life.
navanodd is offline   Reply With Quote
Old 03-26-2017, 05:49 AM   #40
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I agreed with you...it is always better to keep your oil/fluid fresh....
My dealership actually told me to flush my brake fluid when my car only has 19000 miles...There is no way to refuse a simple job where they can make big money....you know...dealership..
FR-Sky is offline   Reply With Quote
Old 03-26-2017, 07:28 AM   #41
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
OP, are you sure you're not bottoming out the suspension or getting some bad rubbing? You are lowered, bigger than stock tires and that's a lot of load in that corner. Have you tried returning to stock springs just for a test?
Old 03-27-2017, 04:48 PM   #42
cmurp96
I had thought about this bc i never had the problem before new tires and lowering which was over a year ago. But i also did not drive my car as hard as I do now either. DOnt have the money to put springs back on lol but thanks for the suggestion
SPC LCA Alignment Issue? ssidd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-15-2018 12:58 PM
FRS Bumper alignment issue, help please Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 5 06-04-2015 02:27 PM
Do I just need an alignment or... (scraping issue) IDFWU 420 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-26-2014 12:26 AM
Alignment issue guscab Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-08-2014 10:26 PM
